Transfer case/front end drive train question. - Dodge Cummins Diesel Forum
 3Likes
  • 3 Post By Saintly
LinkBack Thread Tools
Old 11-18-2019, 11:19 PM Thread Starter
Need some help. Have 2012 2500 slt 6.7 4x4. Getting a vibration and slight growl under the driver's side floorboard. Checked all u- joints an they are good. The one thing I have noticed is the front driveshaft is spinning while not in 4 wheel drive. I thought that it is not supposed to do that or am I wrong? I will take any suggestion.
Thanks everyone.
Sent from my SM-T580 using Tapatalk
bigdaddy31820 is offline
Old 11-18-2019, 11:22 PM
By growl, do you mean sounding like a skateboard on asphalt?
Sent from my SM-N976V using Tapatalk
english03122005 is offline
Old 11-18-2019, 11:34 PM
Duelly Dad's Avatar
Have you ever changed your transfer case fluid
3500 MegaCab Dually 4X4
6.7L Aisin Trans
4:10 Gears
385 Hp 930 Tq
Duelly Dad is offline
Old 11-19-2019, 12:26 AM
Cummins Freak
SRich12's Avatar
On a 2012 the front drive shaft turns all the time!!! you could pull the front drive shaft to eliminate it or it could be a wheel bearing or axle u joint.
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli coils/295 Toyo AT2's /Full Console swop w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is offline
Old 11-19-2019, 01:18 AM
DirtyOleMechanic's Avatar
SRich is right. The front driveshaft is always turning on that model. The front axles are disengaged until you put it in 4x4, then a motor engages them. The u joints on those front axles are bad about going out. The growl noise makes me lean more towards a bad wheel bearing. You can see the axle u joint with the wheel off or laying down on a creeper with the tire turned. I mainly see the needle bearings fall out of the caps. Gotta get the wheel hub off to take the shaft out so you could check them both at the same time.
DirtyOleMechanic is offline
Old 11-19-2019, 07:17 AM
Saintly's Avatar
Originally Posted by DirtyOleMechanic View Post
... The front driveshaft is always turning on that model. The front axles are disengaged until you put it in 4x4, then a motor engages them. ......
No, not on the 2012 model like the OP has.
There is no disconnect whatsoever for the front axles on that one, it is pre-cad.
The driveshaft is always turning when your moving, but that is because the front axle is dragging it along for the ride.
2012 3500, Dually, 4X4, G56, reg cab, Smarty, Severe duty fuel filter kit, Moog tie rod ends & torklift stabiloads, Ford/Dana 60 manual locking hubs, Dynatrac/EMF balljoints.
Saintly is offline
Old 11-19-2019, 09:53 PM
lpennock's Avatar
If your double cardin joint hasn't been greased your centering yoke could be ready to seize. The centering yoke is supposed to be greased every 7500 miles.
Sent from my SM-T350 using Tapatalk
Leonard Pennock AD7AS
2006 Ram 3500 4x4 6sp -- Sold
2018 Ram 3500DRW 4x4 Aisin, Stock for now
lpennock is offline
Old 11-19-2019, 10:54 PM
Oops. You’re right about that. Either way everything else is still accurate.
Old 11-19-2019, 10:56 PM
That’s true. I think they recommend greasing it at every oil change.
Old 11-20-2019, 12:53 AM Thread Starter
Yes it does sound like a skateboard on asphalt.
Old 11-20-2019, 12:57 AM Thread Starter
Okay will start with u joints and wheel bearing check this weekend. Also will check the transfer case fluid. Thank for the suggestion.
Old 11-20-2019, 12:58 AM Thread Starter
Will check that also this weekend.
Thanks
