brakes - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 06-19-2014, 07:58 PM Thread Starter
brakes
I got a 89 w250 my abs unit things that sit in the frame rails are shot so I had bypassed both front and rear people say that these trucks stop straighter and faster without them anyway well here's my problem no matter how much I bleed em the pedal is still soft it comes up and the truck stops so its not a big deal but was wondering why I don't have the stopping power I was hoping for any help would be great thanks
1989scummins is offline
post #2 of 10 (permalink) Old 06-19-2014, 10:54 PM
I would suspect the master cylinder
91 350, 4X4, 5.9, Auto Trans, Non IC, HE Radiator, Flow through Exhaust, K&N,
2007 3500 Quad Cab Laramie 4X4 Long Bed
2013 5500 C/C 12' Reefer box on Board 4X4 Pto Opt. Aisin 6 speed
DBS1 is offline
post #3 of 10 (permalink) Old 06-20-2014, 01:02 AM
Dodgeboy360's Avatar
Rear brake adjustment? I just did my rear and upgraded to 1 ton 3" pads and wheel cylinders.. Bypassed abs and she almost stops on a dime now
Dodgeboy360 is offline
post #4 of 10 (permalink) Old 06-20-2014, 01:10 AM Thread Starter
I did all new everything in the rear and up front with all new lines I just can't seem to get the pressure
post #5 of 10 (permalink) Old 06-22-2014, 09:07 AM
Does the pedal travel a bit then get hard? Im also suspect of incorrect rear adjustment.
If hard right off the bat, the "safety valve" could be stuck, cutting off the rear brakes.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
post #6 of 10 (permalink) Old 06-25-2014, 11:35 PM
I'm having the same problem. I didint bypass the abs but my peddle gets applys down lower than it should. The rear adjustments r good I can tighten them up really tight and I have the same problem. I just replaced all the brakes master cylinder and brake booster. My abs plug is bad so the light is on it in the cab if that makes a difference. Where would I find this safety valve?
Angusbull is offline
post #7 of 10 (permalink) Old 06-27-2014, 08:33 PM
Depending on year the valve is either in the cahnnel of the frame under he firewall or on top of the frame just under the master cylinder. It has a "safety" valve to cut off the front or rear brae in the event of a blown brake line or leak.
post #8 of 10 (permalink) Old 06-27-2014, 09:41 PM
Rescue Tower
Shainer's Avatar
When you pump the brakes up (you don't have to be moving). Will the pressure maintain or does the pedal slowly sink to the floor? If it sinks you either have a leak, or your master cylinder is failing. If it stays solid, then something is out of adjustment. It is common for guys to ruin master cylinders in older rides when they bleed the brakes. Reason is they use more of the cylinders stroke than is normally used in every day driving. The extended stroke pushes through rough areas in the cylinder tearing up the seals allowing fluid to bypass.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #9 of 10 (permalink) Old 06-27-2014, 11:10 PM
Thx guys I will look around and figure try to figure it out.
post #10 of 10 (permalink) Old 06-28-2014, 04:46 PM
What fittings should I need 2 bypass the rear abs
