3rd Gen - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 06-24-2014, 11:37 PM Thread Starter
zgb112's Avatar
3rd Gen
Yes i have used the search. learned everything i could find out.
I would like to know if its safe to use 1/2 inch lugs/studs to bolt on 9/16 spacers i will be converting to 9/16 studs sooner or later but i don't want dumping the extra money into it right now when i have to spend close to $300 on spacers.
I didnt plan on buying wheels yet anyways but for $200 for nice wheels, tires, caps, and lugs i couldnt let them go
They should look pretty good. Especially compared to the junk pile they will be sitting under. lol
1993 w250 Club Cab, BD fuel pin, 3200 spring, hx35, Auto.
zgb112 is offline
post #2 of 14 (permalink) Old 06-24-2014, 11:52 PM
country_hick's Avatar
I would not do it. You have a big hole with a little bolt. That bolt could easily move around and ruin your day. It might ruin the spacers or rims.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #3 of 14 (permalink) Old 06-25-2014, 12:00 AM Thread Starter
zgb112's Avatar
yeah thats what my concern was. well these 200 dollar wheels are probably going to turn out to be 700 dollar wheels by time i get them on. I figure if i'm going to pull the shafts to put in new studs i might as well install new seals and bearings while im at it.
zgb112 is offline
post #4 of 14 (permalink) Old 06-25-2014, 12:22 AM
1070's Avatar
are you sure those wheels will fit seems like I read a thread about that and they are spaced wrong and will hit the break drum. I may not be correct you might check before changing studs. that might be the spacers your talking about.
94 5sp 4x4 4x13x155 2x4 to 4x4 converson.ford dana 60 lockout hubconv. 91.5 gas to 6bt conv. 2x4 to 4x4 conv.5x12x155 16deg timming fass 95 nv4500 conv p pump conv. 05 fass95 d60 lockout hub conv ats conv BD trans controller
1070 is offline
post #5 of 14 (permalink) Old 06-25-2014, 12:33 AM Thread Starter
zgb112's Avatar
Double post
zgb112 is offline
post #6 of 14 (permalink) Old 06-25-2014, 12:36 AM Thread Starter
zgb112's Avatar
Yeah the purpose of the spacers is so I can use the wheels without hitting. The purpose of using spacers with 9/16 studs instead of 1/2 inch studs is so I can use the factory 3rd gen lugs that are needed to hold on the center caps
zgb112 is offline
post #7 of 14 (permalink) Old 06-25-2014, 12:38 AM
1070's Avatar
thanks that's good to know.
1070 is offline
post #8 of 14 (permalink) Old 06-25-2014, 12:47 AM Thread Starter
zgb112's Avatar
No problem! I'm pretty excited to get them on. I guess even if it does cost me close to $700 to get them on, it's still cheaper then new wheels and tires
zgb112 is offline
post #9 of 14 (permalink) Old 06-27-2014, 10:27 PM Thread Starter
zgb112's Avatar
anyone have a link to good 9/16 studs to use? or the specs for the factory 1/2 inch studs so i can match them up
zgb112 is offline
post #10 of 14 (permalink) Old 06-28-2014, 08:33 PM
AlecD's Avatar
I'm running 3rd gen wheels with 1/2in thick 9/16 lug spacers and they work fine, might have to do a little caliper grinding though, i'm not sure.
1991 W250 RCLB Non I/C Cummins Red/Gray
AlecD is offline
post #11 of 14 (permalink) Old 06-28-2014, 09:29 PM
Zgb112, Dorman PN 610-283 is the best fitting stud to use.
Couple other things worth noting:
You'll need two sets of lug nuts. Reason being is that most spacers come with REALLY crappy lug nuts, you'll need to use 3/4" head, 9/16" open head nuts. They will fit down inside the bore of the spacers without needing a special thin walled socket. Second set is so the hubcaps will stick on the lug nuts, I used a used set of second gen lug nuts. 15/16" head, 9/16" nuts. If you got a set that will work, you're money ahead.
Don't buy the studs from your local favorite parts store, they'll charge you $2-4 each. Get on eBay and buy them that way, I paid $18 for a box of ten, X3. Then bought two individual ones.
Don't grind the calipers. Run 1.5" or 2" spacers. Steel ones are the best to use, but are really spendy.
91 W350 SRW, 3.07's w/LSD, NV4500, 2nd gen IC, 370's, HX40
Ikes92 is offline
The Following User Says Thank You to Ikes92 For This Useful Post:
zgb112 (06-28-2014)
post #12 of 14 (permalink) Old 06-28-2014, 11:07 PM Thread Starter
zgb112's Avatar
yeah that is the part number that keeps coming up when i search. so thats what it'll have buy then. hope they work! they worked well for you, front and rear? w350 use the same axles as the w250?
zgb112 is offline
