3" lifts and 37" tires, please post pics - Page 95 - Dodge Cummins Diesel Forum
4wd Suspension 4wd Suspension Systems, Shocks, Springs, and More!....NO ADVERTISING!
 248Likes
post #1129 of 1138 (permalink) Old 02-20-2019, 07:10 PM
Dan @ Carli
OCVeloMan's Avatar
Originally Posted by TheDude724 View Post
Looks killer
How rowdy did you have to trim to fit those 38s?
Also how wide are they?
I haven't cycled the 38s yet. I'll get time one of these days. Running the Carli long arms means 4.5" backspace wheels so I trimmed for 37s and this barely rubs so far but will definitely need more.
Originally Posted by Galawcum View Post
My goodness how do you fit 38's no rub with only a 3inch lift? So around 2k is normal gearing price turnkey?
You trim the hell out of it, lol. I am running 38x13.5 tires with 4.56 gears and turn 2K at 70mph almost exactly.
- Carli Suspension 3" Long Arm Dominator - Torsion Sway Bar - Full Leaf Springs - Ball Joints - Axle Truss | TaterBuilt 62/65 341 | Smarty S06 | Randy's Transmissions Stage 2 | Isspro Performax EGT-Trans-Fuel-Boost | FASS 165 | S&B Intake & Horn | AMP | Redneck Rams Hydro Assist | Ballistic Fab Diff Covers
OCVeloMan is offline
post #1130 of 1138 (permalink) Old 04-11-2019, 02:53 PM
GloNDark's Avatar
Got my wheels and tires mounted this morning at work on my old hoopty.
Walker Evans 501 street 17x8.5 +1 offset
Toyo 37x13.50R17
Suspension: Thuren 3 coils, carli track bar, carli high clearance short arms, carli BJs, 08.5 steering, carli diff guard, carli steering stab, carli full leaf springs, Thuren shackles, extended brake lines from CJC, Thuren overland shocks for now...
How do you like the Thuren overland shocks?
I'm going to remove the 5" rough country lift off my mega and go back down to a 3" lift. I'm really considering the overland system. It's not as wild as my old Quad cab with the Carli Pin top setup but looks like it will handle the type of offroading i'm doing easily.
2006 Dodge 2500 Megacab - 5" exhaust, S&B intake, EFI live, 5" lift, 22x11 Fuels
GloNDark is offline
post #1131 of 1138 (permalink) Old 04-11-2019, 03:57 PM
CrawlerJamie's Avatar
Oh how I regret selling this truck.
37s with 1 front level
Get some
CrawlerJamie is offline
post #1132 of 1138 (permalink) Old 04-11-2019, 06:26 PM
GlowNdark, how long have you had the rough country lift on and for a daily that only goes off road to boat ramps would you recommend it?
20003 lwb 2500 smarty touch, K/N, 4inch exh, and 1pc driveshaft
Galawcum is offline
post #1133 of 1138 (permalink) Old 04-12-2019, 10:53 AM
GloNDark's Avatar
I bought this Megacab with the Rough country lift already on it. I had a quad cab with a full Carli pintop kit and 37x12.50r17's on it so there is no comparison in the ride department.
For an inexpensive lift, it rides decent. I'm sure it's going to ride better once I get rid of the 35"s on 22"s that it currently has on it.
GloNDark is offline
post #1134 of 1138 (permalink) Old 04-12-2019, 12:17 PM
Toyo 37x13.50R17
Suspension: Thuren 3” coils, carli track bar, carli high clearance short arms, carli BJs, 08.5 steering, carli diff guard, carli steering stab, carli full leaf springs, Thuren shackles, extended brake lines from CJC, Thuren overland shocks for now...
I have the 3” overland shocks and springs, control arms, end links and shackles all the way up with Toyo A/T 35/12.5/17. The ride is INCREDIBLE over stock - solid and soft. I am very pleased with the set up
ID:	845389   Click image for larger version
Michaelalan0331 is offline
post #1135 of 1138 (permalink) Old 04-12-2019, 12:20 PM
Good deal, yea I can't justify the Carli lift for what my truck is used for. And the only time it sees dirt is when I put the boat in at an old lake stuck in the cow pasture so I want more lift.
Galawcum is offline
post #1136 of 1138 (permalink) Old 04-12-2019, 12:54 PM
GloNDark's Avatar
Compared to a stock truck, mine rides stiffer but i'm 100% sure that is due to the tires/wheels on it. If I had some more sidewall I would be it rides as good as a stock truck. It's just taller.
GloNDark is offline
post #1137 of 1138 (permalink) Old 04-12-2019, 12:55 PM
GloNDark's Avatar
Originally Posted by Michaelalan0331 View Post
I have the 3 overland shocks and springs, control arms, end links and shackles all the way up with Toyo A/T 35/12.5/17. The ride is INCREDIBLE over stock - solid and soft. I am very pleased with the set up
Awesome, thanks man! I'm thinking the Overland setup with shackles, control arms and end links is the way i'm going to go to bring my truck back down a bit. And then later on I can add Fox or King shocks if I feel like I need it.
GloNDark is offline
post #1138 of 1138 (permalink) Old 04-12-2019, 09:02 PM
flynfry's Avatar
gotta say the 3" overland kit with their ca's, trackbar, lt leafs/shackles and those infamous white shocks is a very very nice ride. should mention no sway bar.
06 qcsb 4x4. mpi oe/475, hts, suncoast, gdp, smarty, thuren
flynfry is offline
