2012 broken borg warner tcase again - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By DarylB
post #1 of 8 (permalink) Old 01-22-2020, 01:58 PM Thread Starter
12ramadam's Avatar
first time posting anything so burn away .
my question is do al this tcase explode on the inside under torque they are the cheapest test possible even the steel gears split this is third time into mine there must be a better option
12ramadam is offline
post #2 of 8 (permalink) Old 01-22-2020, 05:50 PM
DarylB's Avatar
What happened? Bad drive shaft blow the T-case? Need to fill out your signature & provide details. No, transfer cases don't just randomly explode.
Lins likes this.
2016 Ram 3500 4wd Reg Cab G56 Power Wagon Build. 4.10 ARB f/r , BDS swaybar disconnect, CAD Delete, Dynatrac Freespins Carli 2.0 37x12.5R17 Yokohama Geolandar M/T G003
DarylB is offline
The Following User Says Thank You to DarylB For This Useful Post:
N of 60 (01-23-2020)
post #3 of 8 (permalink) Old 01-24-2020, 12:49 PM Thread Starter
12ramadam's Avatar
had no front shaft on . it was off having double cardine removed and 1400 series installed. coupleing that sides on main shaft of tcase shattered.
post #4 of 8 (permalink) Old 01-24-2020, 12:54 PM Thread Starter
12ramadam's Avatar
cardine joint #2 had not blown apart but was getting loose so I removed shaft which got greased monthly , first one was only during oil change.
post #5 of 8 (permalink) Old 01-24-2020, 02:21 PM
Lins's Avatar
Doing a lot of off roading?
Lins is offline
post #6 of 8 (permalink) Old 01-24-2020, 06:46 PM
Cummins Freak
SRich12's Avatar
2012 and previous yrs are perfect trucks to add free spin hubs on since the front drive line turns all the time!!! Only time I have heard transfer cases exploding is usually when the front drive shaft comes apart. I'm sure it happens but it's not common!!
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swap w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is offline
post #7 of 8 (permalink) Old 01-26-2020, 05:47 PM
How much lift you have on your truck? I installed a indexing ring on mine to keep the angle of that joint down. How many miles are you getting on the joint before it goes bad? What does it do , start vibrating?
ar_mcadams is offline
post #8 of 8 (permalink) Old 01-27-2020, 07:23 PM
Gr8bawana's Avatar
Yeah....they explode just because. It couldn't possibly be anything you might have done.
2017 4x4 2500
6.7 CTD 100% stock
33.700 miles
Gr8bawana is offline
