Fuel Injector Failure When it Rains - Page 2 - Dodge Cummins Diesel Forum
 5Likes
post #13 of 16 (permalink) Old 06-12-2019, 08:08 AM
N900WM's Avatar
Ramrocker,
Thanks for the Bulletin. That's the one my dealer is addressing. So far I've missed two trips due to this issue.
They still don't have the new injectors and cant tell me when it will be finished.
18 Tungsten CC 4x4, black on black.
BD Throttle Booster. Western V Plow
N900WM is offline
post #14 of 16 (permalink) Old 06-12-2019, 08:59 AM Thread Starter
jgruberman's Avatar
Originally Posted by jgruberman View Post
Would it help to put some dielectric grease in the connector plug to keep water out?
Sent from my SM-G975U using Tapatalk
Anyone know if this would help?
jgruberman is offline
post #15 of 16 (permalink) Old 06-12-2019, 12:27 PM
ramrocker's Avatar
Dielectric grease helps. I put it inside a connector on the pins if I have one apart where the connector could get water on/in it from splash/spray.
The connectors rely on the seals around each wire as well as the connector's mating seal.
Permatex 22058, Loctite 495549, was used on the spark plug boots.
Used to see dielectric grease inside connectors on older pickups.
Haven't noticed grease inside the one or two connectors I've had apart on the Ram.
I figure the trick would be getting the grease deep enough into the connector cavities to keep water from length of the connector metal.
1st pict is just of my trailer tow while I had it apart to add a tap splice on the wire. I added some grease to those pins.
Probably need to pull the bumper and bed T connector & add some in them as that's a common place for corrosion.
2nd is from a transmission problem post https://www.cumminsforum.com/forum/4...ngagement.html
Name:	Connector & Wire w Seal.jpg
ID:	849785   Click image for larger version
Name:	Transmission Connector Pin.jpg
2017 Ram 3500, 6.7 CTD, ASIN, DRW 3.73, CTS2, Truxedo PRO X15 Tonneau
ramrocker is offline
post #16 of 16 (permalink) Old 06-24-2019, 09:13 AM Thread Starter
jgruberman's Avatar
I took apart the giant connector under the wheel well and the inside was bone dry... I don't understand how this is happening. Last night, it was 4 injectors that "were open" and the truck drove like . Turned it on this morning and everything was fine.
