G56 trans fluid change - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 09-10-2019, 07:15 PM Thread Starter
2010 3500 SRW G56 with 135000 miles looking to change trans fluid. Looking for what oil to put in it.
Martinwelch2006 is offline
post #2 of 13 (permalink) Old 09-10-2019, 10:00 PM
K9Kodi's Avatar
If your trying to stay stock, they come shipped with atf+4. Many folks swap to what Mercedes, the maker of the tranny call for, an actual manual transmission gear oil. I think delvac 50 or something along those lines. If you do a search it’s been covered a lot but I’ll juat be going with a manual tranny gear oil when time comes.
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is online now
post #3 of 13 (permalink) Old 09-11-2019, 03:25 AM
JRD
Like K9Kodi said, I changed mine from ATF+4 to Delvac 50 when I swapped mine out. I'd rather run what the actual tranny manufacturer recommends and not what Dodge just put in there out of convenience.
Sent from my SM-G965U using Tapatalk
2011-2500 Big Horn SRW Mega 4x4 G56 Deleted EFI Live by Gordon Lindamood
JRD is offline
post #4 of 13 (permalink) Old 09-11-2019, 04:58 PM Thread Starter
Is it true if you add an extra qt it helps with that low rpm roar from the gears in the transmission?
post #5 of 13 (permalink) Old 09-11-2019, 05:57 PM
K9Kodi's Avatar
I have read that and I have also read that adding a qt can cause it to run warm.
post #6 of 13 (permalink) Old 09-11-2019, 10:39 PM
Peterman9000's Avatar
Helps some but still kinda loud. You get used to it.
'16 2500 Laramie | CCLB | Max Steel | G56 | Anarchy EFI live | Valair DD
Peterman9000 is offline
post #7 of 13 (permalink) Old 09-12-2019, 01:13 AM
akhr's Avatar
Yes adding a extra quart makes it run hotter, experienced this myself. Ran Castrol syntrans, when dual mass failed I overfilled by a quart after doing the clutch and notice it ran about 15-20 degrees warmer then it did before. Dumped a quart out and back to normal. I am running a trans cooler as well. I’ll upload a pic of the fluid I put in mine, shifts better in the cold then mobil 50 and is also recommend by mb for this transmission.
akhr is offline
post #8 of 13 (permalink) Old 09-12-2019, 01:24 AM
K9Kodi's Avatar
Did you do a write up on the cooler?
post #9 of 13 (permalink) Old 09-12-2019, 01:49 AM
akhr's Avatar
Nope, because these guys already did and did a better job then I ever could. I am using a different oil and did my cooler install a bit different. Mounted my pump and cooler where my def tank use to sit. Also used a Napa transmission filter with no bypass valve and a Napa remote filter kit.
http://www.trucktrend.com/how-to/tra...transmissions/
ID:	856389   Click image for larger version
ID:	856391   Click image for larger version
ID:	856393   Click image for larger version
akhr is offline
post #10 of 13 (permalink) Old 09-12-2019, 02:21 AM
K9Kodi's Avatar
Do you believe it is worth it? Makes a difference?
post #11 of 13 (permalink) Old 09-12-2019, 02:25 AM
K9Kodi's Avatar
Also how does yours kick on? User input only or when it hits certain temp? Or just always on?
post #12 of 13 (permalink) Old 09-12-2019, 12:17 PM
akhr's Avatar
Makes a huge difference for sure, before the cooler, trans was easily getting over 200 degrees and when hot outside was over 235. Now even on the hottest day (over 100 outside temp) I’ll be around 190 and usually sits around 160 when about 70 outside temps. I have a switch and pretty much just turn it on once the truck is running. If it’s hot outside and the trans temp is up I’ll let the cooler run while the truck is off (fueling and making a pit stop). I could say it drop temps by about 40 to 50 degrees. Worth it IMO
akhr is offline
