2016 6.7 Cummins Screeching Sound (Video) - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 05-21-2019, 12:53 AM Thread Starter
Hey Guys,
I have a 2016 Ram 2500 6.7 Cummins with roughly 35,000 miles. My truck makes a screeching sound when I start it up when its cold. It goes away when it gets up to regular operating temp or I drive it. I had a guy at one dealership tell me it could be the fan clutch and another guy at another dealership tell me its not the fan clutch and he is not sure what it is. All maintenance has been consistently performed. I really need to get this fixed so any and all suggestions would be greatly appreciated. I attached a video. Thanks in advance Guys!
Link To Videos - https://drive.google.com/open?id=1Uu...sd2zc9tTU_UIfP
2016 Ram 2500 - 6.7 Cummins - Icon 4.5 Inch Lift - 325x50x22r - 4.10 Axle Ratio
S&B Cold Air Intake
Rhoades1 is offline
post #2 of 13 (permalink) Old 05-21-2019, 08:55 AM
Walker111's Avatar
For some reason I cant play the video. Truck should be under warranty...let the dealer fix it.
16 CTD 2500 Bright White Crew Cab
Walker111 is offline
The Following User Says Thank You to Walker111 For This Useful Post:
Rhoades1 (05-21-2019)
post #3 of 13 (permalink) Old 05-21-2019, 01:21 PM Thread Starter
Hi Walker111, thanks for the reply! The dealership says they don't hear anything off about the way it sounds. When you hear the video there is clearly something off about the way it sounds. I added a link so you can play the videos. If that doesn't work I will try adding a youtube video. Thanks again for all the help!
Link To Video - https://drive.google.com/open?id=1Uu...sd2zc9tTU_UIfP
S&B Cold Air Intake
Rhoades1 is offline
post #4 of 13 (permalink) Old 05-21-2019, 03:30 PM
maybe its the belt tensioner
ar_mcadams is offline
The Following User Says Thank You to ar_mcadams For This Useful Post:
post #5 of 13 (permalink) Old 05-21-2019, 08:30 PM
Ouch. Doesn't sound good. Water pump? Honestly a noise like that should be easy to diagnose it's source with a mechanics stethoscope.
17 2500 CCSB Longhorn, Steel/Saddle,Calibrated Power tune, 68rfe tuned
01 2500, QCSB 4x4, Fass, 3rd gen brakes, 4th gen steering, Revmax fully built, Blue Chip VP44, Edge Comp
17Ram2500 is offline
The Following User Says Thank You to 17Ram2500 For This Useful Post:
post #6 of 13 (permalink) Old 05-21-2019, 10:06 PM Thread Starter
Thanks ar_mcadams, I will research it
S&B Cold Air Intake
Rhoades1 is offline
post #7 of 13 (permalink) Old 05-21-2019, 10:15 PM Thread Starter
Thanks for the reply 17Ram2500. The water pump was replaced under the recall and it still makes that sound. =/
S&B Cold Air Intake
Rhoades1 is offline
post #8 of 13 (permalink) Old 05-21-2019, 11:16 PM
That sounds like it might be the idler pulley, which is the top pulley on the serpentine belt system. They seem to wear and get wobble in them quite quickly. When I did the fan clutch hub conversion on my 11 when the truck had about 67,000 miles the idler had to be replaced because it was worn and loose, but it didn't sound quite like your truck does. That would be the first place I would check if it were my truck.
Den52 is offline
The Following User Says Thank You to Den52 For This Useful Post:
Rhoades1 (05-22-2019)
post #9 of 13 (permalink) Old 05-22-2019, 12:12 AM Thread Starter
Thanks den52, I really appreciate the help. I will check it and let you know if that is it.
S&B Cold Air Intake
Rhoades1 is offline
post #10 of 13 (permalink) Old 05-22-2019, 01:20 AM
UTDiesel's Avatar
If you don't have a stethoscope, you can use a piece of 1/4"-1/2" tubing about 18" long, one end to your ear, other end poking around. When you find the source you'll hear it.
2010 CCSB - 3" Carli Lift & Control Arms - 35" BFG ATs on 17x9 Fuels - H&S Mini Maxx - Line-X Rockers and flares
UTDiesel is offline
The Following User Says Thank You to UTDiesel For This Useful Post:
post #11 of 13 (permalink) Old 05-22-2019, 01:32 AM Thread Starter
Thanks utdiesel. I will try that and see what I can find
S&B Cold Air Intake
Rhoades1 is offline
post #12 of 13 (permalink) Old 05-22-2019, 08:23 AM
Don_T's Avatar
That sound seems to be at a less frequent rate than the engine RPM. I think it most likely is something running off the accessory belt. I would take it loose and check the idler pulley closely for looseness or roughness and if that isn't it, check each accessory for the same issues.
2019 Ram 3500 Crew Cab Long Bed
Don_T is online now
The Following User Says Thank You to Don_T For This Useful Post:
Similar Threads
Ideas to consider when soundproofing your truck. country_hick 89-93 Non-Powertrain 32 04-23-2016 07:19 PM
Turbo screeching sound Dixiedream 3rd Gen. Powertrain 4 12-15-2015 02:35 PM
Ideas to consider when soundproofing your truck. country_hick 94-98 Non-Powertrain 16 11-06-2014 07:16 PM
need to diagnose this sound (with video) superman279 3rd Gen. Powertrain 19 02-20-2011 09:45 AM
5" Turbo back, from Expandit. Video of sound clip Blood 98.5-02 Performance Parts Discussion 2 02-12-2011 02:29 AM
