Adding 2nd alternator to 2500? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 06-28-2013, 03:00 AM Thread Starter
So Im starting my stereo build and need to add a second alternator.
I currently have the 220A alt and am going to have another hi output mechman built.
I know that the 3500s have an option for two alternators, would it be as simple as getting the bracket and additional belt? Hopefully? I need 450+ amps to safely power my planned system. I already ordered new batteries for under the hood, and i have batteries left over from my stereo build from my 1500 so once the alt issue is figured out itll be time to start fiberglassin and wiring up!
2014 3500 Limited Mega DRW l Aisin l 4.10s l dual alts l lots of other fun stuff and mods to come
JLuck13 is offline
post #2 of 12 (permalink) Old 06-28-2013, 11:11 AM
phobos512's Avatar
450 amps? Holy crap...Specs of your system?
phobos512 is offline
post #3 of 12 (permalink) Old 06-28-2013, 04:25 PM Thread Starter
450 is soft. Id really like 500 but i dont see that happening without a 3rd Alt. Let me just say this that I am a die hard audio guy, so im going to be spending more on my audio than most people will on their lift. And I want to get the stereo in before i lift it because lifting a box in and out of a truck with an 8" lift is no fun.
Subs - DC Audio 15" XLm2s (2200 RMS)
A Pillor - RF T142 (2 way full range)
Front door - RF T2652-S ( 2 way full range)
Back door - RF PPS4-6 (6" midrange)
Back door - RF T2652-S (2 way full range)
Amps
DC Audio 5K @ 1Ohm
RF 400-4 (Front)
RF T600-4 (Rear)
Thats 6K total watts. I would like 500A and a battery bank but i think im going to settle for in the 450A MAYBE i can talk mechman into building me a 270A to make for a total of 490A.
Thats the stereo plan at least lol
JLuck13 is offline
post #4 of 12 (permalink) Old 06-28-2013, 05:19 PM
Bigblackctd's Avatar
Any plans for the head unit?
2011 CCSB 4x4 Auto
Thuren/Carli Suspended sitting on 37" Coopers
Bigblackctd is offline
post #5 of 12 (permalink) Old 06-28-2013, 07:15 PM Thread Starter
Yes a Kenwood DNN990HD.
Will also have 2 XS Power D2700 for under the hood batteries and 4 D3000 in a battery bank under the truck. Using XS Flex CCA 1/0 for the "big 3" and all power ground wires and ToolMakers MetalWorkz dual 1/0 to 1/0 and 1/0 to 4 input adapters.
RF premium RCAs for all three amps with RF fuse holders
RF 12g speaker wire for mids and components
XS Flex 4g wire to the subs
Using an SMD-DD1 and SMD-CC1 to set it all up all the gains and crossovers
Also the truck is already 90% covered in a ton of Second Skin products. Damplifier on the firewall, floor, roof, back wall. Heatwave pro on the firewall and roof. Luxury liner in the doors. Ill have to see how the truck sounds audio wise and outside noise wise. Im sure that will be enough sound deadener but i have backups just incase. Mud tires and big turbos/5" TBE are loud and i want this thing to be quieter than stock if possible. On my 1500 with my Toyo MTs and long tubes and straight pipe the inside of the truck was dead quiet so im trying to duplicate that sound quality. The second skin with a bunch of 3M window tint keeps the truck insanely cool too
JLuck13 is offline
post #6 of 12 (permalink) Old 06-28-2013, 07:25 PM
phobos512's Avatar
Wow...I didn't know there was such a thing as what you're planning. But honestly audio's pretty much the bottom of my list. Good luck
Matt | '13 2500 Laramie CCSB 4x4 | Max Steel | Line-X Premium | 305/70R17 Nitto Terra Grapplers | Husky X-Act Contour Floor Mats | Husky Mud Guards | Weathertech Vent Visors | Craven Speed Stubby Antenna
post #7 of 12 (permalink) Old 06-28-2013, 08:18 PM Thread Starter
Honestly this build really isnt that extreme.
You wanna see crazy audio check these out
Just Meade....my projects - Tons of SMD Builds here! - SMD Forum
Steve Meade is to the audio world what Sage/Don is to the Dodge offroad world. Some of those threads in there are the monst insane builds you will ever see
JLuck13 is offline
post #8 of 12 (permalink) Old 06-29-2013, 11:52 PM
lonestarwelder's Avatar
I'd mount a small turbine APU in the bed to power all of that! Lol
Subscribed.
2015 3500 DRW Laramie CCLB 68RFE 4.10 4x4. CM SS flatbed. Cooper LT255/70R17 ST Maxx and 2" Stahl Steel spacers. Thuren 2.5 springs/shocks. Carli track bar Mag-Hytec rear cover with 75/110 Amsoil.
SOLD:2010 3500 DRW Big Horn CCLB Auto 4x4.
SOLD: 2005 3500 SRW SLT 4x4 G56
lonestarwelder is offline
post #9 of 12 (permalink) Old 06-30-2013, 03:55 AM Thread Starter
After talking to mechman today we decided that getting the 2nd alt on should be as easy as getting the 3500 bracket and theyre going to build me one of the "elite" series alts with a microscopic pulley that makes 370A at 2K RPM and just shy of 300A at 1K RPM. We figure paired with the stock 220A alt and a big battery bank i shouldnt have a problem. Im going to order the dodge parts on monday. Ill update this thread when the mayhem begins. ITs going to be a lot of fiberglassing and MDF in my future!
JLuck13 is offline
post #10 of 12 (permalink) Old 07-01-2013, 10:38 PM
pmccue's Avatar
please, post pics , subscribed
01 auto 4 by 4, Fass 150, edge juice attitude, hot unlock, bd towing twins,stage one cam, F1 4.8 injectors, , ported fireringed head , 110 springs, full billet DTT ,ARP studs, four inch mbrp, ARE dcu, , line x ,bedslide,
pmccue is offline
post #11 of 12 (permalink) Old 07-01-2013, 10:48 PM
This sound system sounds badass. Just a little more RMS Wattage than the last system I built.
2011 Ram 2500 SLT MegaCab Deep Water Blue Perl 4X4 68rfe, Transfer Flow Tank/Toolbox, Mini Maxx w/ OD, No Deletes... til the warranty is up. 18K Miles RIP 3/15/14
1994 Ram 3500 SRW 2WD Single cab Utility Body. 625K Miles
Blue-Ox is offline
post #12 of 12 (permalink) Old 07-01-2013, 10:51 PM Thread Starter
My last truck had 7500WRMS and it jut wasnt worth ALL of the extra work. I figure 5500-6000 is the perfect ammount
JLuck13 is offline
