Dodge Cummins Diesel Forum - View Single Post - How does the Over Drive work???
post #1 of (permalink) Old 06-04-2008, 10:17 PM Thread Starter
IPOLUTE
IPOLUTE's Avatar
My dad has a 1996 CTD with an automatic. When doing about 55 to 60 mph and you step on it there is nothing unless you push the button and manually kick it out of overdrive then it will kick down to second and act normal. My question is should it kick out of O/D automatically or does it do it only manually at this speed? Let me know if I explained myself good enough or if you need more info.
[B][COLOR="DarkGreen"]2002 Dodge 24 valve Cummins 2500 4wd shortbed, Edge Juice w/ Attitude, Fass HPFP 150,edge stage 1 injectors, nv5600 6 speed, Straight Piped, BHAF w/ pre-filter, Rhino Liner, HBS Level Kit, Procomp ES9000 shocks, 107,000 miles
IPOLUTE is offline
