Dodge Cummins Diesel Forum - View Single Post - valair 450hp clutch slipping
post #17 of (permalink) Old 05-31-2008, 11:49 AM
IHfarmboy
IHfarmboy's Avatar
Originally Posted by Valair1 View Post
100 miles, you need to break it in a bit more before starting aggressive driving. and i see you truck is a 12V, did you resurface the flywheel and check the center bore of the flywheel for clearence, the 12V had a 6.875 inch bore and that clutch requires a 7".
i just put my Valair clutch in a couple mouths ago and i did not bore out my flywheel, what will happen if i don't?
'94 2500 5 spd- reg cab shortbed
IHfarmboy is offline
