'12 C&C Injector stuck open? - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 02-16-2014, 01:43 PM Thread Starter
Gacklex2552's Avatar
Exclamation '12 C&C Injector stuck open?
One of our work trucks started knocking this morning, like an injector is stuck open. Even at idle. The knock sounds like its on only one cylinder. And it smells like unburnt fuel with about a 16" flame coming out of the exhaust. Truck is bone stock with 128k on it. Our cheap Mac scanner came up with the following codes...
P206E: Reductant Heater B control performance
P0087: Rail Pressure too low
P214D: Description Unavailable
P2201: NOX sensor circuit bank 1
P0116: ECT Circuit range
No injector codes like i thought it would have. Just figured i would get some opinions on here before i dive into it any further since I haven't worked on these 6.7's at all yet. And i cant find Mopar descriptions on the web for the codes with letters... Thank you in advance.
04.5 64/s480. Dual cp3s. Exergy 100% overs. Hamilton springs. On 3 Perf I/C. Fass. ARPs. Custom Traction Bars. Full Billet 48re & PCS controller swap. UDC by Mike @ ATP
Gacklex2552 is offline
post #2 of 3 (permalink) Old 02-17-2014, 12:54 AM
#40Fan's Avatar
P214D: SCR NOx CATALYST OUTLET TEMPERATURE TOO HIGH DURING PARTICULATE FILTER REGENERATION
2011 2500 CC ST G56 LB MM 5" Flo-Pro 463
#40Fan is offline
post #3 of 3 (permalink) Old 02-17-2014, 10:12 AM Thread Starter
Thank you. So I'm assuming its an injector issue that has caused this
