Dodge Cummins Diesel Forum - View Single Post - How does the Over Drive work???
post #6 of (permalink) Old 06-05-2008, 12:00 AM Thread Starter
IPOLUTE
IPOLUTE's Avatar
When you step on it at that speed it is like you are in to high of a gear and you need to shift down but it will not kick down on it's own only if you manually do it then it works just fine. When starting out from a dead stop it shifts nice from first to second to drive to overdrive. I don't know if it is just inbetween gears and at that speed doesn't know what to do but my experience with auto's is that when you step on it it should kick out of Over drive and down shift to meet the demand of the driver.
[B][COLOR="DarkGreen"]2002 Dodge 24 valve Cummins 2500 4wd shortbed, Edge Juice w/ Attitude, Fass HPFP 150,edge stage 1 injectors, nv5600 6 speed, Straight Piped, BHAF w/ pre-filter, Rhino Liner, HBS Level Kit, Procomp ES9000 shocks, 107,000 miles
IPOLUTE is offline
