vacuum pump ? - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 05-04-2014, 11:12 AM Thread Starter
nick05's Avatar
vacuum pump ?
i'm looking to replace the bottom unit on my 90 rig. have the new pump & was ready to install but looks like a mother to replace on truck. can i remove the power steering unit without messing things up in the gear case? pretty much take off & reinstall the unit with no issues?
i just did the kdp & housing bolts, couldn't do the pump at the time.
nick
1992 w250 cc, 5spd "in progress"
98 12v cclb 5spd 4wd
nick05 is offline
post #2 of 10 (permalink) Old 05-04-2014, 01:21 PM
12vforwork's Avatar
Remove the vacuum pump/power steering pump the engine as an assembly. The power steering pump cannot be removed from the vacuum pump without first unbolting the whole assembly from the timing case. However, since you are just replacing the one bottom pod you can do that without removing the power steering pump with the whole assembly on the bench. You dont want to have to remove the power steering pump from the vacuum pump unless you are rebuilding the vacuum pump or replacing the power steering pump, you have to go through a certain procedure and it is a bit of a bear to separate the two.
1990 W250 5spd. (NV4500), Hx35, pump turned some, intake elbow, 4" all the way back with strait through muffler. Running ATI damper with stock tach trigger.
12vforwork is offline
post #3 of 10 (permalink) Old 05-04-2014, 01:49 PM Thread Starter
nick05's Avatar
Ok, right I can remove the assembly as 1 piece. I don't need to take power steering apart. I can just pull it out of the timing case & replace vac . pump correct? I'm just worried about lining up gears when reassemble.
nick05 is offline
post #4 of 10 (permalink) Old 05-04-2014, 02:03 PM
12vforwork's Avatar
Yup there is no timing for the vacuum pump gear to the rest of the timing gears. No way to put it back together and not have the gears meshed right.
post #5 of 10 (permalink) Old 05-25-2014, 10:07 AM Thread Starter
nick05's Avatar
ok im finally getting around to doing my pump replacement. how does one get the bottom bolt out behind the power steering resi? looks like fun.
tried a 15mm swivel & barely room to turn ractchet. no room to fit a wrench in there like the top bolt.
any pointers much appreciated,
nick05 is offline
post #6 of 10 (permalink) Old 06-08-2014, 06:37 PM
12vforwork's Avatar
You only need to remove the two bolts at the timing cover and undo 3 hoses to remove the unit as an assembly which then can easily be repaired on a workbench.
post #7 of 10 (permalink) Old 06-10-2014, 03:17 AM
How to service your vacuum pump
What happens when your vacuum pump stops working. - Dodge Diesel - Diesel Truck Resource Forums
It is easiest to remove the mounting bolts from the timing case using a "C" wrench,
Get yourself a set of them, they are needed if you ever remove your injection pump.
You can get a good set from Sears or a throwaway set from Harbor Freight.
Note**
A "C" wrench is also commonly known as a Manifold Wrench.
Jim
Jim L is offline
post #8 of 10 (permalink) Old 06-12-2014, 08:55 PM
12vforwork's Avatar
When I took mine off, the top bolt of course is out in the open. On the bottom one though I found a normal shallow socket with a wobble extension worked perfectly.
post #9 of 10 (permalink) Old 06-26-2014, 07:59 PM
Sledneck55's Avatar
I just replaced both pods on mine yesterday with it all on the truck. Took about hour and a half. Used a 10mm ratcheting wrench. Was the first time my truck had power brakes since I've owned it! Pretty fancy stuff!
Sent from AutoGuide.com App
2011.5 3500 6.7L HO Auto SRW 3.73, SLT full load, Carli BC lift + steering stab/brace, 35" Cepek, Fully deleted H&S+MM w/ CCV, AFE CAI, AFE diff cvrs,LED lighting, Ironcross bumper, AirRide bags, 5" TB MBRP dual 7" stacks, Webasto
Sledneck55 is offline
post #10 of 10 (permalink) Old 06-27-2014, 08:37 AM
superdre is offline
