2018 6.7 liter sudden blue exhaust smoker - Dodge Cummins Diesel Forum
 7Likes
post #1 of 30 (permalink) Old 11-19-2019, 07:59 PM Thread Starter
All, I deleted my 2018 Cummins at 8000 miles back in April using the raceme ultra tuner along with 4” diamond eye exhaust and egr delete with banks ram tube.
the truck now has 16000 miles, this past weekend while using truck in very cold conditions so I turned on the exhaust brake to assist with heating the engine, soon there after I noticed the truck blowing blue smoke, I changed the oil (shell rotella 15-40) and Fuel filters, about 1500 miles ago.
Any thoughts on what could be causing this ?
Mrnpstr is offline
post #2 of 30 (permalink) Old 11-19-2019, 08:59 PM
BobSagetIsGod?'s Avatar
The cold.
'10AIRSOLD
'14AIR-FUELSOLD
'17
BobSagetIsGod? is offline
post #3 of 30 (permalink) Old 11-19-2019, 09:35 PM Thread Starter
Was thinking that, could bad fuel cause this also
Mrnpstr is offline
post #4 of 30 (permalink) Old 11-19-2019, 09:36 PM Thread Starter
Oil pressure and temp is normal
Water temp is normal
Mrnpstr is offline
post #5 of 30 (permalink) Old 11-19-2019, 09:42 PM
b.lee's Avatar
If this is the first time its been at high idle in the cold I would just monitor it the next few times you start it up in the cold and see what happens when the high idle starts.
If it continues you may have a tuning issue.. ?
2012 2500 Cummins 4x4 - Mega
Laramie, Auto, EFI Live
b.lee is offline
post #6 of 30 (permalink) Old 11-19-2019, 09:42 PM Thread Starter
Also forgot to mention, driving last two days with temps in 40s and 50s and still smoking
Mrnpstr is offline
post #7 of 30 (permalink) Old 11-20-2019, 12:03 AM
Following
abishoff is offline
post #8 of 30 (permalink) Old 11-20-2019, 12:25 PM
Check to turbo intake for oil from the ccv filter. You might also have a bad seal on the turbo which could also cause a leak. Check the turbo for oil to make sure.
2013 2500 6.7 cummins crew cab. white and stock as can be
using Tapatalk
2013 RAM 2500 diesel 6.7 Bighorn Crew Shortbed 4x4 in white. As of 7/21/16 16,100 miles.
cwendel is offline
post #9 of 30 (permalink) Old 11-20-2019, 01:48 PM
using Tapatalk
What is wrong with some oil from the crank case? Of course there will be some at the turbo.
'10AIRSOLD
'14AIR-FUELSOLD
'17
post #10 of 30 (permalink) Old 11-20-2019, 06:18 PM Thread Starter
Ok, I’ll check the inlet of the turbo, I shouldn’t have crankcase oil at 16k.
I was also thinking about PCV valve and or bad tank of fuel.
Your thoughts?
Mrnpstr is offline
post #11 of 30 (permalink) Old 11-20-2019, 07:36 PM
You have no PCV valve. And there will be oil from the crank case at the turbo inlet. It’s a combination of the tuning and the temperatures. Your truck is fine.
N of 60 and INLINE_6.7 like this.
'10AIRSOLD
'14AIR-FUELSOLD
'17
post #12 of 30 (permalink) Old 11-21-2019, 11:02 AM
Oil at the turbo inlet is from the ccv filter. If you have oil there, there will also be oil in the intercooler. Not a good condition. And 40-50F is not all that cold if it still smokes once the engine warms up. It seams the OP is smoking when warm too.
Blue smoke means oil is burning that should not be burned. Like when you have bad valve guide seals.
Now, as long as the smoke is only at startup and goes away once warm it is okay. But if it continues when warmed up then you need to look at issues.
And yes, the ccv filter can be full of oil and need changing by 16000 miles. Mine was full by 24000 and started to oil the intercooler.
using Tapatalk
Dok_M and INLINE_6.7 like this.
cwendel is offline
