7.3 mpgs & 260 degree tranny fluid! - Dodge Cummins Diesel Forum
post #1 of 46 (permalink) Old 04-29-2013, 12:34 AM Thread Starter
Angry 7.3 mpgs & 260 degree tranny fluid!
This weekend we were pulling one of the mountain passes, and once we reached the top, we started up a windy gravel road and the tranny temp got up to 260 degrees! I thought anything above 230 was bad for your fluid?? Is my fluid burnt now? I had no choice but to keep going, as the road was very windy and not wide enough to pull over and stop.
We also only averaged 7.3 mpg's pulling a 35' toy hauler???? 6 something on the way up, and then it averaged out to 7.3 on the way back (down hill w/tail wind). This seems a bit rediculous! This is a new trailer for us, but i pulled heavier loads all the time with previous diesels and never saw this kind of fuel mileage!
2012 3500 CTD Laramie Crew
2012 3500 CTD ST Crew w/flatbed
2007 3500 CTD 5.9, Quad cab, 6 speed, SLT w/flatbed
honda_guy4 is offline
post #2 of 46 (permalink) Old 04-29-2013, 12:38 AM
Slats Extend's Avatar
Auto, manual? What axle ratio? 2 wheel drive, 4 wheel?
2016 3500 Laramie Limited, AISIN, 3.73,RVK 3600. Titan 55 gal fuel tank, BD TSB
2012 Ram 3500 CCLB Laramie 4x4 DRW 68RFE 4.10 ,
BUYBACK.
2005 Ram 3500 CCLB Laramie Dually,auto 4x4 3.73 Traded
2001 Ram 2500 QCSB SLT+ Auto 4x4 3.54 SOLD
1992 W250 Getrag, SOLD
Slats Extend is offline
post #3 of 46 (permalink) Old 04-29-2013, 12:41 AM
LarrysDodge6.7's Avatar
Check the fluid and see if it smells burnt.
2012 D with a C.
LarrysDodge6.7 is offline
post #4 of 46 (permalink) Old 04-29-2013, 01:20 AM Thread Starter
Sorry, auto, 3.73, 4 wheel drive
post #5 of 46 (permalink) Old 04-29-2013, 01:27 AM
TowHaul on? I know last year I left a parking lot on the way up to a lake and forgot to re-engage TH mode and the tranny warmed up a bit. Nothing like yours but it was a slow winding road. No chance to get enough cool air and the converter wouldn't lock up. It was about 90 deg out too.
2018 2500 CC LB 4x4 6.4 Hemi 4.10
B&W Patriot, Timbrens
2013 Fox Mountain 235RLS
012cummins is offline
post #6 of 46 (permalink) Old 04-29-2013, 01:32 AM
Did you order the dual tranny coolers with your truck? I have them, and towing 10k over the pass I don't think my tranny even went above 200.
'97 3500 4x4 CC DRW, 4.10, Banks PP, BD tc, vb, eb, 60# springs, Torqloc, gauges, Weatherguard, B&W...
'92 CC W350 DRW sold '92 CC D350 DRW sold '12 Laramie CC 3500 4x4 SRW sold
brownbear is offline
post #7 of 46 (permalink) Old 04-29-2013, 02:05 AM
BigCE's Avatar
Wow that's hot, I would smell the fluid. Also check and see of you have dual tranny coolers, and possibly think about upgrading them.
2010 2500 Mega Cab Laramie Sold
2015 Jetta TDI...Yep
BigCE is offline
post #8 of 46 (permalink) Old 04-29-2013, 08:42 AM
Idk if you would have been able to do this safely, but I believe the recommendation if the temps get too high is to pull over, put it in neutral, an rev it a little for a few minutes
The trans is the one part I worry about most when I tow. I'm constantly looking at the temps on the evic. Is there an optimal range I should be looking for during towing or just a danger range? I think through hills of pa with my 5th wheel it never reached 150 and ambient temps were around 50-60*f
oaklandopen is offline
post #9 of 46 (permalink) Old 04-29-2013, 09:31 AM
If you never got above 150 your temp gauge is off.
2012 Ford F250 6.7 Powerstroke, Ultimate Lariat FX4...Tuxedo Black
Sold-2002 qcsb 4x4 cummins, 2006 Ram Bighorn 2500 4x4 Cummins.
Lrdchaos is offline
post #10 of 46 (permalink) Old 04-29-2013, 09:35 AM
Staying below 150 in cooler temps is easy to do. With an accurate temp gauge. Without dual coolers.
2012 Ram 2500 SLT Outdoorsman Regular Cab Automatic
2012 Ram 2500 Laramie Limited Crew Cab Automatic
treaves is offline
post #11 of 46 (permalink) Old 04-29-2013, 10:15 AM Thread Starter
I bought my truck off the lot, and don't remember seeing dual coolers listed as an option so i am assuming no? Also, yes tranny was in t/h. I tried pulling over for a couple of minutes (in the one half way safe spot) and idling up the motor, but didn't seem to have any effects. Will be checking the fluid this morning to see if it smells burnt. I don't know what the evic said the tranny temp was, this was off my edge insight, and it started beeping around 220 or 230 (can't recall for sure now). I thought anything above 230 was bad for sure, any tranny experts? Thanks guys!
post #12 of 46 (permalink) Old 04-29-2013, 01:36 PM
US American's Avatar
Search for posts by TransEngineer. He's the expert and has covered overheating issues in other posts. On mountain roads the best thing you can do is grab the lowest gear to minimize the slipping but you cannot eliminate it if the TC isn't locked. I have a ranch buddy in Montana, he tells me he and other ranchers avoid autos because of all the mountain road towing they do. It eventually burns up the trannies. You may be wise to check into changing fluid and filters.
2007 2500 6.7 QC SLT Bighorn shortbox auto 3.73. S&B, B&W turnover ball, Firestone bags, Mag Hytec rear cover, Warn XD9000i, etc.
US American is offline
