oil change question. - Page 4 - Dodge Cummins Diesel Forum
post #37 of 43 (permalink) Old 12-06-2010, 02:30 AM
Funny that the symbols would tell you to not fill the filter until after the previous symbols tell you how to install and tighten it.
Certainly, it's not a requirement to fill the filter. But they aren't saying that it hurts anything either, except the silly assumption that new oil is unfiltered and dirty.
I wouldn't be surprised if they just don't want us simple folk to spill oil on ourselves, slip and fall, and then sue them.
Maybe they even assume that some folk will want to add oil from an open 5 gallon bucket out on the farm somewhere, who knows?
'05 QC DRW flatbed, 6sp manual, 85k miles, silencer ring MIA.
TECH9405 is offline
post #38 of 43 (permalink) Old 12-06-2010, 09:53 AM
Nadir Point's Avatar
Originally Posted by CTD67L View Post
The distributor is correct. Pre-filling the oil filter puts unfiltered oil on the clean side of the filtering media. The oil pump on will fill the oil filter very quickly, within a second or two. Therefore, the recommended practice by many engine manufacturers is to not pre-fill the oil filter.
Well then, I guess I just lost all respect for Baldwin tech support, because that is pure horse manure. I'd be much more worried about initial flow and media collapse than having clean oil in the filter. The lube system flows many gallons per minute while running. The alleged issue of a quart-and-a-half of "unfiltered" oil present at startup as rationale for not pre-filling a filter is just ludicrous.
1stGen: (1) (2) (3) (4) Commonrail: (2)
Nadir Point is offline
post #39 of 43 (permalink) Old 12-06-2010, 11:16 AM
Snofarmer's Avatar
I'm sure it's been covered but the owners manual says to pre-fill the filter. or am I seeing things
Next why would you be so worried about the un filtered oil in the filter? I know with the foil on top of some of the oil jugs and some people not being careful and letting this foil get into the filter and clogging the oil galley.
These other reasons not to pre-fill are hogwash.
Where do you pour the oil into your engine? This "unfiltered oil has already been all over your valve-train.
This "unfiltered" oil is clean unless "you" contaminated it.
Pre-fill your filter.
Snofarmer is offline
post #40 of 43 (permalink) Old 12-06-2010, 11:25 AM
Rangel's Avatar
Now that we got that settled is it30 yet?
03 3500 H.O.| QC/LB|SRW|4x4|NV5600|Leveled|BFG AT 315/70/17|SmartyTNT|Valair DD|ADII 165|5"TBE w/ Aero 5050XL|Willy's Whistler|Banks Monster Ram|AutoMeter Boost,Pyro,FP,RP|HE351|440/900 Gone but not Forgotten
Rangel is offline
post #41 of 43 (permalink) Old 12-10-2010, 02:21 PM
CTD67L's Avatar
Lightbulb
Originally Posted by TECH9405 View Post
The steps don't match correctly if that was the intended message. Here's how I see it:
1. Remove filter/clean base
2. Lube the seal/PRE-FILL the filter
3. Hand tighten filter
4. Add 1 turn
5. Check for leaks
6. Dispose of properly
If #5 was a "do not pre-fill" message, it would be step #2. That reply from the Baldwin guy is probably a generic reply to the question of "do I HAVE to prefill the filter".
I don't see how prefilling can possibly harm a filter. For me to believe it, I need a good reason. My .02
DING DING DING. We have a winner. Symbol #5 on the Baldwin filters does mean "Check for leaks." Per Travis at Baldwin tech support. He said as long as you do not use a pressurized nozzle to fill the filter, there is no harm in pre-filling. If your re-using oil, which must be a common practice for OTR drivers, you should pre-fill through the little inlet holes as opposed to the threaded outlet hole. This keeps contaminants on the "dirty" side of the filter. If using new oil, it doesn't matter.
Finally...
'10 2500 Laramie CCSB BBCP 4X4 68RFE, 285/70-17 Dueler Revo 2's, Black Maxx w/ MCC and OverDrive, 4" TBE w/ 5" tip, Airaid Intake w/ SynthaMax filter, AMP Power Steps.
The dealer said my truck needed new sparkplugs 6>8
CTD67L is offline
post #42 of 43 (permalink) Old 12-10-2010, 06:21 PM
Mopared's Avatar
can all of us that said to pre-fill the frickin' filter give ourselves a pat on the back yet or is this thing going to continue?
2010 2500 ST Crew Cab Long Bed
Bright Silver Metallic
4X4 / G56 / 3.73's / Limited-Slip
Mopared is offline
post #43 of 43 (permalink) Old 12-10-2010, 07:39 PM
Waboo's Avatar
I agree 100%! Yes, you get an A+, so give yourself a pat on the back, then have some cookies and milk.
Terry : ) - US Navy Retired
2016 F150 Platinum 4x4 (Stop Laughing)
Waboo is offline
