4500 vs 5500 - Dodge Cummins Diesel Forum
 2Likes
post #1 of 27 (permalink) Old 11-30-2019, 10:32 AM Thread Starter
4500 vs 5500
2019/2020 Is the only difference between 4500 and 5500 the rear spring pack ? I see on a 4500 you can get 4.10 rear end where 5500 you cannot.
Any ride quality difference between the two. Have driven a 5500 and yes it rides like a rock unloaded. Is the 4500 the same.
'12 ram 3500 dually. H&S mini max mcc tuned
turbo247 is offline
post #2 of 27 (permalink) Old 11-30-2019, 02:18 PM
4500 vs 5500
You can get 4.89 on the rear of a 5500. Maybe the 4.10 gears are stock for a 5500. I ordered mine with 4.89.
abishoff is online now
post #3 of 27 (permalink) Old 11-30-2019, 05:50 PM Thread Starter
With 4.89 what are you rpm wise at 65. Or do you not have your truck yet
turbo247 is offline
post #4 of 27 (permalink) Old 12-01-2019, 10:35 AM
I donít have the truck yet. It doesnít arrive until end of January
post #5 of 27 (permalink) Old 12-01-2019, 11:16 AM
Duelly Dad's Avatar
I would bet with 19.5 rims the 4.89 gears will run like 4.10 gears in 17s or pretty darn close.
3500 MegaCab Dually 4X4
6.7L Aisin Trans
4:10 Gears
385 Hp 930 Tq
Duelly Dad is offline
post #6 of 27 (permalink) Old 12-01-2019, 04:03 PM Thread Starter
The 19.5 tire height is almost identical to stock 17Ē tire height
turbo247 is offline
post #7 of 27 (permalink) Old 12-01-2019, 06:28 PM
I went with those gears because I plan to lift the truck and run 40-44Ē tires
post #8 of 27 (permalink) Old 12-02-2019, 01:07 AM
Bedlam's Avatar
The stock tires are 31" tall. The 5500 has a rear stabilizer bar and the 4500 does not.
Bedlam is offline
post #9 of 27 (permalink) Old 12-07-2019, 02:16 PM Thread Starter
My local dealer had a 4500 and 5500. 4500 had 10 leaf pack. 5500 had 11
Both had rear stabilizers. The 4500 just wasnít as big in diameter
turbo247 is offline
post #10 of 27 (permalink) Old 12-07-2019, 02:25 PM
Bedlam's Avatar
That has changed since my 2015. Thanks for the update.
Bedlam is offline
post #11 of 27 (permalink) Old 12-08-2019, 11:34 AM Thread Starter
Iím just looking to see all the differences on paper I want 5500 but truck will be unloaded or light loaded a lot to so want to see if 4500 ride quality is better
turbo247 is offline
post #12 of 27 (permalink) Old 12-08-2019, 11:53 AM
Jimmy N.'s Avatar
With a lower GVWR (I'm guessing) and one less leaf in the spring pack, a 4500 has to ride better.
Not good, but better.
Then again, a 5500 with correct tire pressure for running empty will most likely ride better than a 4500 with a higher pressure.
Jimmy N. is online now
