2010-2012 6.7L Turbo Diesel Engine Service Info:
Engine Oil Filters: MOPAR# 05083285AA or MO-285 | CUMMINS# 3949561 | FLEETGUARD# LF3972 (standard 30 microns at 95%) or FLEETGUARD# LF16035 (upgraded/fluted stratapore version 30 microns at 100% / 10 microns at 60%) | AMSOIL# EA080 (15 micron at 98.7%) $18.85 each wholesale or $24.80 retail | ROYAL PURPLE# 40-780 (99% filtration at 25 microns) | DONALDSON# ELF7349 | WIX# 57620 (standard/20 micron) or 57620XE (high efficiency/14 micron) | NAPA GOLD# 7620XE (14 micron) | FRAM# PH3976A (standard) or HPH3976A (extended life) | BALDWIN# BT7349
Fuel Filters:
MOPAR 68157291 NANONET two stage fuel Filter (5 micron outer/3 micron inner) | MOPAR# 68065608AA (5 microns at 98.7%) | FLEETGUARD# FS43255 (5 microns at 98.7%) | CUMMINS# 4947561 (5 microns at 98.7%) | WIX# 33255 (12 micron at 100% / 5 micron at 98.7%) | NAPA# 3255 (12 micron at 100%) | Baldwin#
Air Filter: MOPAR# 53034051AB | FLEETGUARD# AF27684 | WIX# 46930 | NAPA# 6930 | FRAM# CA10261 | PUROLATOR# A56314 | DONALDSON# P616743 | BALDWIN# PA4318
68RFE Transmission (4x4 only): MOPAR Sump Filter# 5013470 | MOPAR Screw On# 5179267
68RFE Transmission (4x2 only): MOPAR Sump Filter# 5013470A | MOPAR Screw On# MOP-5179267
AISIN Transmission (4x2 & 4x4): MOPAR Sump Filter# 68019688 | MOPAR Pan Gasket# 68020049
Crankcase Vent Filter (CCV): CUMMINS# CV520010
Engine Oil Viscosity: In ambient temperatures below 0°F (-18°C) 5W-40 synthetic engine oil that meets Chrysler Materials Standard MS-10902 and the API CJ-4 engine oil category is required. In ambient temperatures above 0°F (-18°C) 15W-40 engine oil that meets Chrysler Materials Standard MS-10902 and the API CJ-4 engine oil category is required. *Change engine oil when prompted by the Engine Oil Indicator System or every 7,500 miles/12,000km or 6 months. Uses 12.1 Quarts/11.4 Liters/3 gallons. *Can use MOPAR DIESEL FRESH Oil Additive PN: 05139947AA to neutralize the smell during oil changes if preferred. The four-ounce Diesel Fresh bottle treats up to 12 quarts of diesel engine oil. For easy removal use this End Cap Filter Wrench: LISLE 54780 END CAP FILTER WRENCH-Dodge Cummins Diesel Truck Accessories – Geno’s Garage **Your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “Oil Change Due” on your Electronic Vehicle Information Center (EVIC). The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending on your per- sonal driving style. Driving styles such as frequent stop and go type driving or extended idle time can increase the frequency of the engine oil change. Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Trip Odometer button on the instrument cluster. To reset the oil change indicator system: (after performing the scheduled maintenance) 1. Turn the ignition switch to the ON/RUN position (do not start the engine). 2. Fully depress the accelerator pedal slowly three times within 10 seconds. 3. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary, repeat this procedure.
Transmission Service: Automatic Transmission (68RFE): MOPAR ATF+4 Automatic Transmission Fluid or equivalent. *Change automatic transmission fluid and filter(s) every 60,000 miles.
Automatic Transmission Chassis Cab (AS68RC): MOPAR AS68RC Automatic Transmission Fluid or equivalent. *Change every 30,000 miles (48,000 km) or 24 Months
Manual Transmission (G-56): MOPAR ATF+4 Automatic Transmission Fluid or equivalent. *Change the manual transmission fluid at 120,000 Miles (192,000 km) or 96 Months.
Fuel Filter Service: Replace fuel filter every 15,000 miles or 12 months using MOPAR Fuel Filter or equivalent. *Must meet 5 micron rating. Using a fuel filter that does not meet the manufacturers filtration and water separating requirements can severely impact fuel system life and reliability. For easy filter removal use this $6.95 Cummins Fuel Filter Removal Tool: LISLE 14600 CUMMINS FUEL FILTER REMOVAL TOOL-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Fuel Tank Capacity: 34 Gallons / 29 Liters (short bed) or 35 Gallons / 132 Liters (long bed). *Commercially available fuel additives are not necessary for the proper operation of your Cummins diesel engine. Use MOPAR Premium Diesel Fuel Treatment # 5191800 or equivalent as needed. Use Valvoline Synpower Diesel Injector Cleaner or equivalent as needed to clean and lubricate injectors and pump.
Radiator Service: Use MOPAR Antifreeze/Coolant 5 Year/100,000 mile formula or equivalent. *Flush and replace engine coolant every 60 months or replaced at 97,500 miles (157 000 km). Uses 5.7 Gallons or 21.4 Liters of coolant
Transfer Case Service: Change the transfer case fluid (4x4) every 60,000 miles (96,000 km) or every 48 months. Use MOPAR ATF+4 Automatic Transmission Fluid or equivalent. Fluid level can be checked by removing the filler plug and inserting a finger. The level of the lubricant should not be more than 1/2 in (12 mm) below the bottom of the filler hole while the vehicle is on level ground.
Power Steering Service: (3500) Flush and replace power steering fluid at 97,500 Miles (157,000 km) or 78 Months. (2500) Flush and replace power steering fluid at 105,000 Miles (168,000 km) or 84 Months. Use MOPAR ATF+4 Automatic Transmission Fluid or equivalent.
Front/Rear Axle Service: Inspect the front (4x4) and rear axle (2x4 & 4x4) fluid and change if using your vehicle for police, taxi, fleet, off-road or frequent towing every 15,000 miles (24,000 km) or 12 Months. Rear Differential: (8.5 pints or 4.2 quarts (LSD) / 8.9 pints or 4.5 quarts (Open) Front Differential: (4.7 pints or 2.4 quarts)
Front Drive Shaft: Grease Front Driveshaft Fitting at each oil change interval, every 7,500 miles or 6 months. Use MS-6560 Lithium Base Grease #05083150AA or equivalent. (must use grease gun needle adaptor) Buy Performance Tools 4" Grease Gun Needle Nose Adapter W54216 at Advance Auto Parts Here is a picture of where the fitting is on the driveshaft: http://www.cumminsforum.com/forum/6-7l-powertrain/157170-front-driveshaft-greasefitting.html
Clutch Linkage: Lubricate using MOPAR® Multi-Purpose Grease, NLGI Grade 2 E.P. or equivalent.
Crankcase Ventilation Filter (CCV): Replace Crankcase Ventilation Filter every 67,500 miles (108,000 km) or every 54 Months. Use MOPAR CCV Filter or equivalent.
Diesel Particulate Filter (DPF): Clean every 200,000 miles, 6500 hours (anually if used vocationally) or if notified by by on-board computer.
Overhead Adjustment: Adjust every 150,000 miles, 5,000 hours or 4 years. (any excessive lash or need of constant adjustment may indicate tube, rocker, and or camshaft are damaged)
Cabin Air Filter: Add this mod to ensure proper HVAC air flow inside the cab and replace as flow decreases or filter gets dirty. DODGE RAM CABIN AIR FILTER KIT ('10-'12)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
EGR Cleaning Kit: 6.7L EGR CLEANING KIT W/O FILTER ('07.5-'12)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Turbo Drain Tube: The stock drain tube is only about 9-1/2" long and too short for aftermaket turbos unless you get lucky(extremely unlikely). The 3rd gen turbo drain tube is 11" long and fits way better. Cummins PN# 3970875 or get it here: Cummins Stock Length Flexible Turbo Drain Tube 5.9L 3970875 don't forget to get a new turbo drain gasket PN# 5264568 https://genosgarage.com/prodinfo.asp?number=5264568
* Any brand product that meets or exceeds the factory OEM products “should” be ok to run however I would like to point out that Cummins developed Cummins Filtration in 1958 to meet the high performance requirements of Cummins diesel engines and manufactures Fleetguard filters. Cummins also endorses and recommends Valvoline Oil. This by no means discounts other brand products or quality but many will argue these Cummins endorsed/manufactured products are the best for a Cummins engine.
With that being said here are some products/feedback/prices and places to buy them from. Feel free to post your favorites or comments on products for the 6.7L
Engine Oil:
Valvoline Premium Blue 15W40 Diesel Engine Oil $14-16 per gallon (great all around oil, Cummins endorsed) (Valvoline)
Valvoline Premium Blue Extreme 5W40 Diesel Engine Oil $20-35 per gallon (great for the winter or extreme cold temps, Cummins endorsed) (Valvoline)
AMSOIL Synthetic 15W-40 Diesel Oil (DME1G) $29.80 per gallon wholesale / $38.70 retail or $113.40 per 4 gallons wholesale / $153.10 retail
AMSOIL Synthetic 5W-40 Premium Diesel Oil (DEO1G) $30.40 per gallon wholesale / 39.50 retail or $115.80 per 4 gallons / $156.35 retail
Royal Purple 15W40 Diesel Engine Oil #RP-1154 $8-9 per quart
Rotella T Triple Protection 15W40 Diesel Engine Oil $13-14 per gallon or $3-4 per quart (Shell)
Rotella T6 Synthetic Extreme Temperature 5W40 Diesel Engine Oil $21-22 per gallon (Shell)
Mobil One 5W40 Synthetic Diesel Engine Oil $25 per gallon (Mobil)
Mobil Delvac 1300 Super 15W40 Diesel Engine Oil $13-14 per gallon (Mobil)
Delo 400LE Heavy Duty Motor Oil 15W40 $12-13 per gallon or $3-4 per quart (Chevron)
Auto Transmission Oil / Transfer / Power Steering:
AMSOIL Synthetic Multi-Vehicle Automatic Transmission Fluid (ATF1G) $34.85 per gallon wholesale / $45.20 retail or per 4 gallons $132.60 wholesale or $179.05 retail
AMSOIL Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT) $8.90 per quart wholesale / $11.50 retail
Royal Purple Max ATF Synthetic Transmission Fluid (RP-1320 $12 for 1 quart) (RP-12320 for 12 quarts) or (RP-5320 for a 5-gallon pail)
Front Differential / Rear Differential:
AMSOIL SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) $11.55 per quart wholesale / $14.90 retail
AMSOIL 75W-90 Synthetic Long Life Gear Lube (FGRQT) $9.50 per quart wholesale / $12.35 retail (FGR1G) $37.45 per gallon wholesale / $48.55 retail
Royal Purple Max-Gear 75W-90 (RP-1300 for 1-quart bottle) (RP-12300 for 12 1-quart bottles) (RP-5300 for a 5-gallon pail)
Brake Fluid:
AMSOIL Brake Fluid DOT-3 (BF3SN) $5.50 per 12oz wholesale / $7.20 retail
Grease:
AMSOIL Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR) $9.14 per 14oz cartridge wholesale / $12.75 retail
AMSOIL Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCCR) $5.41 per 14 oz cartridge wholesale / $7.55 retail
AMSOIL Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR) $5.82 per 14oz cartridge wholesale / $8.10 retail
Royal Purple Ultra-Performance Grease (UPG) (RP-1312 for 14½-Ounce Tube) (RP-30312 for 10 14½-Ounce Tubes)
Additives:
Valvoline Synpower Diesel Injector Cleaner $16-17 for 32oz
Mopar Diesel Fresh $9-10 for 4oz
Mopar Premium Disel Fuel treatment $7-8 for 11oz
Fleetguard Fleet-Tech CC2588 Turbo Diesel Fuel Additive $8-9 for 16oz
Fleetguard Fleet-Tech CC2592 Winter Conditioner $7-8 per quart
Fleetguard CC2597 Asphaltene Conditioner $9-10 per quart
Assembly Lube:
Royal Purple Max-Tuff Assembly Lube (RP-10553 for 2-ounce bottle) (RP-1335 for 8-ounce bottle) (RP-12335 for Case of 12 8-Ounce Bottles)
Torques:
Oil Drain Plug.....37 ft/lbs
Manual Transmission G56 Fill Plug 42 ft/lbs and Drain Plug 42 ft/lbs
Transfer Case NV271 Fill Plug 15-25 ft/lbs and Drain Plug 15-25 ft/lbs
Transfer Case NV273 Fill Plug 15-25 ft/lbs and Drain Plug 15-25 ft/lbs
Front End & Suspension Upgrades:
BD Steering Box Stabilizer: BD STEERING BOX STABILIZER ('09-'12) 4WD-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Carli Low-Mount Steering Stabilizer: Dodge Ram Steering Stabilizer - Bilstein 7100 Series Steering Stabilizer for Dodge Ram 2500/3500 or Thuren Fabrication- Dodge ram steering stabilizer kit
Adjustable Track Bar: Dodge Ram Suspension - Carli Track Bar or Adjustable Pan Rod Bar or Thuren Fabrication - 2003-2011 Dodge trackbar
Control Arms: Carli Dodge Ram Control Arms and Suspension System Components or .: THUREN FABRICATION :. DODGE RAM CONTROL ARMS
Carli Front End Upgrade Kit: Dodge Ram Suspension - Carli Front End Upgrade Kit
Rear Lift Shackles: (3/4" - 1.75") .: THUREN FABRICATION :. 2003-2009 RAM SHACKLE
Performance Tuners:
H&S Mini Maxx: Mini Maxx - H&S Performance plus Dodge Mounting Solutions - H&S Performance
H&S Black Maxx: Black Maxx - H&S Performance plus Dodge Mounting Solutions - H&S Performance
H&S XRT Pro: XRT Pro Race Tuner by H&S Performance - H&S Performance plus Dodge Mounting Solutions - H&S Performance
H&S Overdrive Transmission Software: OVERDRIVE Transmission Software - H&S Performance
Performance Exhaust & DPF Delete Pipes:
5" SS TBE (Turbo Back Exhaust): 2007-2009 Dodge 6.7 STAINLESS Turbo Back 5" DPF Delete with Muffler - Dodge Exhaust - Exhaust/DPF Delete Kits or 2007-2009 Dodge 6.7 STAINLESS Turbo Back 5" DPF Delete NO MUFFLER - Dodge Exhaust - Exhaust/DPF Delete Kits
DPF Delete: FLO~PRO - 2011 Dodge Cummins Exhaust Kits or 2007-2012 Dodge 6.7 DPF Delete Pipe No Bungs - Dodge Exhaust - Exhaust/DPF Delete Kits
DPF Delete & Downpipe: 2007-2012 Dodge 6.7 Stage 2 DPF Delete/Downpipe Kit No Bungs - Dodge Exhaust - Exhaust/DPF Delete Kits or 2007-2012 Dodge 6.7 STAINLESS DPF Delete/Downpipe Kit No Bungs - Dodge Exhaust - Exhaust/DPF Delete Kits
EGR & EGR Cooler Deletes:
EGR only Delete: 2007-2012 Dodge 6.7 EGR Delete - EGR Delete Kits
EGR Cooler only Delete: 2009-2012 Dodge 6.7 EGR Cooler ONLY Delete - EGR Delete Kits
EGR & EGR Cooler Delete: 2009-2012 Dodge 6.7 EGR/Cooler Delete - EGR Delete Kits or DRP 6.7L EGR Delete Kit For 09-11 Cummins
Performance Parts:
Cold Air Intakes(CAI): Cummins
High Flow Intake Manifolds / Deletes EGR only: GDP Mega-Flo S-2 Flanged 6.7L Cummins Intake Manifold (Blue or Black) #07511-MFS2 Glacier Diesel Power - Product Detail | GDP '07.5-'12 6.7L Mega-Flo Throttle Valve Grid Heater #07510-MF-TVH Glacier Diesel Power - Product Detail | 2007-2012 H&S Maxx Flow Intake Manifold for Dodge 6.7 Cummins *Requires use of other parts - EGR Delete Kits
Boost Tubes: GDP 2010-2012 6.7L 3.50" Silicone Boost Tube #201012-SBT Glacier Diesel Power - Product Detail | 2010-2012 Dodge 6.7L 4" Boost Tube
Grid Heater Deletes: GDP '07.5-'12 6.7L "Air-Boss 67" Grid Delete (Pickup) #07510-ABIP Glacier Diesel Power - Product Detail
Fuel Rail Plugs: Fuel Rail Plug Ram 6.7L / Duramax 6.6L
Big Fuel Line Kits: GDP '10-'12 6.7L Cummins Big Line Kit #201011BLK Glacier Diesel Power - Product Detail
Upgraded Fuel Systems: AirDog II - Advancing AirDog Technology by Removing Entrained Air/Vapor from Diesel Engine Fuel or Fass - Fuel Air Separation System
Water-Methenol Injection Kits: Snow Performance : Diesel MPG-MAX? or Snow Performance : Diesel TOW-MAX?
Performance Differential Covers:
Mag-Hytec Rear Diff Cover #AA 14-11.5 (8-quart capacity) Dodge #AA 14-11.5 [Dodge #AA 14-11.5] - $285.00 : Mag-Hytec
Mag-Hytec Front Diff Cover #AA 14-9.25 (4-quart capacity) Dodge #AA 14-9.25 [Dodge #AA 14-9.25] - $285.00 : Mag-Hytec
Head Studs & Head Gasket Parts:
ARP 425 Head Studs #247-4202 ARP 247-4202 Head Stud kit for 98.5 and up Dodge Cummins - 12mm
ARP 625 Head Studs#247-4204 ARP 247-4204 Custom H 625 Super Alloy High Tensil Strength Fits 98-up Dodge 5.9L
ARP Ultra- Torque assembly lube 1.68 oz tube #100-9909 ARP 100-9909 - ARP Ultra Torque Assembly Lubricants - Overview - SummitRacing.com or ARP 100-9909 ARP Ultra-Torque Fastener Assembly Lube
VALVE COVER GASKET ('06-'12, 5.9L & 6.7L) CUMMINS #5264950 CUMMINS 5264950 VALVE COVER GASKET ('06-'12, 5.9L & 6.7L)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
6.7L Head Gasket Cummins #4932210 Cummins 6.7L Head Gasket 4932210
HID Replacement Lights:
Quad Lamp H11 Headlights: 55W DIGITAL HID KITS - Retro-Solutions Store (2009+ quad lamp, regular ballast, no caping)
H10 Fog Lights: 55W DIGITAL HID KITS - Retro-Solutions Store (regular ballast, no caping) and HID relay wiring harness - Retro-Solutions Store (H10)
Dual Lamp H13 Headlights: 55W DIGITAL HID KITS - Retro-Solutions Store (regular ballast, no caping, 2006+ dual lamp)
LED Interior Dome Light #578-6LED: High Power 578 211 212 212-2 214 Festoon LED Bulbs
LED Backup Lights #921-CREE: Pair 921 T15 5W CREE LED bulbs
LED Amber Blinker Lights #3157-WEDGE: Pair 3156/3157 T20 LED Wedge Bulbs
Fuel Filters:
Engine Oil:
Brake Fluid:
Grease:
Additives:
Assembly Lube:
Torques:
Performance Tuners:
Performance Parts:
