93 steering box brace. - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 06-30-2014, 01:23 PM Thread Starter
I have a crack in the frame at the steering box mount plate on the 93. Is it better to weld the crack then brace it or just put a brace on. From what I read the heat from the welding will alter the condition of the metal. Is there anyone still making recreations of the brace? Cross over steering is not an option at the moment.
Trevor B.
fiveptnineftw is offline
post #2 of 8 (permalink) Old 06-30-2014, 04:19 PM
simplysmn
simplysmn's Avatar
iTrader Score: 11 reviews
Welding it will be fine as for the Brace good Luck some Ramcharger's had them but they are Hard to find .
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto sxe62/70 turbo 6x13 injector's full 4 in Diamond Eye Exhaust ,366 spring and THD fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #3 of 8 (permalink) Old 06-30-2014, 05:53 PM
1STGENFARMBOY's Avatar
I bought a brace that goes on the inside of the frame made for a little red express, new for like 30 bucks...sorry I can't remember where I got it though.
if you have the frame horn striped for welding I would box that part of the frame, I think they need it.
93 W250, A518, 3.54, DDP 4's, 16cm housing, 60mm Gillett, all pump mods, P/S intercooler, Tim W cooler tubes, carter 4601, 366 spring, denny t pin, homemade BHFF, BHAF, 1/8in bump, 4in DP to 5in , gauges,
1STGENFARMBOY is offline
post #4 of 8 (permalink) Old 07-01-2014, 12:22 AM
thrashingcows's Avatar
Doesn't Jungle Jim over on RCC make a boxing kit?
I got my RC frame brace off E-bay. Lucked out when it showed up late one night. Tuff to find since the company that was reproducing them has not made another run on them.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 350K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #5 of 8 (permalink) Old 07-01-2014, 01:45 AM Thread Starter
Think hard it would help out. The whole front of the truck is stripped down at the moment.
post #6 of 8 (permalink) Old 07-01-2014, 08:41 AM Thread Starter
This is my e-mail to dodgeconnection.com about the steering brace they have on their online store. If there is enough demand they may bring them back unfortunately this design is under copyright. Their email is [email protected]
Hello my name is Trevor I'm up in Vernon CT. I and many other first gen owners are still looking for these braces. I see they are discontinued is there any way to still get them? Is there a minimum number of orders you would need to make this feasible for you?
Thank you,
Trevor B.
Response:
Trevor,
We are working on having them reproduced. I'll put your name on the list to be contacted once they are done. Hope to have a date from them soon.
Thank you
Kim
DC
post #7 of 8 (permalink) Old 07-01-2014, 02:53 PM
I have my name on that list too. I received the same basic response a couple years ago.
post #8 of 8 (permalink) Old 07-01-2014, 06:18 PM
justinfonder's Avatar
I had the same the issue about 2 months ago with my 93 frame bracket. the bracket cracked, when i took it off i found the forward most hole was cracked all around. i drilled a small hole at the base of the crack then filled it all with a heavy weld. i then cut a piece of 3/8" steel plate to brace between the front and bottom 2 holes on the backside of the frame. I didnt have the time or tools to do the full box, but i think this helped some. here is what it looks like. used all new grade 8 hardware as well. couldnt make it connect to the third hole as there is a hump in the frame between the two. i figure it made it 225K on the first one, should make it another 225K with this.
'67 D100 on '89 D350 chassis/12v/a518 --- '88 Ramcharger on '93 W250 chassis/12v/47rh --- '93 W250 race truktor --- '03 1500 shorty 12v/a518 --- 12 3500 cclb studded, deleted, tunez, 5
justinfonder is offline
