Looking to buy a 1st gen / just bought a 1st gen? READ THIS - Page 8 - Dodge Cummins Diesel Forum
 25Likes
post #85 of 105 (permalink) Old 07-31-2017, 03:56 PM
SlammedYam's Avatar
thanks man! Ill go look at it this weekend.
SlammedYam is offline
post #86 of 105 (permalink) Old 07-31-2017, 04:41 PM
myother4x4isaCJ7's Avatar
Originally Posted by avvblanc01 View Post
My two cents would be to (if you can afford it) buy it and then decide if you want to keep your ford as a daily. First gens are really cool, but you'll be losing a lot of the creature comforts of your 2006 ford! I personally have my first gen as a fun weekend toy and cruiser, and then use my 2006 ram as a primary work vehicle/road trip vehicle.
First gens are loud, ride rough, and are totally unrefined. Those are also the things that make them so damn fun to own. It's literally a tractor engine stuffed into an old dodge truck haha.
The price on the truck you're looking at sounds really solid, so go test drive it and see what you think. I know a lot of people that happily daily drive first gens with zero regrets!
I daily drive my first gen and have no desire to buy anything else!!!! Gets ok mileage, has good power (I've surprised a few newer trucks pulling up a steep hill) and is a conversation starter, everyone has a story about these trucks kind of like owning an old bug. If you've owned an old vw you would know what I'm talking about. Literally my only complaint is the rough ride but that will be fixed with new springs when the budget allows.
myother4x4isaCJ7 is online now
post #87 of 105 (permalink) Old 07-31-2017, 06:43 PM Thread Starter
avvblanc01's Avatar
Oh yeah I also forgot to add that with a first gen (especially a 2wd one) you'll be seeing some major mpg improvements over your 6.0 ford. I usually see between 17 and 23 mpg out of my 1993 d350. That's driving below 70mph though.
Instagram:@AVVBLANC 2006 2500 qcsb 4x4: auto, yukon hubs, Fass, 2mic Cat/baldwin 5mic FWS, 20" Trail Ready wheels & 37's, Edge insight, custom retroshop, heads/tails, Carli Dominator, Amp steps, Smarty JR 1993 D350 5spd, HID projectors, 4in TBE
avvblanc01 is offline
post #88 of 105 (permalink) Old 08-06-2017, 09:40 PM
SlammedYam's Avatar
Okay so I took the plunge today and bought a 92 D350 shows 194,000 miles and odometer works. No rust to speak of. Power steering pump leaks and runs out of fluid after about an hour give or take. It won't go over 55 mph down the road so I think there is a transmission issue. Also, there is an oil leak from somewhere lower in the engine but haven't found it yet. Thoughts?
post #89 of 105 (permalink) Old 08-07-2017, 07:46 PM
You probably have no overdrive, testing and adjusting the tps would be a great place to start
avvblanc01 and SlammedYam like this.
post #90 of 105 (permalink) Old 01-03-2018, 09:14 PM Thread Starter
avvblanc01's Avatar
I'll second the OD probably being the culprit. PS isn't too bad to replace, just make sure you get a quality unit and not a reman. As for the oil leak, unless you're loosing a noticeable amount of oil, I wouldn't worry about it. These 12v Cummins like to sweat haha
Congrats on the new rig!
post #91 of 105 (permalink) Old 02-07-2018, 10:24 AM
Last First Gen's Avatar
Hey all, I bought a 93 W250 Cummins a little over a year ago and have been running into some problems with it... I only recently started having the money to get it into the shape she deserves to be in. She's got a fairly new paint job (bright red), 4" body lift and stock pretty much everything else.
What I've done to it
So far, I've had to replace my turbo - not upgraded, just new. Alternator and battery (interstate 800 CCA). I saw some brake dust on my front right wheel the other day to find out I now need to replace my rotors and brakes (ordered from RockAuto and are in shipping ATM). I've also replaced my ignition lock cylinder, and ignition switch.
Problems I'm having
-I am having an electrical problem that is giving me (and the wife) a serious headache, where the old girl is draining battery while it's off. I can't leave it for more than two days without needing a jump. I can't for the life of me figure out what the hell is draining it. I know I have a short in my horn (it blows the fuse when I hit the horn) but I am nervous to take apart the steering column to find out what it is.
-My wiper arms are going limp (when I drive over 50, they are not fully seated on the windshield anymore) and no one has OEM replacements for them.
-My headlight socket has a broken plastic adjuster clip and I cant seem to find a new one so she doesn't look like she has a lazy eye anymore.
-My electrical system pulses (brightens and dims)
-Whenever I use my dash or headlights, the buzzer goes off - even when the engine's running.
What I want to do to it
-I desperately want to get rid of my stock exhaust system (it was designed horribly) and so it sounds better.
-I would love to get more HP out of her, but I don't want my MPG to get any worse than it already is.
-I want to change my body lift to a suspension lift
-Clean up the interior (new door panels, door seals, carpet, roof liner, etc.)
If anyone has an answer to the problems I've been having, please share! It would help the wife be less mad at me for buying the old beauty. Thanks all!
Last First Gen is offline
post #92 of 105 (permalink) Old 02-07-2018, 04:04 PM
Blue Goose's Avatar
Beautiful truck!
LMC has the adjusters for the headlight if the local parts store does.
Truck Parts and Truck Accessories
I'd unhook the battery if the truck sits for days till you fifure that one out
the lights pulsing is normal in the cold weather while the grid heaters cycle until the truck warms up...is yours doing it longer?
I might have a spare set of factory wiper arms. Let me know and I'll check.
and beautiful truck!
and these trucks usually get pretty good milage
'81 D150
Blue Goose is offline
The Following User Says Thank You to Blue Goose For This Useful Post:
Last First Gen (02-07-2018)
post #93 of 105 (permalink) Old 02-07-2018, 04:15 PM
Tmtbob's Avatar
Disconnect the negative cable from your battery. Take a test light and go between the negative post and the cable. Then start pulling fuses until it goes out. That's your current draw. Most cars have a little draw so the light will be really dim under normal circumstances but something that drains a battery in a couple days will have that test light burning bright
thrashingcows likes this.
Tmtbob is offline
The Following 2 Users Say Thank You to Tmtbob For This Useful Post:
Last First Gen (02-07-2018), thrashingcows (02-07-2018)
post #94 of 105 (permalink) Old 02-07-2018, 04:48 PM
Brashanic_im's Avatar
Problems I'm having
when mine was draining the battery it was because the glove box light was staying on while closed.
1993 W350 4x4 DRW Manual daily driver
2012 3500 H.O. Laraime 4X4 DRW Auto
Brashanic_im is offline
post #95 of 105 (permalink) Old 02-07-2018, 06:21 PM
I've never even opened the thing lol, i'll give it a look!
post #96 of 105 (permalink) Old 02-07-2018, 06:27 PM
dumb question but is a test light the same as an multi-meter?
