Dodge Cummins Diesel Forum - View Single Post - 2004 ram 5.9
Thread: 2004 ram 5.9
post #2 of (permalink) Old 08-16-2013, 12:21 AM
tsilvscummins
tsilvscummins's Avatar
03-05 code list
i found this on the smarty website.. it is way more detailed than the one we have so i thought i would post it up
P0016–CRANKSHAFT / CAMSHAFT TIMING MISALIGNMENT
P0030-1/1 02 SENSOR HEATER RELAY MALFUNCTION
P0036-1/1 02 SENSOR HEATER RELAY MALFUNCTION
P0071-AMBIENT AIR TEMPERATURE SENSOR PERFORMANCE
P0072-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW
P0088-FUEL RAIL PRESSURE SIGNAL IS ABOVE MAX LIMIT
P0101-MAF SENSOR PERFORMANCE
P0102-MAF SENSOR LOW FREQUENCY
P0103-MAF SENSOR HIGH FREQUENCY
P0106-BAROMETRIC PRESSURE OUT OF RANGE
P0107-MAP SENSOR VOLTAGE TOO LOW
P0108–MAP SENSOR VOLTAGE TOO HIGH
P0111-INTAKE AIR TEMP PERFORMANCE
P0112-INTAKE AIR TEMP SENSOR VOLTAGE TOO LOW
P0113-INTAKE AIR TEMP SENSOR VOLTAGE TOO HIGH
P0116–ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT
PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE (ECT) SENSOR
VOLTAGE TOO LOW
P0118-ENGINE COOLANT TEMPERATURE (ECT) SENSOR
VOLTAGE TOO HIGH
P0121-TP SENSOR VOLTAGE DOES NOT AGREE WITH MAP
P0122-THROTTLE POSITION SENSOR VOLTAGE TOO LOW
P0123-THROTTLE POSITION SENSOR VOLTAGE TOO HIGH
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP
FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0130-1/1 02 SENSOR HEATER RELAY MALFUNCTION
P0131-O2 SENSOR 1/1 CIRCUIT VOLTAGE TOO LOW
P0132-O2 SENSOR 1/1 CIRCUIT VOLTAGE TOO HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0134-02 SENDOR 1/1 STAYS AT CENTER
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0136-O2 SENSOR 1/2 HEATER CIRCUIT MALFUNCTION
P0137-O2 SENSOR 1/2 CIRCUIT LOW
P0138-O2 SENSOR 1/2 CIRCUIT HIGH
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P0140-02 SENSOR 1/2 STAYS AT CENTER
P0141-02 SENSOR 1/2 RELAY
P0143-02 SENSOR 1/3 SHORTED TO GROUND
P0144-02 SENSOR 1/3 SHORTED TO VOLTAGE
P0145-02 SENSOR 1/3 SLOW RESPONSE
P0146-02 SENSOR 1/3 STAYS AT CENTER
P0147-02 SENSOR 1/3 HEATER FAILURE
P0148-FUEL DELIVERY ERROR
P0151-O2 SENSOR 2/1 CIRCUIT LOW
P0152-O2 SENSOR 2/1 CIRCUIT HIGH
P0153-O2 SENSOR 2/1 SLOW RESPONSE
P0154-O2 SENSOR 2/1 STAYS AT CENTER
P0155-O2 SENSOR 2/1 HEATER PERFORMANCE
P0157-O2 SENSOR 2/2 CIRCUIT VOLTAGE TOO LOW
P0158-O2 SENSOR 2/2 CIRCUIT VOLTAGE TOO HIGH
P0159-O2 SENSOR 2/2 SLOW RESPONSE
P0160-O2 SENSOR 2/2 STAYS AT CENTER
P0161-O2 SENSOR 2/2 HEATER PERFORMANCE
P0168-DECREASED ENGINE PERFORMANCE DUE TO HIGH
INJECTION PUMP FUEL TEMPERATURE
P0169-WATER IN FUEL (WIF) LIGHT ON TOO LONG
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0174-FUEL SYSTEM 2/1 LEAN
P0175-FUEL SYSTEM 2/1 RICH
P0176-LOSS OF FLEX FUEL CALIBRATION SIGNAL
P0177-WATER IN FUEL
P0178-WATER IN FUEL SENSOR VOLTAGE TOO LOW
P0178-FLEX FUEL SENSOR VOLTAGE TOO LOW
P0180-CNG TEMP SENSOR VOLTAGE FAIL
P0181-FUEL PUMP INJECTION PUMP FAILURE
P0182-CNG TEMP SENSOR VOLTAGE TOO LOW
P0183-CNG TEMP SENSOR VOLTAGE TOO HIGH
P0192-FUEL RAIL PRESSURE SENSOR VOLTAGE TOO LOW
P0193-FUEL RAIL PRESSURE SENSOR VOLTAGE TOO HIGH
P0201-INJECTOR #1 CONTROL CIRCUIT
P0202-INJECTOR #2 CONTROL CIRCUIT
P0203-INJECTOR #3 CONTROL CIRCUIT
P0204-INJECTOR #4 CONTROL CIRCUIT
P0205-INJECTOR #5 CONTROL CIRCUIT
P0206-INJECTOR #6 CONTROL CIRCUIT
P0207-FUEL INJECTOR 7 CIRCUIT
P0208-FUEL INJECTOR 8 CIRCUIT
P0209-FUEL INJECTOR 9 CIRCUIT
P0210-FUEL INJECTOR 10 CIRCUIT
P0215-FUEL INJECTOR PUMP CONTROL CIRCUIT
P0216-FUEL INJECTOR PUMP TIMING FAILURE
P0217-DECREASED ENGINE PERFORMANCE DUE TO ENGINE
OVERHEAT CONDITION
P0219-CRANKSHAFT POSITION SENSOR OVER SPEED SIGNAL
P0220-APP SENSOR 2 CIRCUIT
P0221-APP SENSOR 2 PERFORMANCE
P0222-APP SENSOR 2 CIRCUIT LOW
P0222-IDLE VALIDATION SIGNALS BOTH LOW
P0223-INJECTION PULSE WIDTH ERROR (RISE TIME LONG)
P0223-IDLE VALIDATION SIGNALS BOTH HIGH (ABOVE 5V)
P0225-APP SENSOR 3 CIRCUIT
P0226-APP SENSOR 3 CIRCUIT PERFORMANCE
P0227-APP SENSOR 2 CIRCUIT LOW VOLTAGE
P0228-APP SENSOR 2 CIRCUIT HIGH VOLTAGE
P0230-TRANSFER PUMP (LIFT PUMP) CIRCUIT OUT OF RANGE
P0231-FUEL PUMP FEEDBACK CIRCUIT LOW VOLTAGE
P0232-FUEL SHUT-OFF SIGNAL VOLTAGE TOO HIGH
P0234-TURBOCHARGER OVERBOOST CONDITION
P0236-MAP SENSOR TOO HIGH TOO LONG
P0237-MAP SENSOR VOLTAGE TOO LOW
P0238-MAP SENSOR VOLTAGE TOO HIGH
P0243-OPEN OR SHORTED CONDITION DETECTED IN THE
TURBOCHARGER WASTEGATE SOLENOID CONTROL
P0251-FUEL INJECTION PUMP FUEL VALVE FEEDBACK
CIRCUIT
P0252-FUEL INJECTION PUMP FUEL VALVE STUCK
P0253-FUEL INJECTION PUMP FUEL VALVE OPEN CIRCUIT
P0254-FUEL INJECTION PUMP FUEL VALVE CURRENT TOO
HIGH
P0263-CYLINDER 1 BALANCE SYSTEM
P0266-CYLINDER 2 BALANCE SYSTEM
P0269-CYLINDER 3 BALANCE SYSTEM
P0272-CYLINDER 4 BALANCE SYSTEM
P0275-CYLINDER 5 BALANCE SYSTEM
P0278-CYLINDER 6 BALANCE SYSTEM
P0281-CYLINDER 7 BALANCE SYSTEM
P0284-CYLINDER 8 BALANCE SYSTEM
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER # 1 MISFIRE
P0302-CYLINDER # 2 MISFIRE
P0303-CYLINDER # 3 MISFIRE
P0304-CYLINDER # 4 MISFIRE
P0305-CYLINDER # 5 MISFIRE
P0306-CYLINDER # 6 MISFIRE
P0307-CYLINDER #7 MISFIRE
P0308-CYLINDER #8 MISFIRE
P0309-CYLINDER #9 MISFIRE
P0310-CYLINDER #10 MISFIRE
P0320–NO CRANK REFERENCE SIGNAL AT PCM
P0325-KNOCK SENSOR 1 CIRCUIT .
P0327-KNOCK SENSOR NOISE CHANNEL LOW VOLTAGE
P0330-KNOCK SENSOR 2 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0336-CRANKSHAFT POSITION (CKP) SENSOR SIGNAL
P0337-CRANKSHAFT POSITION (CKP) SENSOR VOLTAGE TOO LOW
P0338-CRANKSHAFT POSITION (CKP) SENSOR VOLTAGE TOO HIGH
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
P0340-CAMSHAFT POSITION (CMP) LOST
P0341-CAMSHAFT POSITION (CMP) SENSOR SIGNAL
P0342-ESS VOLTAGE SUPPLY LOW
P0343-ESS VOLTAGE SUPPLY HIGH
P0350-IGNITION COIL DRAWN TOO MUCH CURRENT
P0351-IGNITION COIL #1 PRIMARY CIRCUIT
P0352-IGNITION COIL #2 PRIMARY CIRCUIT
P0353-IGNITION COIL #3 PRIMARY CIRCUIT
P0354-IGNITION COIL #4 PRIMARY CIRCUIT
P0355-IGNITION COIL #5 PRIMARY CIRCUIT
P0356-IGNITION COIL #6 PRIMARY CIRCUIT
P0357-IGNITION COIL #7 PRIMARY CIRCUIT
P0358-IGNITION COIL #8 PRIMARY CIRCUIT
P0370-FUEL INJECTION PUMP SPEED/POSITION SENSOR
SIGNAL LOST
P0380-INTAKE AIR HEATER RELAY NO.1 CONTROL CIRCUIT
P0380-GLOW PLUG CIRCUIT PERFORMANCE
P0381-WAIT TO START LAMP INOPERATIVE
P0382-INTAKE AIR HEATER RELAY NO.2 CONTROL CIRCUIT
P0387-CKP SENSOR SUPPLY VOLTAGE TOO LOW
P0388-CKP SENSOR SUPPLY VOLTAGE TOO HIGH
P0400-EXHAUST GAS RECIRCULATION (EGR) FLOW
MALFUNCTION
P0401-EGR SYSTEM PERFORMANCE
P0403-EGR SOLENOID CIRCUIT
P0404-EGR POSITION SENSOR RATIONALITY OPEN
P0405-EGR POSITION SENSOR CIRCUIT LOW
P0406-EGR POSITION SENSOR CIRCUIT HIGH
P0410-AIR SYSTEM
P0412-SECONDARY AIR SOLENOID CIRCUIT
P0420-1/1 CATALYTIC CONVERTER EFFICIENCY
P0430-1/2 CATALYTIC CONVERTER EFFICIENCY
P0432-1/2 CATALYTIC CONVERTER EFFICIENCY
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE FLOW MONITOR
P0442-EVAP LEAK MONITOR MEDIUM (0.040) LEAK DETECTED
P0443-EVAP PURGE SOLENOID CIRCUIT
P0446-EVAP EMISSION VENT VALVE PERFORMANCE
P0452-EVAP EMISSION PRESSURE SENSOR CIRCUIT LOW
VOLTAGE
P0453- EVAP EMISSION PRESSURE SENSOR CIRCUIT HIGH
VOLTAGE
P0455-EVAP LEAK MONITOR LARGE LEAK DETECTED
P0456-EVAP LEAK MONITOR SMALL (0.020) LEAK DETECTED
P0460-FUEL LEVEL SENDING UNIT NO CHANGE OVER MILES
P0461-FUEL LEVEL UNIT NO CHANGE OVER TIME
P0462-FUEL LEVEL SENDING UNIT VOLTS TOO LOW
P0463-HIGH VOLTAGE DETECTED AT THE FUEL LEVEL
SENSOR
P0475-EPR SOLENOID CIRCUIT
P0477-EXHAUST PRESSURE CONTROL RELAY LOW
P0478- EXHAUST PRESSURE CONTROL RELAY HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT OPEN (LOW SPEED FAN)
P0483-FAN SPEED
P0500-NO VEHICLE SPEED SENSOR SIGNAL
P0501-VEHICLE SPEED SENSOR PERFORMANCE
P0505-IDLE AIR CONTROL MOTOR CIRCUITS
P0506-IDLE SPEED PERFORMANCE LOWER THAN EXCEPTED
P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXCEPTED
P0508-UNDERCURRENT CONDITION DETECTED IN LINEAR
IDLE AIR CONTROL MOTOR FEEDBACK SENSE CIRCUIT
P0509-OVER CURRENT CONDITION DETECTED IN LINEAR
P0514-BAT TEMPERATURE SENSOR RATIONALITY
P0516-BATTERY TEMPERATURE SENSOR CIRCUIT LOW
P0517-BATTERY TEMPERATURE SENSOR CIRCUIT HIGH
P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT
P0521-ENGINE OIL PRESSURE SENSOR PERFORMANCE
P0522-OIL PRESSURE CIRCUIT LOW
P0523-OIL PRESSURE CIRCUIT HIGH
P0524-OIL PRESSURE TOO LOW
P0532-A/C PRESSURE SENSOR CIRCUIT LOW
P0533-A/C PRESSURE SENSOR CIRCUIT HIGH
P0541-LOW VOLTAGE ON THE #1 INTAKE AIR HEATER RELAY
P0542-HIGH VOLTAGE ON THE #1 INTAKE AIR HEATER RELAY
P0545-A/C CLUTCH RELAY CIRCUIT
P0551-POWER STEERING PRESSURE SWITCH FAILURE
P0560-SYSTEM VOLTAGE
P0562-CHARGING SYSTEM VOLTAGE TOO LOW
P0563- CHARGING SYSTEM VOLTAGE TOO LOW
P0567-CRUISE RESUME CIRCUIT
P0568-CRUISE SET CIRCUIT
P0571-CRUISE BRAKE SWITCH 1 PERFORMANCE
P0572-BRAKE SWITCH 1 LOW
P0573-BRAKE SWITCH 1 HIGH
P0575-CRUISE SWITCH FAILURE (SHORTED)
P0577-CRUISE SWITCH FAILURE (OPEN)
P0579-SPEED CONTROL SWITCH 1 PERFORMANCE (5.7L)
P0580-LOW VOLTAGE DETECTED AT THE SPEED CONTROL
MULTIPLEXED SWITCH
P0581-HIGH VOLTAGE DETECTED AT THE SPEED CONTROL
MULTIPLEXED SWITCH
P0600-PCM FAILURE SERIAL COMMUNICATION LINK
P0601-PCM INTERNAL CONTROLLER FAILURE
P0602-ECM FUELING CALIBRATION ERROR
P0603-VCM MEMORY RESET
P0604-ECM RAM CHECK FAILURE
P0605-ECM ROM CHECK FAILURE
P0606-ECM HARDWARE ERROR
P0607-ECU INTERNAL FAILURE
P0615-STARTER RELAY CONTROL CIRCUIT
P0621-GENRATOR L TERMINAL CIRCUIT
P0622-GENERATOR FIELD NOT SWITCHING PROPERLY
P0628-FUEL PUMP RELAY CICRUIT LOW
P0628-LOW VOLTAGE DETECTED AT THE FUEL LIFT PUMP
P0629-FUEL PUMP RELAY CICRUIT HIGH
P0629-HIGH VOLTAGE DETECTED AT THE FUEL LIFT PUMP
P0630-VIN NOT PROGRAMMED IN PCM
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
P0643- SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
P0645-A/C CLUTCH CONTROL CIRCUIT
P0646-LOW VOLTAGE DETECTED AT THE A/C CLUTCH RELAY
P0647-HIGH VOLTAGE DETECTED AT THE A/C CLUTCH RELAY
P0650-MALFUNCTION INDICATOR LAMP (MIL) CIRCUIT
P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH
P0654-ENGINE SPEED OUTPUT CIRCUIT
P0698-SENSOR REF VOLTAGE 3 CIRCUIT LOW
P0699- SENSOR REF VOLTAGE 3 CIRCUIT HIGH
P0700-EATX CONTROLLER DTC PRESENT
P0703-BRAKE SWITCH PERFORMANCE
P0704-CLUTCH SWITCH CIRCUIT (M/T)
P0711-TRANS TEMP SENSOR, NO TEMP RISE AFTER START
P0712-TRANS TEMP SENSOR TOO LOW
P0713-TRANS TEMP SENSOR TOO HIGH
P0720-LOW OUTPUT SPEED SENSOR RPM, ABOVE 15MPH
P0740-TORQUE CONVERTER CLUTCH, NO RPM DROP AT
LOCKUP
P0743-TORQUE CONVERTER CLUTCH SOLENOID/TRANS
RELAY CIRCUIT
P0748-GOVERNOR PRESSURE SOL CONTROL/TRANS RELAY
CIRCUIT
P0751-O/D SWITCH PRESSED (LOW) MORE THAN 5 MINUTES
P0753-TRANS 3-4 SHIFT SOL/TRANS RELAY CIRCUIT
P0756-AW4 SHIFT SOL B (2-3) FUNCTIONAL FAILURE
P0783-(3-4) SHIFT SOL, NO RPM DROP AT LOCKUP
P0801-REVERSE GEAR LOCKOUT CIRCUIT OPEN OR
SHORTED
P0830-CLUTCH DEPRESSED SWITCH CIRCUIT
P0833-CLUTCH RELEASED SWITCH CIRCUIT
P0837-4WD SWITCH PERFORMANCE
P0838-4WD SWITCH CIRCUIT LOW
P0839-4WD SWITCH CIRCUIT HIGH
P1000-IGNITION CIRCUIT LOW
P1001-IGNITION CIRCUIT HIGH
P1004-ECU BATTERY FEED & POWER GROUNDS
P1005-SYSTEM GROUND CIRCUIT
P1006-EGR/EVAP SOLENOID CIRCUIT LOW
P1007-EGR/EVAP SOLENOID CIRCUIT HIGH
P1008-POWER STEERING CIRCUIT LOW
P1009-POWER STEERING CIRCUIT HIGH
P1012-MPA CIRCUIT LOW
P1013-MPA CIRCUIT HIGH
P1014-FUEL PUMP CIRCUIT LOW
P1015-FUEL PUMP CIRCUIT HIGH
P1016-CHARGE AIR TEMPERATURE CIRCUIT LOW
P1017-CHARGE AIR TEMPERATURE CIRCUIT HIGH
P1018-SERIAL DATA CIRCUIT
P1019-POWER LATCH NOT SET
P1021-ENGINE FAILED TO START DUE TO MECHANICAL, FUEL OR IGNITION CONDITIONS
P1022-STARTER RELAY CIRCUIT LOW
P1024-ECU START CIRCUIT LOW
P1025-WOT CIRCUIT LOW
P1026-WOT CIRCUIT HIGH
P1027-ECU SEES WIDE OPEN THROTTLE
P1028-ECU DOES NOT SEE WIDE OPEN THROTTLE
P1029-ISA CLOSED THROTTLE CIRCUIT LOW
P1030-ISA CLOSED THROTTLE CIRCUIT HIGH
P1031-ECU SEES CLOSED THROTTLE
P1032-ECU DOES NOT SEES CLOSED THROTTLE
P1033..36-ISA CIRCUIT
P1037-TP SENSOR CIRCUIT READS LOW
P1038-PARK/NEUTRAL LINE HIGH
P1039- PARK/NEUTRAL LINE LOW
P1040-LATCHED B+ LINE LOW
P1041-LATCHED B+ LINE HIGH
P1042-NO LATCHED B+ VOLT DROP
P1043-SHIFT LAMP CIRCUIT GROUNDED
P1044-D2-1 CIRCUIT LOW (A/T)
P1044-UPSHIFT LAMP CIRCUIT (M/T)
P1044-SHIFT LAMP CIRCUIT HIGH
P1045-SHIFT LAMP CIRCUIT OPEN
P1047-WRONG ECU
P1048-M/T VEHICLE CONFIGURATION
P1049-A/T VEHICLE CONFIGURATION
P1050-IDLE RPM LOW
P1051-IDLE RPM HIGH
P1052-MAP SENSOR OUT OF LIMITS
P1053-CHANGE IN MAP READING OUT OF LIMITS
P1054-COOLANT SENSOR & 5V SUPPLY FOR TP SENSOR /
MAP CIRCUIT LOW
P1055-COOLANT SENSOR CIRCUIT HIGH
P1065-INACTIVE COOLANT TEMPERATURE SENSOR
P1059-A/C REQUEST CIRCUIT LOW
P1060-A/C REQUEST CIRCUIT HIGH
P1061-A/C SELECT CIRCUIT LOW
P1062-A/C SELECT CIRCUIT HIGH
P1063-A/C CLUTCH CIRCUIT LOW
P1064-A/C CLUTCH CIRCUIT HIGH & POWER STEERING INPUT
P1065-RICH OXYGEN SENSOR INPUT
P1066-LEAN OXYGEN SENSOR INPUT
P1067-LATCH RELAY CIRCUIT LOW
P1068-LATCH RELAY CIRCUIT HIGH
P1069-NO TACH
P1074-ECU DOES NOT SEE SPEED SENSOR
P1106-MAP SENSOR CIRCUIT INTERMITTENT HIGH VOLTAGE
P1107-MAP SENSOR CIRCUIT INTERMITTENT LOW VOLTAGE
P1110-DECREASED ENGINE PERFORMANCE DUE TO HIGH
INTAKE AIR TEMPERATURE
P1111-IAT SENSOR CIRCUIT INTERMITTENT HIGH VOLTAGE
P1111-IAT SENSOR CIRCUIT INTERMITTENT LOW VOLTAGE
P1114-ECT SENSOR CIRCUIT INTERMITTENT LOW VOLTAGE
P1115-ECT SENSOR CIRCUIT INTERMITTENT HIGH VOLTAGE
P1121-TPS CIRCUIT INTERMITTENT HIGH VOLTAGE
P1122-TPS CIRCUIT INTERMITTENT HIGH VOLTAGE
P1125-ACCELERATOR PEDAL POSITION SYSTEM
P1133-HO2S INSUFFICIENT SWITCHING BANK 1 SENSOR 1
P1134-HO2S INSUFFICIENT TRANSITION TIME RATIO BANK 1 SENSOR 1
P1153-HO2S INSUFFICIENT SWITCHING BANK 2 SENSOR 1
P1154-HO2S INSUFFICIENT TRANSITION TIME RATIO BANK 2 SENSOR 1
P1180-DECREASED ENGINE PERFORMANCE DUE TO HIGH
P1191-INTAKE AIR DUCT LEAK
P1192-INLET AIR TEMP SENSOR VOLTAGE LOW
P1193-INLET AIR TEMP SENSOR VOLTAGE HIGH
P1194-O2 HEATER PERFORMANCE
P1195-O2 SENSOR 1/1 SLOW DURING CATALYST MONITOR
P1196-O2 SENSOR 2/1 SLOW DURING CATALYST MONITOR
P1197- O2 SENSOR 1/2 SLOW DURING CATALYST MONITOR
P1198-RADIATOR TEMPERATURE SENSOR VOLTS TOO HIGH
P1198-RADIATOR TEMPERATURE SENSOR VOLTS TOO LOW
P1214-INJECTION PUMP TIMING OFFSET
P1216-FUEL SOLENOID RESPONSE TIME TOO SHORT
P1217-FUEL SOLENOID RESPONSE TIME TOO LONG
P1218-INJECTION PUMP CALIBRATION CIRCUIT
P1271-ACCELERATOR PEDAL POSITION SENSOR 1-2
CORRELATION
P1272- ACCELERATOR PEDAL POSITION SENSOR 2-3
CORRELATION
P1273- ACCELERATOR PEDAL POSITION SENSOR 1-3
CORRELATION
P1275-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT
P1277-ACCELERATOR PEDAL POSITION SENSOR 1 LOW
VOLTAGE
P1278-ACCELERATOR PEDAL POSITION SENSOR 1 HIGH
VOLTAGE
P1280-ACCELRATOR PEDAL POSITION SENSOR 2 CIRCUIT
P1281-ENGINE IS COLD TOO LONG
P1282-FUEL PUMP/SYSTEM RELAY CONTROL CIRCUIT
P1282-ACCELERATOR PEDAL POSITION SENSOR 2 LOW
VOLTAGE
P1283-IDLE SELECT SIGNAL INVALID
P1283-ACCELERATOR PEDAL POSITION SENSOR 2 HIGH
VOLTAGE
P1284-FUEL INJECTION PUMP BATTERY VOLTAGE OUT OF
RANGE
P1285-FUEL INJECTION PUMP CONTROLLER ALWAYS ON
P1285-ACCELERATOR PEDAL POSITION SENSOR 3 CIRCUIT
P1286-ACCELERATOR POSITION SENSOR SUPPLY VOLTAGE
TOO HIGH
P1287-FUEL INJECTION PUMP CONTROL SUPPLY VOLTAGE
LOW
P1287-ACCELERATOR PEDAL POSITION SENSOR 3 LOW
VOLTAGE
P1288-INTAKE MANIFOLD SHORT RUNNER SOLENOID
CIRCUIT
P1288-ACCELERATOR PEDAL POSITION SENSOR 3 LOW
VOLTAGE
P1289-MANIFOLD TUNE VALVE SOLENOID CIRCUIT
P1290-CNG FUEL SYSTEM PRESSURE TOO HIGH
P1291-NO TEMP RISE SEEN FROM INTAKE HEATERS
P1292-CNG PRESSURE SENSOR VOLTAGE TOO HIGH
P1293-CNG PRESSURE SENSOR VOLTAGE TOO LOW
P1294-TARGET IDLE NOT REACHED
P1295-NO 5-VOLTS TO THROTTLE POSITION SENSOR
P1296-NO 5-VOLTS TO MAP SENSOR
P1297-NO CHANGE IN MAP FROM START TO RUN
P1298-LEAN OPERATION AT WIDE OPEN THROTTLE
P1299-VACUUM LEAK FOUND (IAC FULLY SEATED)
P1336-CRANKSHAFT POSITION SYSTEM VARIATION NOT
LEARNED
P1345-CRANKSHAFT POSITION/CAMSHAFT POSITION
CORRELATION
P1351-IGNITION CONTROL CIRCUIT HIGH VOLTAGE
P1361-IGNITION CONTROL CIRCUIT LOW VOLTAGE
P1380-ELECTRONIC BRAKE CONTROL ROUGH ROAD DATA
UNUSABLE
P1381-MISFIRE DETECTED-NO ELECTRONIC BRAKE
CONTROL DATA
P1388-AUTO SHUTDOWN RELAY CONTROL CIRCUIT
P1389-NO ASD RELAY OUTPUT VOLTAGE AT PCM
P1390-TIMING BELT SKIPPED 1 TOOTH OR MORE
P1391-INTERMITTENT LOSS OF CMP OR CKP
P1398-MIS-FIRE ADAPTIVE NUMERATOR AT LIMIT
P1399-WAIT TO START LAMP CIRCUIT
P1403-NO 5 VOLTS TO EGR SENSOR
P1404-EGR VALVE CLOSED PINTLE POSITION
P1406-EGR VALVE POSITION
P1409-EGR VALVE SYSTEM LEAK
P1415-AIR SYSTEM BANK 1
P1416-AIR SYSTEM BANK 1
P1441-EVAP EMISSION FLOW DURING NON-PURGE
P1475-AUXILIARY 5 VOLT SUPPLY VOLTAGE HIGH
P1476-TOO LITTLE SECONDARY AIR
P1477-TOO MUCH SECONDARY AIR
P1478-BATTERY TEMP SENSOR VOLTS OUT OF LIMITS
P1479-TRANSMISSION FAN RELAY CIRCUIT
P1480-PCV SOLENOID CIRCUIT
P1481-EATX MISFIRE RPM SIGNAL OUT OF RANGE
P1482-CATALYST TEMPERATURE SENSOR CIRCUIT SHORTED LOW
P1483-CATALYST TEMPERATURE SENSOR CIRCUIT SHORTED HIGH
P1484-CATALYTIC CONVERTER OVERHEAT DETECTION
P1485-AIR INJECTION SOLENOID CIRCUIT
P1486-EVAP LEAK MONITOR PINCHED HOSE FOUND
P1487-HIGH SPEED RADIATION FAN CTRL RELAY CIRCUIT
P1488-AUXILIARY 5 VOLT SUPPLY OUTPUT TOO LOW
P1489-HIGH SPEED FAN CTRL RELAY CIRCUIT
P1490-LOW SPEED FAN CTRL RELAY CIRCUIT
P1491-RADIATOR FAN CONTROL RELAY CIRCUIT
P1492-AMBIENT/BATTERY TEMPERATURE SENSOR VOLTAGE
TOO HIGH
P1493-AMBIENT/BATTERY TEMPERATURE SENSOR VOLTAGE
TOO LOW
P1494-LEAK DETECTION PUMP SWITCH OR MECHANICAL
FAULT
P1495-LEAK DETECTION PUMP SOLENOID CIRCUIT
P1496-5 VOLT SUPPLY, OUTPUT TOO LOW
P1498-HIGH SPEED RADIATOR FAN GROUND DTRL RELAY
CIRCUIT
P1508-IAC SYSTEM LOW RPM
P1509-IAC SYSTEM HIGH RPM
P1594-CHARGING SYSTEM VOLTAGE TOO HIGH
P1595-SPEED CONTROL SOLENOID CIRCUIT
P1596-SPEED CONTROL SWITCH ALWAYS HIGH
P1597-SPEED CONTROL SWITCH ALWAYS LOW
P1598-A/C PRESSURE SENSOR VOLTAGE TOO HIGH
P1599-A/C PRESSURE SENSOR VOLTAGE TOO LOW
P1602-PCM NOT PROGRAMMED
P1621-PCM MEMORY PERFORMANCE OR WRITE
P1626-VEHICLE THEFT SYSTEM CONTROL LOSS OF DATA
P1627-A/D PERFORMANCE
P1630-VEHICLE THEFT SYSTEM PCM IN LEARNING MODE
P1631-VEHICLE THEFT SYSTEM IMPROPER PASSWORD
P1635-5 VOLT REFERENCE (A) CIRCUIT
P1639-5 VOLT REFERENCE (B) CIRCUIT
P1641-MIL CONTROL CIRCUIT
P1643-WAIT TO START LAMP CONTROL CIRCUIT
P1646-5 VOLT REFERENCE (C) CIRCUIT
P1652-J1850 SHORT TO GROUND
P1653-EGR VENT SOLENOID CONTROL CIRCUIT
P1654-SERVICE THROTTLE SOON LAMP CONTROL CIRCUIT
P1655-EGR SOLENOID CONTROL CIRCUIT
P1656-WASTEGATE SOLENOID CONTROL CIRCUIT
P1680-CLUTCH RELEASED SWITCH CIRCUIT
P1681-NO I/P CLUSTER CCD/J1850 MESSAGES RECEIVED
P1682-CHARGING SYSTEM VOLTAGE TOO LOW
P1683-SPEED CONTROL POWER RELAY
P1683-S/C 12V DRIVER CKT
P1684-BATTERY DISCONNECTED IN THE LAST 50 STARTS
P1685-SKIM INVALID KEY
P1686-NO SKIM BUS MESSAGES RECEIVED
P1687-NO CLUSTER BUS MESSAGE
P1688-INTERNAL FUEL INJECTION PUMP CONTROLLER
FAILURE
P1689-NO COMM BETWEEN ECM & INJECTION PUMP MODULE
P1690-CKP SENSOR DOES NOT AGREE WITH ECM CKP
SENSOR
P1691-FUEL SYSTEM ESS RPM ERROR
P1692-DTC SET IN ECM
P1693-DTC CLEARED IN COMPANION JTEC MODULE
P1694-NO BUS MESSAGES RECEIVED FROM ECM MODULE
P1695-NO CCD/J1850 MESSAGE FROM BODY CONTROL
MODULE
P1696-PCM FAILURE EEPROM WRITE DENIED
P1697-EMR (SRI) MILEAGE NOT STORED
P1698-NO CCD/J1850 MESSAGE FROM TCM/PCM
P1719-SKIP SHIFT SOLENOID CIRCUIT
P1740-TCC OR O/D SOLENOID PERFORMANCE
P1756-GOV PRESS NOT EQUAL TO TARGET @ NOT 12-20 PSI
P1757-GOV PRESS ABOVE 3 PSI IN GEAR WITH 0 MPH
P1762-GOV PRESS SENSOR OFFSET VOLTS TOO LOW OR
HIGH
P1763-GOV PRESS SENSOR VOLTS TOO HIGH
P1764-GOV PRESS SENSOR VOLTS TOO LOW
P1765-TRANS 12V SUPPLY RELAY CTRL CIRCUIT
P1899-P/N SWITCH STUCK IN PARK OR IN GEAR
P2121-PEDAL POSITION SENSOR 1 CONFORMANCE ERROR
P2122-PEDAL POSITION SENSOR 1 VOLTAGE TOO LOW
P2123-PEDAL POSITION SENSOR 1 VOLTAGE TOO HIGH
P2127-PEDAL POSITION VALIDATION SWITCH 2 LOW
P2128-PEDAL POSITION VALIDATION SWITCH 2 LOW
P2146-FUEL INJECTOR GROUP 1 SUPPLY VOLTAGE CIRCUIT
P2147-FUEL INJECTOR GROUP 1 SUPPLY VOLTAGE LOW
P2148-FUEL INJECTOR GROUP 1 SUPPLY VOLTAGE HIGH
P2149-FUEL INJECTOR GROUP 2 SUPPLY VOLTAGE CIRCUIT
P2150-FUEL INJECTOR GROUP 2 SUPPLY VOLTAGE LOW
P2151-FUEL INJECTOR GROUP 2 SUPPLY VOLTAGE HIGH
P2266-WATER IN FUEL (WIF) SENSOR VOLTAGE TOO LOW
P2269-WATER IN FUEL (WIF)
P2502-CHARGING SYSTEM ERROR
P2503-CHARGING SYSTEM OUTPUT LOW
P2504-CHARGING SYSTEM OUTPUT HIGH
P2509-ECM/PCM POWER INPUT SIGNAL INTERMITTENT
P2607-LOW VOLTAGE AT THE #2 INTAKE AIR HEATER RELAY
P2608-HIGH VOLTAGE AT THE #2 INTAKE AIR HEATER RELAY
P2609-NO VOLTAGE DROP SEEN FROM INTAKE AIR HEAT
2006 4x4 qcsb, Leveld on 35s, Built Stage 4 BD Tranny, BD pulse manifold,4" mbrp exhaust,SB intake, BD steering box stabilizer, Auto meter pillar gauges,Smarty S06
tsilvscummins is offline
