Replacement Shock While Waiting For Carli King Repair? - Dodge Cummins Diesel Forum
4wd Suspension 4wd Suspension Systems, Shocks, Springs, and More!....NO ADVERTISING!
 4Likes
  • 1 Post By G. Mcpherson
  • 2 Post By Bad V2
  • 1 Post By 2500/6
post #1 of 4 (permalink) Old 08-19-2019, 05:21 PM Thread Starter
I have a 2.5 Carli King that leaks from the fitting that goes from the shock body to the reservoir hose.
It leaked when new,but I tightened the fitting it appeared to fix the issue but 4 months later I see that it has been leaking.
The turn around from King is a month,so I need a replacement shock.
I have a 1" Thuren coil lift,but I may go to a Carli 2.5 coil in the future.I am thinking of getting a Bilstein to run while waiting for the shock to be repaired,I am not sure of the best length to buy.
Will the longer shock compress enough to fit the truck at the current height?
Or,should I buy the shorter shock and use a shock extension if and when I go to a higher lift?
Bilstein 24-251754 Shock Absorber Front Lifted Height: 2-2.5"
or
Bilstein 24-239455 Shock Absorber 0-1"Front Lifted Height
14 2500/68rfe 4X4 CC SWB Tradesman 315/70/18 Toyo MT's
ARE DCU
2500/6 is offline
post #2 of 4 (permalink) Old 08-19-2019, 07:53 PM
G. Mcpherson's Avatar
Call Thuren and they have the Spec number for Bilstein shock for the Application. It is Spec'd for their Travel Length. I believe this is it. 24-185776 for the Front Shock.
2500/6 likes this.
2018 Ram Big Horn. Crew Cab Short Box. 6.7Ltr. 68 RFE. Thuren Suspension
G. Mcpherson is offline
post #3 of 4 (permalink) Old 08-19-2019, 08:02 PM
Bad V2's Avatar
Just buy a pair of Thuren's Overland shocks for your temporaries. They work with his coils. They can also work with Carli 2.5 lift springs in the future. They are cheap enough and good enough until your King shock gets fixed. I ran used Overlands while waiting for my Kings and they were fine.
Then you have back-up shocks for the future, if ever needed.
2500/6 and G. Mcpherson like this.
2006 4x4 QCSB 2500 Laramie 5.9 Auto - Thuren equipped - Toyo R/T 37s
Bad V2 is offline
post #4 of 4 (permalink) Old 09-27-2019, 12:32 AM Thread Starter
FWIW,I got my shock back from King today.
I think I will do it myself next time.
Bad V2 likes this.
ARE DCU
2500/6 is offline
