Vibrations and shuttering when turning - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 06-29-2014, 04:58 PM Thread Starter
peckens's Avatar
I have had this problem for awhile amd I think its time i finally try to figure this out. I for the life of me cannot figure out why I have so much vibration and noise when I am turning on paved roads at slow speeds, like turning at a stop sign. I feel it everywhere and the gf even commented that it feels worse. It almost feels like my tires have "too" much traction. Its making me wonder if my axles are in need of a rebuild, king pins are just so rotted or warn out, or that its just the tires. I rebuilt he front hubs a year ago, no change.
1993 W250 ext cab a518 (Revmax t/c) 4.10, 366 spring; timing bump; Red Head steering gear w/ Dodge Connection brace, bhaf, DAP 5x12 sac injectors
peckens is offline
post #2 of 12 (permalink) Old 06-29-2014, 09:06 PM
Have you inspected the knuckle U-joints lately? When you rebuilt the hubs, did you pull the spindle and inspect the outer axle shaft inner roller bearing?
91 W350 SRW, 3.07's w/LSD, NV4500, 2nd gen IC, 370's, HX40
Ikes92 is offline
post #3 of 12 (permalink) Old 06-29-2014, 10:37 PM Thread Starter
peckens's Avatar
When i rebuilt the hubs i just pulled them off cleaned everything and replaced all ghe races and bearings in the hub. I never pulled the shaft because the ujpints were fine
peckens is offline
post #4 of 12 (permalink) Old 06-29-2014, 11:30 PM
country_hick's Avatar
Your u-joints might be chewed up internally and still be tight.
The bearing assembly of the u-joint may have notches instead of a smooth surface. As the u-joint is forced to work during a turn this idea would make sense. Picture the needle bearings in a case that has cutouts the same size as the needles. When you turn the needle falls into the groove nicely. Then when the needle hits the uphill part of a groove it struggles to go over that hump. That would make a jerking and a vibration.
Naturally this can happen to any bearing. It is not just limited to u-joints.
I would tend to rule out the tires. They should not be a cause of noise at low speeds.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
The Following User Says Thank You to country_hick For This Useful Post:
peckens (06-30-2014)
post #5 of 12 (permalink) Old 06-30-2014, 02:36 PM
Mine used to feel like it was in 4WD when making sharp turns on the road. Changed joints and it was gone. It made a world of difference. Especially while towing during low speed turns.
93 W250 4x4 G360; VE w/std mods; KDP killed; Hydroboost brakes; ⅛" bump; HX35 @31psi; 4" TBE; PSD IC w/custom 3" piping; Bosch190's; Custom fuel pin; LED's all around; boost, pyro, tach, oil pressure, water temp & digital volt gauges
Nughuffer is offline
The Following User Says Thank You to Nughuffer For This Useful Post:
post #6 of 12 (permalink) Old 06-30-2014, 03:38 PM Thread Starter
peckens's Avatar
That makes a ton of sense, especially since just about every ujoint I have done has been gnarled up just like you described. Ill be alone on the 4th, so this will be my project.
Any advice on pressing those ujoints out, I always use a ball joint press.
peckens is offline
post #7 of 12 (permalink) Old 06-30-2014, 05:05 PM
I use a bearing press but it can be done with a decent bench vise. Ball joint press should do the trick.
post #8 of 12 (permalink) Old 06-30-2014, 06:14 PM Thread Starter
peckens's Avatar
I just jacked up thenfront end and locked the hubs. The d/s was relatively easy to turn with the wheel straight or turned. The P/s was not, infact it turned with quite alot of resistance. I then lowered the truck back on the ground and drove it back and forth with the wheels turned. I noticed a slight popping when the wheels were turned and moving forward only. Im pretty convinced at this point it is a ujoint.
peckens is offline
post #9 of 12 (permalink) Old 06-30-2014, 10:42 PM
My u-joints always got beaten out with a hammer. I am not saying it is the best way but I have no press.
post #10 of 12 (permalink) Old 07-01-2014, 08:52 AM
Make sure it isn't in 4X4.
1998 2500 4X4. built my own automatic. Built my own engine too.
j-fox is offline
post #11 of 12 (permalink) Old 07-01-2014, 04:25 PM
thrashingcows's Avatar
Yup sure sounds liker a bad U-joint on the front drive axle.
I do U-joints with a couple sockets (couple big, and small) and a hammer. Never had an issue.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #12 of 12 (permalink) Old 07-01-2014, 07:53 PM Thread Starter
peckens's Avatar
Pulling the shaft on the ps tonight. I picked up new ujoints and a spindle bearing and seals just in case. Ill let you guys know how it turns out.
peckens is offline
