New turbo still have exhaust brake issues - Dodge Cummins Diesel Forum
 4Likes
post #1 of 43 (permalink) Old 11-11-2019, 08:04 PM Thread Starter
I replaced the stick turbo on my deleted 11 because a clip broke and jammed up the nozzle ring. Everything was working good until that happened. I replaced it with a modified he351ve 67/67. For some reason I canít get the exhaust brake to work correctly. If Iím going down a hill with the exhaust brake on it will kick in like it should but you accelerate and it will not kick out. The only way to get it off is to come down to 25-30 mph and it kicks out on its own. Even if you push the button it wonít go off. The other issue Iím having is if you are under hard acceleration with the exhaust brake off it will just kick itís self on while your are accelerating. Any ideas? I have replaced the maf sensor. And recalibrated the vgt actuator 4 or 5 times.
1995 dodge ram 1500 5.2 gasser
2007 dodge ram 2500 5.9 cummins
2011 ram 2500 6.7 cummins.
BigRedRam95 is offline
post #2 of 43 (permalink) Old 11-13-2019, 07:53 AM
Sounds like the vgt is sticking. Either bad turbo or bad actuator.
2013 2500 6.7 cummins crew cab. white and stock as can be
using Tapatalk
2013 RAM 2500 diesel 6.7 Bighorn Crew Shortbed 4x4 in white. As of 7/21/16 16,100 miles.
cwendel is offline
post #3 of 43 (permalink) Old 11-16-2019, 01:59 AM Thread Starter
using Tapatalk
Itís a brand new turbo so Iím sure itís not sooted up. Not totally sure if itís a actuator or not because it worked fine on the stock turbo when I took it apart. Is their a way to run a true test on the actuator?
post #4 of 43 (permalink) Old 11-16-2019, 02:57 AM
Cummins Freak
SRich12's Avatar
Originally Posted by BigRedRam95 View Post
It’s a brand new turbo so I’m sure it’s not sooted up. Not totally sure if it’s a actuator or not because it worked fine on the stock turbo when I took it apart. Is their a way to run a true test on the actuator?
You re used the actuator off your old turbo?? why????? Did you calibrate it and if so what did you use? AlfaOBD will let you test and calibrate the actuator…..
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swap w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is online now
post #5 of 43 (permalink) Old 11-16-2019, 09:10 AM Thread Starter
Originally Posted by SRich12 View Post
You re used the actuator off your old turbo?? why????? Did you calibrate it and if so what did you use? AlfaOBD will let you test and calibrate the actuatorÖ..
Well first I used my factory actuator and calibrated it with my snapon scanner. After a few days of having problems with it and redoing the calibrating a few times even though it passed every time. I bought another actuator off of someone that tested good and stuck it on. And still have the same problem. The turbo builder said they had one doing that and it was the maf sensor. So I replaced that still no change.
post #6 of 43 (permalink) Old 11-16-2019, 11:52 AM
There is a way but the tool. Is about a $1000.
Have you tried reloading the delete tune? The more info I hear the more it sounds like the tune is messing it up. You may also need a different tune for the turbo, as well, to adjust for the different air flow.
Also, how old are the batteries? If they are old and one has a bad cell, the truck will start and run but you will have all kinds of odd stuff happening.
using Tapatalk
cwendel is offline
post #7 of 43 (permalink) Old 11-16-2019, 12:50 PM Thread Starter
using Tapatalk
What tool can you use to test? Iím using a snapon to calabrate. I have reloaded the tune once. The batteries were replaced over the summer and I load tested them when I started having this issue. Hoping I can find something out. Been without a truck since sept.
post #8 of 43 (permalink) Old 11-16-2019, 05:35 PM Thread Starter
So I just plugged in my snap on scanner and looked at the live data. When I go to exhaust pressure it shows 0 no matter if I rev it up or not. I then took a meter and checked at the sensor. One wire has 5 volts one is ground and the other is return to the pcm. Truck running in warm up mode and high idle I had 3.1 volts return to the pcm.
post #9 of 43 (permalink) Old 11-16-2019, 05:59 PM
the man in black's Avatar
Do you get normal boost under acceleration? Wouldnt be the first time an exhaust pressure sensor went bad without throwing a code.
cwendel likes this.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #10 of 43 (permalink) Old 11-16-2019, 06:00 PM
And be sure the tube feeding the sensor isnt plugged.
post #11 of 43 (permalink) Old 11-16-2019, 07:33 PM Thread Starter
Tube is not plugged for sure. Yes normal boost until I ge up in the boost and it will through the exhaust brake on while still on the throttle.
post #12 of 43 (permalink) Old 11-17-2019, 11:27 AM Thread Starter
I unplugged the actuator and drove it around for about 30 min or so went to a few lumber yards so it went through a few key cycles and never popped up any cel I was think it would show something. I thought it would at least show a actuator code with it unplugged.
