2.5" lift in front - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 06-28-2014, 10:23 AM Thread Starter
2.5" lift in front
Ok so I'm looking at lifting the front end of my dodge with a 2.5" lift. All new leafs. Would I possibly be able to run 35x13s with it or would I need more of a lift. Don't want to lift it any higher because the truck will still be used to haul gooseneck trailers on the farm and when I have to haul other trucks.
91 dodge w250 5.9/727 1/8 timing bump rotated fuel pin stock everything else...
Sbrown91w250 is offline
post #2 of 5 (permalink) Old 06-29-2014, 10:54 PM
Andrewtt12's Avatar
I cleared 315s (34.6) at stock height. Only rubbed when turning sharp and hit a bump. Wheels will also play apart on if they rub... mine were on steel wagon wheels
1993 LE W-250 currently under the knife...
build thread -
Andrewtt12 is offline
post #3 of 5 (permalink) Old 06-29-2014, 11:37 PM
Comrade General's Avatar
when i got my my 1/2 ton, it had approx a 2in lift in the front and only cleared 35s with some trimming
Generally if you want 35s, a 4in is the way to go, unless you dont mind trimming
<<check it out
1993 w250 getrag, 374 spring, THD pin, THD comp inj 6x.013, SBDD clutch, timing spacer, 60mm hx35, HT3B, D80, 3.54, 35"s, 6in lift, AirDog, studs, o-ringed Dyno: 427/951
Comrade General is offline
post #4 of 5 (permalink) Old 06-29-2014, 11:45 PM
Andrewtt12's Avatar
I trimmed my flares because the tires ripped them off but I had rubbing. Now I have 4" and 36s with no rubbing at all.
build thread -
post #5 of 5 (permalink) Old 07-01-2014, 10:49 PM Thread Starter
Well the reason I was asking was because I wanted to still be able to pull our gooseneck flat bed and stock trailer. I guess I'm just gonna stick with getting some 33s. I wouldn't mind the 4" lift at all except I don't think I'll be able to pull the trailer.
