Where/how to tap in for gauge lights? - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 06-29-2014, 10:51 PM Thread Starter
Hey all,
Sorry if this has been gone over before, but i couldn't find a thread that answered my question.
I'm installing isspro boost and pyro gauges. the pyro will be easy, all it needs is 12v when key is on, i will buy one of those blade fuse add-on plugs and find a good spot.
However, i want to hook the boost gauge light to the dimmer switch integral to the headlight switch. i could cause a bunch of trouble and figure it out myself, but does anyone know how to easily access the switch and which wire goes to the gauge lights in the dash? I read about using the ashtray light, but i don't have one!
thanks,
conrad
'89 W350, 4" straight pipe, BHAF, HE351CW, 2nd Gen intercooler, 5x13 injectors, 3200RPM gov spring, M&H Dynamic Timing Spacer, BD fuel pin, 5 speed. '02 3500 4" exhaust, 100HP injectors, hot rod VP44, NV5600, south bend clutch, Edge J w/A, dually.
con-rad is offline
post #2 of 5 (permalink) Old 06-29-2014, 10:59 PM
9297oldram's Avatar
Easiest way is to tap the fuse in the fuse box for the dash lights.
9297oldram is offline
post #3 of 5 (permalink) Old 06-29-2014, 11:15 PM Thread Starter
dumb question maybe... but will the dimmer switch dim the gauge lights too with that set up?
thanks
conrad
con-rad is offline
post #4 of 5 (permalink) Old 06-29-2014, 11:22 PM
9297oldram's Avatar
Yes it will.
post #5 of 5 (permalink) Old 06-30-2014, 01:15 AM
jbtsurf's Avatar
Any of the 20gauge solid orange wires in the cab are a light source.
'89 W250 SC Dana61/70-2UA rear Disc conv. 727
'81 CrewCab Remodel https://www.cumminsforum.com/forum/89...b-remodel.html
jbtsurf is offline
