Dodge Cummins Diesel Forum - View Single Post - P2149 resolution
post #10 of (permalink) Old 05-21-2012, 09:45 AM
StealthDiesel
StealthDiesel's Avatar
Here is some PD info on P2149:
Case Number K30540141
Vehicle Issue MIL and the engine runs rough. P2146 or P2149 are logged.;No wiring problems such as a chafed or shorted wire are found per P2146 / P2149 diagnostics.
System or Component Engine Misfire,Rough / Unstable / Erratic Idle,Lack of Power / Sluggish;DTC / Error Message;Yes - Continuously
Recommendation One at a time, disconnect both wires from each injector and insulate the terminal ends so the circuit will not short to ground on the effected bank (1-3 for P2146 or 4-6 for P2149).
Clear the codes and start the engine, check if the same code resets. If an injector is disconnected and the code does not reset, replace that injector.
2004.5 Dodge SB QC 2500 2wd Cummins 600/6spd manual/3.73 LSD
ATS 3K/5K Twin turbos. DDP 50HP tips, F1 valve springs, ARP headstuds.
SBC Dual disk 3250. Smarty. Glacier Diesel intake plate, air horn, fuel & filter system.
MBRP S.S. muffler. BD short shifter. Brakesmart tow controller.
BD exhaust brake. Pullrite 24k Superglide.
StealthDiesel is offline
The Following User Says Thank You to StealthDiesel For This Useful Post:
Taquache (05-21-2012)
