-12 offset with stock suspension - Dodge Cummins Diesel Forum
 5Likes
post #1 of 22 (permalink) Old 09-13-2019, 03:20 PM Thread Starter
I just bought a Ď19 ram 2500 and want to put 295/70/18 on the truck. I was looking at the 18x9 method mesh wheels with a -12 offset. Anyone running the same size tire with -12 offset wheels? Do they rub? I want to keep the truck stock but may have to level it.
bmutch is offline
post #2 of 22 (permalink) Old 09-13-2019, 07:16 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
https://www.cumminsforum.com/forum/5th-gen-tire-wheel/
2018 RAM 4500 Chassis Tradesman Crew Cab 60Ē C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Firestone FD690ís, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 196,704 miles and 3,437 hours as of January 27th, 2020 (Average Miles Per Hour = 57.2)
gsbrockman is offline
post #3 of 22 (permalink) Old 09-13-2019, 08:59 PM
mxsledder's Avatar
33’s would likely work but I’m almost certain 35’s would rub.
2010 Ram 2500cc sb mineral gray metallic, laramie. Lovin it !!
mxsledder is offline
post #4 of 22 (permalink) Old 09-14-2019, 11:30 AM
you would be better off with the +18 offset
just saying
USMC8511 likes this.
'18 3500 Mega Aisin, Carli suspended
í13 3500 CCLB Aisin, Carli suspended
'11 2500 Mega, Carli suspended
kylant is offline
post #5 of 22 (permalink) Old 09-17-2019, 12:27 PM
Stock wheels are like +44mm offset or close to that. So do the math.
Gain 1/2" track width due to the 1" wider wheel and about another 2-1/4" with the offset difference and a smidge with wider tires, so they'll stick out close to 4" further.
If you're ok with that then leter rip. Not brodozer wide, but a bit more than I'd like. Big fender flares will be on tap unless you're ok with slinging ____ all over the side of the truck and chipping the paint up.
For only 295 tires, I agree, I'd stick with more like a +18 offset.
07 5.9 Mega, G56, SB Single disk Ceramic clutch, OE 1 piece Al driveshaft, 60hp Industrial injectors, Triple dog, Glacier 2mic filter, BD exhaust brake, ATI Super Damper, BD steering brace, Firestone bags, Big Wig swaybar, 4th Gen 20s and some home made Stableloads.
Grit dog is online now
post #6 of 22 (permalink) Old 10-02-2019, 11:36 PM
I put a leveling kit on mine and used a 17” method and 0 offset on 37” it barley rubbed trimmed a little bit and now it doesn’t rub
2019RAMDREW is offline
post #7 of 22 (permalink) Old 10-02-2019, 11:41 PM
So the closer to zero and below the further it will stick out? What will keep it flush or just barely sticking out with a 295/70/18?
Nighthawk87 is offline
post #8 of 22 (permalink) Old 10-02-2019, 11:42 PM
Zackolas's Avatar
I currently have 295/70R18 on my stock truck on stock wheels with no rub at all with tons of clearance.
Zackolas is offline
post #9 of 22 (permalink) Old 10-03-2019, 09:33 AM
7492's Avatar
Looking good there. I don't like the tread sticking out, looks like crap.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is online now
post #10 of 22 (permalink) Old 10-03-2019, 07:05 PM
Zackolas's Avatar
Luckily mine don't stick out at all. They aren't even flush with the fender flares.
Zackolas is offline
post #11 of 22 (permalink) Old 11-05-2019, 01:29 PM
could you post a pic showing the side view? thanks in advance.
2019 2500 Limited, bone stock
johnnyroastbeef is offline
post #12 of 22 (permalink) Old 11-14-2019, 07:11 PM
USMC8511's Avatar
285/75r18 on stock wheels, no rubbing. -12 will stick out...a lot.
Pearl White, 19 Ram 3500 CC LWB Laramie Longhorn 4X4-because it's a truck, Bone Stock 6.7 HO, AISIN, 5th Wheel/GN Prep, Thuren 1.75" coils and Fox 2.0 all around, Duratrac 285/75r18
USMC8511 is offline
The Following User Says Thank You to USMC8511 For This Useful Post:
johnnyroastbeef (01-28-2020)
