Dodge Cummins Diesel Forum
Dodge Cummins Diesel Forum (https://www.cumminsforum.com/forum/)
-   4th Gen Powertrain (https://www.cumminsforum.com/forum/4th-gen-powertrain/)
-   -   12" AAM rear diff 'anti spin' (https://www.cumminsforum.com/forum/4th-gen-powertrain/2500351-12-aam-rear-diff-anti-spin.html)
BTGreen 05-17-2019 03:22 PM
You have a clutch type limited slip rear differential.
You do not have any helical/torsen/magic wizardry differential.
You need to use a friction modifier or approved lubricant or clutch damage will result.
Jhenderson 05-17-2019 09:45 PM
Iíve got a months salary that says Iíve pulled apart more clutch type diffs than youíve ever seen. Many of them came to me because of complaints of chattering, sticking, or noisy rear ends. This comes from a lack of friction modifier, (for GM it was a type of fish oil) not a lack of lubrication. Not one of them had damaged clutch plates. After initial inspection the repair was to add the modifier, go to an empty parking lot and do tight circles in both directions under light throttle until the clutch packs freed up. Once again, no damage, just a poorly functioning limited slip.
esminbritt 05-23-2019 10:04 PM
Originally Posted by Lins (Post 28983823)
Are we having brain farts here?
Yes. Yes we are
Lins 05-23-2019 10:06 PM
Yes. Yes we are
Ok just checking.
esminbritt 05-23-2019 10:06 PM
Ok. So my pig has clutches. Since it is an AAM, would that make it a Tracrite PC?
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
