Tail light Help - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 06-23-2014, 10:16 AM Thread Starter
Cornfedbindered's Avatar
Tail light Help
Need some help on tail lights for my 93 w350.
My truck has the additional harness for marker lamps on the dually fenders. My problem deals with no function of the left tail light. Does anyone know where this light is supposed to get its power? I have two plugs coming from the right ( pass) side of the truck ( both have power) The hot wire with tail lights on is a black wire with a yellow stripe and a gray wire ( ground).
Not sure how these two plugs integrate into the left side. I can pull power from either plug and jump power to the tail light and everything works.
I assume 1 plug would be for the license plate light.
In addition, I have a relay close to the left tail light connector plugs in the rear. Is this factory?
My ultimate goal is to wire the truck for a 7 way without splicing into the harnesses. It sounds as if I will also need to do a power convertor to avoid voltage drops and save the headlamp switch due to a heavier load on the system.
Thanks for the help.
Cornfedbindered is offline
post #2 of 5 (permalink) Old 06-25-2014, 12:15 AM Thread Starter
round 2
No suggestions?
post #3 of 5 (permalink) Old 06-25-2014, 12:27 AM
Comrade General's Avatar
Not really sure, but I think if only one is side is out (and you ruled out the bulb and the socket being bad) then there must be a brake some after the wire splits off to go to that side, or something along those lines.
Do you have a meter to test for voltage?
<<check it out
1993 w250 getrag, 374 spring, THD pin, THD comp inj 6x.013, SBDD clutch, timing spacer, 60mm hx35, HT3B, D80, 3.54, 35"s, 6in lift, AirDog, studs, o-ringed Dyno: 427/951
Comrade General is offline
post #4 of 5 (permalink) Old 06-25-2014, 12:58 AM
thrashingcows's Avatar
A factory service manual is always helpful when trying to diagnose wiring issues.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 350K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #5 of 5 (permalink) Old 06-25-2014, 09:47 AM
jbtsurf's Avatar
pics would really HELP us HELP you... but good job with the word description. its just a lot of wires to draw in the readers' heads.
'89 W250 SC Dana61/70-2UA rear Disc conv. 727
'81 CrewCab Remodel
jbtsurf is offline
