Can't get transmission crossmember off - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 01-11-2011, 02:05 AM Thread Starter
Well, it seems I scraped the crossmember on something. I'm doing an exhaust, and can't get it off. I removed the shield going to the rearward member, the 4 bolts holding the crossmember to the frame, and the 3 holding it to the transmission. It won't budge. I even lowered the jack and there was 0 movement. Any special way of taking the cross member out (besides bfh and a wrecking bar)?
2010 Reg Cab LB 4x4 Handshaker
JohnRodriguez is offline
post #2 of 5 (permalink) Old 01-11-2011, 02:34 AM
ram1500tr's Avatar
try putting a board under the trans and jack that up a hair it will have some play and let you pull it good luck
new truck 2001 dodge ram 2500 extended cab long bed mild build auto trans. new vp pump edge comp drag box and hoping more to come soon
ram1500tr is offline
post #3 of 5 (permalink) Old 01-11-2011, 03:08 AM
Tech support junkie
powerstroke8994's Avatar
Porta power and spread the frame apart a little
[COLOR=2017 2500 tradesman_g56[/COLOR]
SOLD2017 F-250 platinum
SOLD-2014_F-250_Platinum
SOLD-2010_48re
SOLD_2013 MEGA_g56_laramie_Loaded
powerstroke8994 is offline
post #4 of 5 (permalink) Old 01-11-2011, 04:09 AM Thread Starter
36" wrecking bar popped it out pretty fast. Was trying not to make too much noise for the neighbors since it's 2am heh. Now it seems the Flo Pro exhaust I got doesn't fit reg. cab long beds
post #5 of 5 (permalink) Old 01-11-2011, 12:11 PM
Tech support junkie
No youll def have to do some trimming. Dont see too many reg cabs. That thing would look insane lifted with a set of stacks man
SOLD-2010_48re
