Exhaust brake issue - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-24-2019, 01:55 PM Thread Starter
Idafrog's Avatar
Exhaust brake issue
2011 2500 with 73,000 miles. Recently did a full EGR delete, Throttle valve delete, 5" Flo Pro exhaust, and H&S XRT Pro tuner, 3k ago. All is good and well. Pulling 36' 5th wheel toy hauler, 4 horse trailer, daily driving, whatever.
That is until yesterday. Was coming back home with 1 horse in the trailer @70mph, and let off the throttle as normal and exhaust brake worked fine until I went to get back on the throttle. Had no power and just smoked the out of the car behind me. Shut off the EB with the dash switch and all smoke quit and had just fine power again. I messed with it a few more times on the trip and sometimes it would do the same thing, but other times it worked as normal. I don't have a monitor to watch EGT's and such so no clue where that was. Trans temp, engine temp, etc were fine.
What and where do I go from here?
Thanks.
2011 2500 Mega Laramie, auto, mineral gray with shiney stuff.....
Idafrog is offline
post #2 of 6 (permalink) Old 06-25-2019, 10:40 AM
ZOP
Decoder Ring Specialist
ZOP's Avatar
So unless you replaced the VGT it sounds like your VGT is sticking. The other possibility is the exhaust pressure sensor. Both are same answer.... Clean or replace. There's no separate exhaust brake, the button just instructs the ECM to close the VGT almost completely when in braking. If the EB hasn't been used much the last section of the VGT can be caked with soot (or get rusty as happened with mine for a bit due to the truck sitting for long periods)
2011.5 6.7L HO 3500 4x4 ST Crew LB 3.73 SRW Rear 68RFE H&S MM w/ Custom Tuning, B&W+Companion
60 Gal RDS Tank/Tool PacBrake Bags
2012 Fuzion FZ305 35' Toy Hauler (no, the Ford does not pull this...)
ZOP is offline
post #3 of 6 (permalink) Old 06-26-2019, 04:57 AM
BFD
BFD's Avatar
Mine started acting up at 118 thousand miles and I got a code that indicated it was a mechanical problem. I took it apart and the hub that the vanes are attached to had a wear groove and that's where it was hanging up. I replaced the VGT with a fixed vane and inline exhaust brake and it is better in every way. Craig
2012 CCLB 4wd dually, 3.73, 68rfe, Fass, Deleted, EFI engine/trans tuning, BD IH SXE 363/80/.91 w/ebrake, 4" turbo back/51" Quiet Tone. DD and tow vehicle.
Olde too soon... Schmart too late!
BFD is offline
post #4 of 6 (permalink) Old 06-26-2019, 10:58 AM Thread Starter
Idafrog's Avatar
Thanks for the info folks. Going to try cleaning it and get it recalibrated and see what that does.
Hope it works as I am not in the budget for a new turbo just yet.
Idafrog is offline
post #5 of 6 (permalink) Old 06-26-2019, 12:37 PM
N of 60's Avatar
You will be in for a replacement. Trust me
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #6 of 6 (permalink) Old 07-24-2019, 11:31 PM
mrbreeze's Avatar
Could un plug the turbo also...my work truck was doing this on start w/out turning on eb been unhooked the last 30k sucks but it's a cheap bandaidūü§∑
mrbreeze is offline
