Triple Guage Mounting - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 06-24-2014, 12:57 AM Thread Starter
89_12valve's Avatar
Good evening all... Now that I got my charging issue figured out, Im ready to add some guages and start driving her(after a paintjob) Im thinking of the boost and pyro guages for the pillar and I want to add the Summit Racing Triple Guage pod with Voltmeter, Oil Pressure, and Water Temp. I like those guages because they are sort of period correct and looks like it would belong in my truck. Where is the best place to mount the guages? Im trying to go for a clean, OEM type of look but if thats unavoidable, then it is what it is. Thanks!
1989 Dodge D250- 12v Cummins/5speed/3.54s/17x000 miles. KDP killed, DPS manifold, BHAF,M5 fuel pin, pump work, 4 in to Kenworth stack.
1988 S10- 2.5/T5/3.73s Daily with bolt-ons for MPG 26mpg
89_12valve is offline
post #2 of 4 (permalink) Old 06-24-2014, 07:17 PM
Comrade General's Avatar
If you wait a little while autometer is making a 3 gauge pillar pod specifically for our trucks.
Alot of people will take a 2 gauge pillar pod and use a single one.
The 2nd gen dash 3 gauge pod will work with some trimming.
The 2nd gen steering column gauge pod works aswell .... just saw you have an 89 so nevermind, yours is a different steering column
The Hungry Diesel <<check it out
1993 w250 getrag, 374 spring, THD pin, THD comp inj 6x.013, SBDD clutch, timing spacer, 60mm hx35, HT3B, D80, 3.54, 35"s, 6in lift, AirDog, studs, o-ringed Dyno: 427/951
Comrade General is offline
The Following User Says Thank You to Comrade General For This Useful Post:
RCCUMMINS89 (06-24-2014)
post #3 of 4 (permalink) Old 06-24-2014, 11:26 PM Thread Starter
89_12valve's Avatar
I got the pillar figured out, but I was thinking more along the lines of the triple guage set you can get from Stewart Warner or Autometer... I was wondering if and where people were putting guages other than the pillar or column. I would like my pyro and boost on the pillar and a tasch on the column. But I was looking for ideas for my triples.
post #4 of 4 (permalink) Old 06-25-2014, 02:08 AM
thrashingcows's Avatar
I originally had my 2 of my gauges on my dash, and one on my column...89 wiring and column in my 84 crewcab. When I converted to 4wd I swapped all the 1993 donor stuff over. I did not want to mount he gauges on the dash again...so I did the boost and pyro on the pillar, and the tach on the column. I have to say I really like this set-up!!
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
