Dodge Cummins Diesel Forum - View Single Post - Turbo Spec Compilation
post #3 of (permalink) Old 04-03-2013, 07:57 PM
jigabop
Western WA President
jigabop's Avatar
H1C and WH1C
8 blade compressors that can be either:
45mm, 52mm, 54mm, or 56mm inducers.
the turbine side is identical and wheels are interchangeable with the hx35. housings differ slightly by bolt count on the back.. 2 less bolts. Far less efficient turbos than the hx35 that replaced it, commonly found on first gen trucks.
the intercooled first gens had a larger compressor wheel than the non intercooled version.
dunno if you wanna add that to your list or not...
00 24v powered by the high performance "53" block and "Unicorn Injectors" 576hp/1285tq 8/10/2013
2004 Jetta TDI 5spd Malone S1 + dyn EGR/idle tune
Originally Posted by DieselDon16 View Post
my truck is literally full of Panties already...
Originally Posted by 'strokeThis_'07 View Post
I'll admit, I was sitting here giggling like a little girl
jigabop is offline
The Following User Says Thank You to jigabop For This Useful Post:
Capt. Slow (04-03-2013)
