Fuel Filter Question - Page 2 - Dodge Cummins Diesel Forum
post #13 of 23 (permalink) Old 01-23-2014, 08:32 PM
Wxguru's Avatar
I buy mine from Mid-South Cummins here in Central Arkansas. Runs about $42 for the Fleetguard. Guy at the counter thought it was the entire assembly for that price until he pulled it. His comment when he opened it to look and check it "that is a damn rip off".
Wxguru is offline
post #14 of 23 (permalink) Old 01-23-2014, 08:33 PM
Lol 47 and 57 for a filter. Geez. My dealer wants 149!!!!!
2012 2500 CC, 6'' BDS Long Arm, Fox Shocks, 20'' Feul Hostage Chrome, 37x12.50 Nitto Trails, EGR, Throttle Valve Delete, 4'' TBE AFE Exhaust H&S MiniMax, with Overdrive, 20'' LED Bar between tow hooks HID fogs, matching tint.
liquidoxygen is offline
post #15 of 23 (permalink) Old 08-03-2014, 07:14 PM
dundonrl's Avatar
it is a rip-off.. Cummins/fleetguard makes them for probably a buck each (parts and labor) and sells them for close to 50..
FC1(SW) US Navy Retired
2012 Ram 2500 ST CCSB 4x4, G56, 3.73's, Toyo M-55s, Warn 9.5ti multi mount winch and limited slip, with 3487 lbs drawbar capacity. Built Oct 22 [email protected] engine built Oct 9 2012.
dundonrl is offline
post #16 of 23 (permalink) Old 08-03-2014, 08:29 PM
To the OP, doesn't the '12 have 2 filters like the 13-14?
______________________________________________
2014 Ram 3500 6.7 CC LB 4X4 Tradesman 68RFE 5th wheel prep, snow plow prep, Fumoto, Wolo Big Bad Max
RA1 to RA2 upgrade with backup cam, HP F310 DVR
It's just a little 6 cylinder...
Big_Iz is offline
post #17 of 23 (permalink) Old 08-03-2014, 09:22 PM
Go Packers
camperman's Avatar
No, the 2012's have only one fuel filter, that is under the hood. Fleetguard FS43255 or the upgraded fuel filter FS53000.
2012 SLT 3500, CCLB, HO, SRW 4x2, 4.10s, 68RFE, Mineral Grey, Pacbrake air springs, Fumoto oil valve, Cat/Cummins Dual Filter kit, Edge CTS Monitor.
camperman is offline
post #18 of 23 (permalink) Old 08-03-2014, 09:25 PM
Dangit
So if the 12's have a single filter and are surviving, why is it that we don't have a longer change interval for the engine mounted filter -- say 2:1 to the rear frame filter?
Big_Iz is offline
post #19 of 23 (permalink) Old 08-03-2014, 09:36 PM
Go Packers
camperman's Avatar
^^^, If I had to speculate, the reason is that the rear fuel filter catches more, sooner, and the front filter stays cleaner from what I've read. NOT that I know first hand thou. I change yearly, due to not seeing 15,000 miles per year. At any rate, cheap insurance changing a fuel filter or 2, for what these trucks cost. Preventative maintenance is 100% better than a trip to the dealer for an issue, IMO.
post #20 of 23 (permalink) Old 08-03-2014, 09:49 PM
No worries on my part changing both at the intervals, although logic would seem to indicate that the first filter (rear frame) would catch most of the crap and the second (engine mount), unless a finer micron level, would be more-or-less a second line of defense.
Big_Iz is offline
post #21 of 23 (permalink) Old 08-05-2014, 06:35 PM
jlb27537's Avatar
The new 5/3 micron fuel filter for a '13/14 will fit a '12 and is available on Ebay for $42 with free freight.
Mopar 68157291AA Fuel Filter | eBay
Jim
2012 3500 DRW Laramie, Tow Max, 3.73, B&W Companion. Usually towing a 14.9K RV 5th wheel
jlb27537 is offline
post #22 of 23 (permalink) Old 08-13-2014, 12:20 AM
djbatt's Avatar
I use Baldwin fuel filters. Great filter (5 micron ) with a great price $42. Part number ph9870 for the 2011 model. Mopar filters are 7 micron and do not meet cummins specs and wix (napa) are 12 micron rated. Junk
djbatt is offline
post #23 of 23 (permalink) Old 08-13-2014, 12:34 AM
07white6.7's Avatar
It's probably different for the newer trucks, but for the 07.5-10 6.7s the napa gold/wix filter p/n 3733 is a 5 micron glass media filter. Not sure if this one will fit a 2010-2012 truck though.
07.5 3500 DRW, 6.7CTD, XRT Pro w/od tune, H&S Deletes, AFE TBE w Black MBRP Tip, AFE Intake, Torklift Superhitch 17k
07white6.7 is offline
