68rfe cracked case COMMON? - Dodge Cummins Diesel Forum
 5Likes
  • 1 Post By sicumminsde
  • 2 Post By URDiesel
  • 1 Post By ofelas.5z
  • 1 Post By TransmissionPartsNow
post #1 of 12 (permalink) Old 11-29-2019, 01:55 AM Thread Starter
jroyster06's Avatar
So I was online looking for service information on my 68rfe and came across ATS diesels transmission case brace. After watching the youtube video, its got me convinced i've been living under a rock and had no idea about our cases being prone to cracking...
Sooo, have I been living under a rock and its a potential likely problem and a brace would be good on a lifted truck? OR is it snake oil and not to worry?
Ive also read that U-joints going out will crack them. I plan on a transmission service soon with a deeper pan, upgraded filter coupler, as well as fixing a leaky seal.... If the brace isn't snake oil, ill consider it...
2013 Mega Laramine longhorn. 6" BDS Long arm, 22" Hostages, 37x13.50 Nitto Ridge Grapplers, Fusion Bumpers, Back flip, AMP steps, Mag Diff Covers, 4.30's.... 3 previous cummins
jroyster06 is offline
post #2 of 12 (permalink) Old 11-29-2019, 09:13 AM
That brace is the last thing I would spend money on.
nick00less likes this.
2013 2500 CTD Laramie 4x4 68rfe
sicumminsde is offline
post #3 of 12 (permalink) Old 11-29-2019, 03:45 PM
Marketing 101! If you're making enough BHP, you can break/crack the case.
It comes from abusive behavior with high BHP and built trans internals.
My nephew broke his 2008 1 ton 68RFE because he has 700 plus BHP
and drives like a knucklehead. Anything can be broken if you try hard enough.
An external brace is a great marketing item, but it's like trying to fix a water leak
from the outside of the pool.
Maybe you could try some Flex Seal and hope for the best
jroyster06 and nick00less like this.
2016 Laramie 2500 CC 4X4 6.7L CUMMINS
URDiesel is offline
The Following User Says Thank You to URDiesel For This Useful Post:
jroyster06 (11-30-2019)
post #4 of 12 (permalink) Old 11-29-2019, 05:09 PM
ofelas.5z's Avatar
Go for the brace.
Should go well with the Nittos, Fusions, and Mag Hytecs.
N of 60 likes this.
R12.5z in the summer, Webasto in the winter; cassette tapes & SAE-20078.5z all year.
ofelas.5z is online now
post #5 of 12 (permalink) Old 11-30-2019, 04:06 PM Thread Starter
jroyster06's Avatar
Originally Posted by ofelas View Post
Go for the brace.
You and N of 60 are just soooo constructive around here. It was a simple question, sarcasm wasn't asked for...
post #6 of 12 (permalink) Old 11-30-2019, 05:35 PM
ofelas.5z's Avatar
Oh dear. I was just trying to save you some hard earned $.
I'll try again -
" Your (cast aluminum, hopefully) deep pan should stiffen up the case a bit.
Look to sloppy shaft splines and/or bad u-joints as well".
Better?
The Following User Says Thank You to ofelas.5z For This Useful Post:
post #7 of 12 (permalink) Old 11-30-2019, 05:41 PM Thread Starter
jroyster06's Avatar
Yes. The cover on the case is stock. Reason for the post was I came across the video and was perplexed as I havenít seen a case break. It seems like snake oil but I figured I would gather other opinions as well...
post #8 of 12 (permalink) Old 12-06-2019, 09:21 AM
7492's Avatar
So sensitive.......
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is offline
post #9 of 12 (permalink) Old 12-06-2019, 10:37 AM
Why does everything turn into a pissing contest around here - its honestly funny. Been a part of car / truck forums for two decades almost now, and have never seen it like this
Jkysh is offline
post #10 of 12 (permalink) Old 12-06-2019, 10:44 AM
ofelas.5z's Avatar
Deezul Racketsz oneupmanship...
post #11 of 12 (permalink) Old 12-06-2019, 11:47 AM Thread Starter
jroyster06's Avatar
Ive been on this forum for over 10 years. Im not so "sensitive." I just find it obnoxious that new guys come on here with no knowledge and they look to us for help. Just like we did when we got into this side of things.
Now when people get on here because they have no idea what they need or want, we belittle and point fingers, make sly comments and say USE THE SEARCH FEATURE...
This forum never used to be this way. It saddens me how active it is now days. Years ago this thing was rolling 24/7 with people posting all hours of the night..
This forum now seems much slower than some of the other ones out there. Which stinks because this is my go to forum. The only thing I can attribute it to is the tone of some of these responses and these guys with 2 or 3 posts that never come back. Who would want to stay on a forum where you come for help, and get slammed?
Case-in-point this post. I had no knowledge previously of a 68fre case cracking, so I did what I always do. Posted about it because I genuinely had NO idea... and instead of talking about truth in the matter, this thread derailed hard because of obnoxious attitudes...
post #12 of 12 (permalink) Old 12-09-2019, 05:00 AM
I do a lot of tech support for transmission shops, all types of calls. The 68RFE is a common issue with cracked cases. Most common issues are u-joints and abuse. I personally have not used the brace but have heard mixes reviews. My good friend has one and swears by it because he had 2 case crack. After the brace no issues but he also replace front drive shaft at the same time.
Jarad Trans Parts Now
jroyster06 likes this.
TransmissionPartsNow is offline
