Factory 20s With Spacers - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 07-04-2019, 12:24 PM Thread Starter
I just got a 2019 2500 Mega cab Laramie. It has the stock 20x8 wheels and I wanted to get a little better stance. I like the look of the wheels, and I was thinking about putting some spacers on. I also plan to put on some 35x12.50s when I do it. I just don't know much about spacers.
What size can I use? I'd like to go 1.5 to 2"
Do I need to trim wheel studs? I hope not.
Lug Centric or hub centric?
2019 2500 Mega Laramie 4x4- Mostly stock... for now.
Sold:2013 3500 SRW Mega Laramie 4x4, Fully deleted and tuned and 2001 QCLB 2500 4x4
dblack21 is offline
post #2 of 4 (permalink) Old 07-04-2019, 12:57 PM
battlerattle's Avatar
2" is a common size and at that width you wont need to trim lugs. Your factory wheels are actually both hub and lug centric. I would order a set of spacers that are machined to be hub centric. That way you keep both. Quality bolt on spacers are fine as long as you are not towing heavy with them.
2016 2500 Laramie Longhorn 4wd CTD crewcab Granite Crystal Metalic, 2" Pure Performance triple rate leveling springs, Adjustable front Trackbar, Stealth Module
battlerattle is offline
post #3 of 4 (permalink) Old 07-05-2019, 09:30 PM
bigskyhntr's Avatar
I've used these on prior trucks without issue, they are the best!!
Wheel Adapters, Wheel Spacers, Hub Rings for your car! | Motorsport Tech
2016 Laramie CTD 2500 CC 4x4 2.75" Thuren w/ Kings 35" Toyo RT's on Method NV
2015 Laramie CTD 2500 CC 4x4 ALRS,(traded)
2014 Laramie Power Wagon 6.4 Hemi 35" Toyo R/T(traded)
bigskyhntr is offline
post #4 of 4 (permalink) Old 07-14-2019, 12:28 PM
racerryan's Avatar
If you go with 2” spacers you will have to trim the pinch weld with a 35x12.5. I personally would not put a 12.5 on a 8” wheel.
Better would be a 295/65r20 which is taller then a 35” and still around 11.75” wide. A 35x11.5” would also work well. The metric size will have a higher load capacity but smaller tread depth.
racerryan is offline
