P0087 Fuel Pressure Too low... - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 11-04-2010, 06:17 PM Thread Starter
er-74's Avatar
So I was driving up a hill and all the sudden the CEL came up...I have a minimax, with plug to avoid defueling, DPF delete and air intake. truck has ~15k diesel filter was replaced about 1k ago. Any ideas? WOT rail pressure is 23K normal driving is 18-19k. Any help or advice would be appreciated.
er-74 is offline
post #2 of 21 (permalink) Old 11-05-2010, 12:55 AM
Tech support junkie
powerstroke8994's Avatar
Might be the lift pump straining to keep up. If i was you id take that plug out and see ifit still does it. I remember someone having issues with that a while ago and it ended upbeing that plug. 23k seems low to me as mine goes up to 25k. IDK though id try the FPRV reinstall first. With just a mini doubt youll ever pop the valve anyways
[COLOR=2017 2500 tradesman_g56[/COLOR]
SOLD2017 F-250 platinum
SOLD-2014_F-250_Platinum
SOLD-2010_48re
SOLD_2013 MEGA_g56_laramie_Loaded
powerstroke8994 is offline
post #3 of 21 (permalink) Old 11-05-2010, 06:52 AM Thread Starter
er-74's Avatar
Thanks I will try that today...
er-74 is offline
post #4 of 21 (permalink) Old 11-05-2010, 07:17 AM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
what tune were you running when it came up?
Back in the common snail game. 03 SO 2wd 530,000 miles and counting.
11 3500 Laramie DRW 2wd deep forest green pearl
Shibbyutman is offline
post #5 of 21 (permalink) Old 11-05-2010, 07:57 AM Thread Starter
er-74's Avatar
70hp...I'm going to try a couple of things today. 1st drive it it without the program and if still does it put the original rail pressure valve back. I'm also going to check the diesel filter...although is 1k old and I done drive the truck with less than 1/2 tank ( I owned a gas station). I frustating as the old truck 2003 never gave me any problems...
er-74 is offline
post #6 of 21 (permalink) Old 11-05-2010, 09:49 AM
Tech support junkie
That will be a good start get back to us and let us know what ya find
SOLD-2010_48re
post #7 of 21 (permalink) Old 11-05-2010, 07:34 PM Thread Starter
er-74's Avatar
Update...this morning I put back the oem fuel rail plug, I had the one from H&S and the cel shutoff. The pressure now is 24-26K, I drove about 100 miles no issues. I will monitor over the weekend to see what happens. Also I spoke with H&S and I was told that the 2010 did not needed the rail plug... that it was intended for 2007. I will keep you updated if it comes back again.
powerstroke8994-have you had any issues with yours?
er-74 is offline
post #8 of 21 (permalink) Old 11-06-2010, 12:35 AM
Tech support junkie
My fuel rail plug is sitting in the minimaxx box right next to my desk.lol I never found a need to install it just bought it to have just in case i was popping it off. Rail psi doesnt get high enough to pop it yet. I have it just incase though. IDK why but seems like ive seen alot of the plugs casuing more issues than good. Ive had no issues with rail psi yet. Let us know how it turns out
SOLD-2010_48re
post #9 of 21 (permalink) Old 11-07-2010, 09:07 PM
bnt5574's Avatar
I am having problems with mine also it has about 13,000 miles on it no cel's but the engine chugs on the highway feels like I am losing power then comes back if I increase throttle and rail pressure goes up it seems to go away. If I am on a higher tune its more evident. I change the fuel filter yesterday and no difference. I have the H & S fuel rail plug installed does anyone think this could be causing my problems.
2010 Dodge CC Laramie 6.7, Thuren 3" coil & mini pack, bilstein 5100's, air lift bags, 20" XD rock stars, terra graplers
bnt5574 is offline
post #10 of 21 (permalink) Old 11-07-2010, 11:39 PM
Tech support junkie
Very possible sir. Why not throw that puppy back in? IMO though it almost sounds like a fuel supply issue though. WHat is your railpsi when this starts happening? Id get a fuel psi gauge and check what the supply pressure is. If you lived closer to me id help you do it as i have all the fitting to check it. But youcould always install a pillar setup w/ a fuelpsi gauge that would be awsome
SOLD-2010_48re
post #11 of 21 (permalink) Old 11-09-2010, 09:07 PM
bnt5574's Avatar
Powerstroke I have put the stock fuel rail plug back in and I will see tomorrow when I go to work if its still there fuel pressure is all over the place when I watch it but i assume that's normal. I really don't think this is going to fix the problem as I put about 3000 miles on the truck with the H&S plug and no issues. Any other ideas other then taking it to the dealer as I will have to put the DPF back on.
Thanks
bnt5574 is offline
post #12 of 21 (permalink) Old 11-09-2010, 09:14 PM Thread Starter
er-74's Avatar
bnt5574-Since I put the oem plug back the cel is gone . I would try that for starters...good luck
er-74 is offline
