Fuel Injector Failure When it Rains - Dodge Cummins Diesel Forum
 3Likes
post #1 of 15 (permalink) Old 06-07-2019, 01:19 PM Thread Starter
jgruberman's Avatar
It was raining the other day and the truck is driving on the freeway fine. I took an exit and my check engine light came on and the truck got shaky like it was misfiring(just describing the shake not the cause), and I pulled over into the nearest parking lot. I waited 30 min, cleared the CEL, and everything was fine and drove away.. it had also stopped raining when I left.
The CEL codes were Fuel Injector 2 and 3 Open(two different codes).
I've had some weird rain issues in the past, so I assume there is some sort of connector loose somewhere or exposed and water gets in when it rains because if it's not raining, I NEVER have any issues with the truck and it's always some weird engine error. I think last time it was Cyl 2 and 3 misfire.
Does anyone know somewhere I can start looking to see if there are any exposed connectors that specifically may be causing similar issues when they get wet?
P.S. The first time this happened, I think I was behind a semi(also in the rain) and it was shooting water all over the front end so maybe there's a connector or something behind the grill?
Thanks in advance!
Sent from my SM-G975U using Tapatalk
jgruberman is offline
post #2 of 15 (permalink) Old 06-08-2019, 09:02 PM Thread Starter
jgruberman's Avatar
Any ideas?
post #3 of 15 (permalink) Old 06-08-2019, 10:06 PM
the man in black's Avatar
Start by checking the injector harness.
URDiesel likes this.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #4 of 15 (permalink) Old 06-09-2019, 05:25 AM
K9Kodi's Avatar
There is a large body electrical harness on the drivers side. I believe it’s in the are on the drivers side, behind the wheel well plastic near where where the metal wheel arch runs into the quarter panel. I have seen trucks show symptoms like yours when the harness is not completely connected or tight enough to resist water.
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is online now
post #5 of 15 (permalink) Old 06-09-2019, 05:37 AM
K9Kodi's Avatar
I believe if I remember last time I saw it, it’s behind the plastic wheel well liner
post #6 of 15 (permalink) Old 06-09-2019, 09:13 AM Thread Starter
jgruberman's Avatar
Originally Posted by K9Kodi View Post
I believe if I remember last time I saw it, itís behind the plastic wheel well liner
Awesome, and that's which harness?
post #7 of 15 (permalink) Old 06-09-2019, 12:34 PM
There is a large body electrical harness on the drivers side. I believe itís in the are on the drivers side, behind the wheel well plastic near where where the metal wheel arch runs into the quarter panel. I have seen trucks show symptoms like yours when the harness is not completely connected or tight enough to resist water.
yeah, isnt that a dumb place for a connection.
jgruberman likes this.
ar_mcadams is offline
post #8 of 15 (permalink) Old 06-09-2019, 03:14 PM
K9Kodi's Avatar
I don’t know what harness it is specifically but I do know people in the past have had sporadic issues like you described in wet weather. You can’t miss it. It’s a prettt big connector
post #9 of 15 (permalink) Old 06-09-2019, 11:49 PM
ramrocker's Avatar
The Powertrain Control C1 that runs up to the engine has injector(s) control.
Took a look at the 3 connectors I have behind the driver wheel well.
I'd also read about water splash causing problems for the connectors back there, especially the transmission one.
Lowest one to the ground is the Transmission I-255 connector.
Then above it is I220 Body > Chassis 34 Pin. It has Fuel Pump, Fuel Level, Rear Lights, Locks, Trailer Tow, Park Assist, etc. And I221 Body > Chassis 4 Pin Trailer Tow Park Lamp & 12V
I220 pinout:
2017 Ram 3500, 6.7 CTD, ASIN, DRW 3.73, CTS2, B&W Manual Slider, Truxedo PRO X15 Tonneau
ramrocker is online now
The Following User Says Thank You to ramrocker For This Useful Post:
jgruberman (06-10-2019)
post #10 of 15 (permalink) Old 06-10-2019, 01:22 PM Thread Starter
jgruberman's Avatar
Would it help to put some dielectric grease in the connector plug to keep water out?
xxwabbit likes this.
post #11 of 15 (permalink) Old 06-10-2019, 02:13 PM
N900WM's Avatar
This happened to me today!
I have been having intermittent drivability issues with the exact description. Mis-fires and skips. Dealer found no issues as of course it worked fine for them.
Today in the rain, it did it again, I drove to the dealer and they were finally able to plug in while it was acting up. NO CEL but it did have stored codes for all but one injector. They tell me there is a bulletin which requires that the injectors be replaced.
18 Tungsten CC 4x4, black on black.
BD Throttle Booster. Western V Plow
N900WM is offline
post #12 of 15 (permalink) Old 06-10-2019, 03:40 PM
ramrocker's Avatar
Well, I looked at a TSB for 2017.
TSB 09-003-17 for 2017s made from 11-23-2016 thru 3-17-2017 for Fuel Injector metal wiskers.
N900WM (06-12-2019)
