Coolant temp. - Page 3 - Dodge Cummins Diesel Forum
post #25 of 40 (permalink) Old 02-01-2014, 08:33 PM Thread Starter
Villa Style's Avatar
I will change mine when I do my turbo swap.
The Old : 07' 6.7 Mega, EFI
The Sold: 12' Mega, EFI, Carli
The Bold: 16' Mega, EFI
Villa Style is offline
post #26 of 40 (permalink) Old 02-02-2014, 01:33 AM
Hollnagel's Avatar
iTrader Score: 14 reviews
Mine will get up to 210-212 then open the first time. Then it'll float between 199-206.
I picked up a 190 thermostat at cummins southern plains a couple days ago just haven't put it in yet.
2012 Lonestar Edition Mineral Gray 3500 DRW CrewCab 4x4 6.7/68RFE 120,000 miles, Cummins Cat Fuel Filter Kit, 190į Thermostat, RevMax Valve Body, Edge Insight CTS
Instagram: hollnagelc
Hollnagel is offline
The Following User Says Thank You to Hollnagel For This Useful Post:
UCTJ (02-09-2015)
post #27 of 40 (permalink) Old 02-02-2014, 03:02 AM
trafficmstr's Avatar
I just did the 190* thermo on mine after delets stays around 187 to 192
trafficmstr is offline
post #28 of 40 (permalink) Old 02-03-2014, 03:06 PM
jlb27537's Avatar
In a previous thread, it was the general consensus was if you are stock you need to leave the 200 degree stat in it. Deleted, do what you want.
My stock '12 runs about 204 or so. When towing heavy and slow, when I get to 217 the fan turns on and it pulls down to 200 quickly. So, normal is 200-217.
2012 3500 DRW Laramie, Tow Max, 3.73, B&W Companion. Usually towing a 14.9K RV 5th wheel
jlb27537 is offline
The Following User Says Thank You to jlb27537 For This Useful Post:
UCTJ (02-09-2015)
post #29 of 40 (permalink) Old 02-03-2014, 05:14 PM
smykowski's Avatar
That's what mine does, usually hits 210, drops to 197-199, then stays right around 203.
smykowski is offline
post #30 of 40 (permalink) Old 09-19-2014, 08:08 PM
zirka's Avatar
high coolant temperature HELP
I have a 2010 6.7 with a g56 tranny. And my coolant temp is always running hot about 208 to 213 cruising empty on highway @ 70. I was recently pulling a boat hrough Utah and temperature spike to 220 to 230 at that point I started blasting the heat and trying to get the temperature down. Will not engage fan full speed unless the air conditioning is on. do you think that I have a thermostat problem? Please help.
zirka is offline
post #31 of 40 (permalink) Old 09-20-2014, 11:37 AM Thread Starter
That sounds like something else.
post #32 of 40 (permalink) Old 09-21-2014, 11:16 AM
I live in SETX and havent seen mine reach temps over 202 to 203. All stock. Usually keep the evic on temp gauge.
2011 Ram 2500 SLT CCLB, 6.7L, Black Pearl, black leather seats and carpet, toolbox
eXceleon DNX891HD DVD/NAV, backup camera, Dual 10" Kickers, Audiobahn amplifier
DPF/NOX delete with MM, custom tuning by Tom at Anarchy Diesel
systemicchanges is offline
post #33 of 40 (permalink) Old 09-24-2014, 10:14 AM
I think i have a t-stat sticking open. My 11 that is all stock will get to around 190 then drop to around 183 running interstate @ 70mph and stay there. It throws good heat so i dont know whats going on. Could it be that the sensor is off by 10 or 15 degrees. I would think if it was stuck open the temps would run around 140 to 150
kdkklam is offline
post #34 of 40 (permalink) Old 09-25-2014, 11:12 PM
rbro7752's Avatar
truck in sig runs 200-204 on average I did see 217 hauling a 6700# toy hauler up a long steep grade not to long ago runnin 75 mph.
2011 HO Outdoorsman CCSB all stock with 373 gears and 285's
rbro7752 is offline
post #35 of 40 (permalink) Old 09-26-2014, 02:05 AM
N of 60's Avatar
No matter stock or deleted, running 75mph pulling 6500+ up a steep grade, Dodge/Ram CUMMINS started this in the lite duty truck segment. There was no way in he double L this was going to happen with the naturally aspirated 6.2 or 6.9IDI. Just saying. Thanks for sharing, Hope its a simple answer for the OP. Definitely not motor threatening. Keep it simple.
Yes I have had a couple. Long day. Haha
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.High tech old school and finally lovin it.
N of 60 is offline
post #36 of 40 (permalink) Old 10-07-2014, 01:55 PM
rmgthompson's Avatar
I just ordered a MOTORAD 426190 (426-190) thermostat for my truck. Here lately my truck will reach as much as 212f before the thermostat opens. I am inclined to believe the thermostat is sticking because it used to open sooner. For peace of mind I'm going with a 190 because normal operating temp of 204f just seems hot.
2012 RAM 2500 Laramie, 4X4, Solid Mineral Grey, Tinted, 6.7L CUMMINS High Output Turbo Diesel with H&S Mini Max, 3:73 rear, 6 speed auto, BAK FLIP F1, LINE-X, MOPAR NERF BARS, Bilstein 5100's and Bilstein steering damper
rmgthompson is offline
