raceMe tuner questions - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 03-02-2014, 09:59 PM Thread Starter
dnguillory's Avatar
Guys,
for best mileage while towing, should I use sw-2 towing and if so, timing 1, 2, 3, 4, or default? would like to have a setting that gives best mpg for towing and not towing. thanks
David Guillory, 2012 mega/dually 4x4 6.7/6sp auto stock. RaceMe Jr, DPF/egr deletes, 175k miles. Bought used at 42k miles.
dnguillory is offline
post #2 of 22 (permalink) Old 03-03-2014, 02:19 PM
vb712's Avatar
Depends on how heavy you tow. I would do either sw2 or even sw1 if you tow heavy. Always run the default timing on any raceme tune you use.
'12 Mineral Grey HO CCSB, Deleted. Studded. EFI Live by Anarchy 13 sec club 💨
vb712 is offline
post #3 of 22 (permalink) Old 03-03-2014, 03:39 PM
Rollin Smoke Diesel's Avatar
iTrader Score: 20 reviews
Like vb712 said keep the timing on default. The power setting you can run depends. Are you using a EGT gauge? The power setting will depend on what the load is you are towing.
James
RSD
2016 Cummins, Stainless 468/480 compounds, RevMax 850, member of the 1K club
Rollin Smoke Diesel is offline
The Following User Says Thank You to Rollin Smoke Diesel For This Useful Post:
vb712 (03-04-2014)
post #4 of 22 (permalink) Old 03-03-2014, 03:51 PM Thread Starter
dnguillory's Avatar
I never tow more than 15,500lbs. I do not have an egt gauge. I do monitor tranny. has not been an issue. should I be looking at egt's with that max weight? thanks guys
post #5 of 22 (permalink) Old 03-03-2014, 04:02 PM Thread Starter
dnguillory's Avatar
typically tow between 8500-10000lbs.
post #6 of 22 (permalink) Old 03-03-2014, 04:10 PM
Default timing on is the odd numbers correct?
Pete 2012 RAM 3500 MEGA DRW RaceMe Pro /Flo Pro/ HID/5100 Bilstein/1.5 TopGunz/265/70/17 Nitto G2/
www.whipsandlifts.com
Mooringproduct is offline
post #7 of 22 (permalink) Old 03-03-2014, 09:35 PM
To use the default timing level on any software level you simply press 0 in the Injection Timing screen.
James
RSD
post #8 of 22 (permalink) Old 03-03-2014, 09:37 PM
It wouldn't hurt to monitor EGT's. I am always a big fan of a EGT gauge (or monitor) if towing or running higher hp levels.
James
RSD
vb712 (03-04-2014)
post #9 of 22 (permalink) Old 03-04-2014, 04:34 PM
James
RSD
Im confused. Im using the RaceMe pro. I thought the odd numbers were with timing added and the even number with no timing added.
Am I not reading or understanding this correctly?
post #10 of 22 (permalink) Old 03-04-2014, 05:09 PM
You are correct. The odd numbers have additional timing predetermined by the manufacturer and the even have no timing which is great for stacking a module with the tuner. You can still adjust timing to your liking on any setting.
James
RSD
post #11 of 22 (permalink) Old 03-04-2014, 07:25 PM
vb712's Avatar
Always a good idea when tuned and towing to monitor EGT's.
vb712 is offline
post #12 of 22 (permalink) Old 06-18-2014, 01:42 PM Thread Starter
dnguillory's Avatar
so why default timing instead of 2? it seems that my truck runs smoother, not necessarily better mpg, but smoother than on default as if they were different. any insight is appreciated. thanks
The Following User Says Thank You to dnguillory For This Useful Post:
ducks an diesels (08-04-2014)
