Water Pump Replaced - Page 2 - Dodge Cummins Diesel Forum
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
post #13 of 18 (permalink) Old 06-08-2010, 04:06 PM Thread Starter
IL Chapter VP
Onelongshot's Avatar
Location: Columbia, Illinois ALSO KNOWN AS THE COMMUNIST STATE OF CHICAGO
Originally Posted by ku4ns View Post
My 6.7 is at the dealership since Thursday for a water leak (17,000 miles). I called Friday and they said it wasn't leaking so I told them to keep it over the weekend. Monday it had a few drops under it but they can't tell from where. The dealership is going to add some liquid that appears under UV light to try to pinpoint. Seems like a lot of work to get around changing the water pump. Small water puddle near the front of the oil pan on the passenger side. I'll post the final result. John
You sir have a water pump with bad seals in it. Tell them to run the truck until it gets good and hot. Then shut it off and they will find were it is coming from real fast.
Andy 2011 HO Ram 3/4 Crew Cab, Laramie, Short Bed, 4X4 Electronic T-Case, 68RFE, 3:73's, Snow Plow Prep, Line-X, Mopar Side Steps, Smarty Sr S67, Smarty Jr SJ67, Dodge_Made_It_Marco_Helps_Cummins_Shake_It.
Remember Elementary School "Cardboard Pizza and Tater Tots in the morning. The smell of Learning."
Onelongshot is offline
The Following User Says Thank You to Onelongshot For This Useful Post:
collin (06-01-2014)
post #14 of 18 (permalink) Old 06-08-2010, 07:33 PM
Second Most Important Member
TORK-STIK's Avatar
great post for instructions on the h2o pump change out!
2007.5 6.7L THANKS TO, DANS DIESEL PERFORMANCE-EFI [email protected]@GLACIER DIESEL POWER-RANDY ELLIS DESIGN-DON THUREN FABRICATION-POLY PERFORMANCE-S&B-H&S-BFG-GENERAL RED LETTERS-MHP-B&G-FLO PRO-AMSOIL-EDGE-RECON-GENOS GARAGE-HELL BENT STEEL-BILSTEIN
TORK-STIK is offline
post #15 of 18 (permalink) Old 06-08-2010, 07:44 PM Thread Starter
IL Chapter VP
Only if enough people say it helps.
JohnMurphyRN (12-21-2013)
post #16 of 18 (permalink) Old 06-08-2010, 10:24 PM
Gunner10605's Avatar
I just replaced mine at 101,000 past Saturday....wish I had seen this post first. I forced my hands down between the rubbery shroud and fan to reach the pump. I cut my arms and hands in 6 places trying to work that way......Mom always said I wasn't the brightest bulb in the box. Evidently I'm something like 40 watts.
2007.5 Quad Cab 4x4 6.7 AUTO 3.73-STOCK EXCEPT FOR 285/70 BFG A/T and S&B CAI.
Gunner10605 is offline
The Following User Says Thank You to Gunner10605 For This Useful Post:
Mudman1 (02-03-2013)
post #17 of 18 (permalink) Old 11-19-2011, 12:02 AM
CF Administrator
THE STIG's Avatar
iTrader Score: 6 reviews
Perfect. Found my problem and found this handy write up. Pump out at 85k on 07 6.7, Time to dig in.
Powerful - Reliable - Inexpensive. Pick any two at a time, the third is not included.
CUMMINSFORUM. Often imitated, never duplicated. The world's largest #1 resource for everything Cummins Turbo Diesel.
Need something? PM any moderator or report posts anonymously! We are here to help.
THE STIG is offline
post #18 of 18 (permalink) Old 11-18-2014, 12:43 PM
BlackDiesel
Guest
Posts: n/a
Yup, mine just went out last night. Might as well change the belt out while I'm there. 2012 with 57K
Great write-up!
