Tire Pressure Question - Dodge Cummins Diesel Forum
4th Gen Tire and wheel Discussion of tire and wheel options
 29Likes
post #1 of 19 (permalink) Old 07-18-2019, 09:51 PM Thread Starter
wisdom_cody's Avatar
First post on the forum.
I'm looking for some opinions on tire pressure. I'm currently running Toyo M/T 35x12.50x22 with 22" AF wheels, and am curious what everyone's opinion on is the ideal tire pressure as far as ride quality is concerned. I also have a 4" SuperLift with their upgraded radius arms and Bilstein shocks front and back. I have the tires set at 55 PSI right now.
I used the search feature and couldn't find anything pertaining to these specs, so feel free to post a link to it and criticize me for not finding it on my own!
2016 6.7 {EFI Live 3 Stage} {Full Delete} {4" Straight Pipe} {4" Superlift Suspension Lift} {22x12 AF SS8}
wisdom_cody is offline
The Following User Says Thank You to wisdom_cody For This Useful Post:
dsol (07-20-2019)
post #2 of 19 (permalink) Old 07-18-2019, 10:06 PM
Jimmy N.'s Avatar
If ride quality is your only criterion, then as little pressure as possible (while still keeping the beads seated) would be the answer.
For real life use, look up a load chart. You will need to know your axle weights, though, and keep in mind that the charts are for a full load, just like the door sticker for the stock setup, which is generally too much.
Jimmy N. is online now
post #3 of 19 (permalink) Old 07-18-2019, 10:10 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Try 45-50 front and 35-40 rear unloaded. TPMS light will come on but ride will be better
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
The Following User Says Thank You to 98whitelightnin For This Useful Post:
wisdom_cody (07-20-2019)
post #4 of 19 (permalink) Old 07-18-2019, 11:16 PM
TPMS adjustment guy
4x4x4door's Avatar
iTrader Score: 4 reviews
2 words ... chalk test. There a couple great videos on YouTube. If you can't live with the lights and warnings, shoot me a PM for details on how to change the TPMS settings.
Gr8bawana likes this.
TPMS Adjusted..
Speedo adjusted and fogs w/high beams enabled..
Thuren suspension w/Kings, MM3, Airlift bags, 18x9 Warriors w/35" Atturo Trail Blades
2011 CCSB 2500 SLT 4x4 Auto w/150k miles-SOLD!
4x4x4door is offline
The Following User Says Thank You to 4x4x4door For This Useful Post:
post #5 of 19 (permalink) Old 07-18-2019, 11:22 PM
Rhinopkc's Avatar
Weigh your truck, consult the chart. Itís very easy. https://www.toyotires.com/media/2125...s_20170203.pdf
Cummins0867, Lins and Jimmy N. like this.
Give Us a Call for All Your Suspension, Lighting, and Wheel Needs!
424.241.3252 x700
Rhinopkc is offline
post #6 of 19 (permalink) Old 07-19-2019, 10:58 AM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
M/Tís and 35ís, coupled with 22x12Ē wheels, when stirred together, may just be mutually exclusive for a good ride......
2018 RAM 4500 Chassis Tradesman Crew Cab 60Ē C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDRís, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 150,076 miles and 2,654 hours as of July 12, 2019 (Average Miles Per Hour = 56.5)
gsbrockman is online now
post #7 of 19 (permalink) Old 07-19-2019, 11:10 AM
tsconver's Avatar
12.5 in tire on a 12 in wide rim? That tire is designed for a 8 in wide rim or there abouts. Load will be greatly reduced in a rim that wide and it will look just stupid.
73 K4CTD
2018 2500 QC SB Laramie - stock for now
2005 2500 QC SB, Rebuilt at 330K miles, Sold
tsconver is offline
post #8 of 19 (permalink) Old 07-19-2019, 11:16 AM
Jimmy N.'s Avatar
For whatever reason, that seems to be the goal sometimes.
post #9 of 19 (permalink) Old 07-19-2019, 01:24 PM
6401nohl's Avatar
My neighbor has a set. Those tires are made for a 8" to 10" wheel I believe. He's got them on 10's, and I give him good natured grief about them all the time.... They look (imho) too wide on 10's. Can't imagine how you'd ever even get the bead seated on a 10 ply (E) with a 12" wheel. Even when it's done, running low air pressure with the bead spread that far, is just playing with fire. I know we see it all the time, but it still surprises me that tire/wheel shops will mount tires on wheels that are not spec'd to take them. But the wide wheel/narrow tire thing seems to still be very popular. To each their own.
gsbrockman, Jimmy N. and Gr8bawana like this.
2014 Granite Crystal Metallic 3500 - 6.7, 4x4, CC, SRW, 3:42, 68RFE, LB, Tradesman -130k miles and going
2005 White 2500 - 5.9 HO, 4x2, CC, SRW, 3:42, 48RE, LB, SLT - 200,000 miles and going.
6401nohl is offline
post #10 of 19 (permalink) Old 07-19-2019, 07:43 PM
Jimmy N.'s Avatar
If you use starting fluid you can. If you use a lot of starting fluid, and inhaling a bunch of it, the result may even look good to you.
I may have to try that. I like the smell of ether.
post #11 of 19 (permalink) Old 07-19-2019, 08:22 PM
Seen a stretched rim truck yesterday. Canít imagine why anyone would want to do that to a vehicle. Horrible look.
And 22Ē rims too boot donít help. The smaller the sidewall the worse the ride comfort wise. And donít like the looks of 22Ē on a truck.
Aburdett is offline
post #12 of 19 (permalink) Old 07-19-2019, 10:03 PM
Rhinopkc's Avatar
Originally Posted by Aburdett View Post
Seen a stretched rim truck yesterday. Canít imagine why anyone would want to do that to a vehicle..
Easy, driving around with your moose mirrors engaged is only entertaining for so long.
Jimmy N. likes this.
424.241.3252 x700
Rhinopkc is offline
