Front drive shaft removal - Page 2 - Dodge Cummins Diesel Forum
 1Likes
post #13 of 17 (permalink) Old 04-16-2019, 05:28 AM Thread Starter
Ryan2242's Avatar
Well as I expected. Dealer said it's normal and wouldn't be covered under warranty regardless. Due to the lift I put on the vehicle (BDS 4")
Funny thing is this problem was present prior to installing the lift and they have that on record.
I am getting an alignment done today and sending in the driveshaft to get balanced.
Ryan2242 is offline
post #14 of 17 (permalink) Old 04-16-2019, 08:03 AM
gotsig21's Avatar
I would normally say its something to do with the truck lifted but if it was doing it prior to being lifted than probably not the case.
I found on my previous Power Wagon I was getting some wierd driveline vibes...no shop could figure out where it was coming from, everything looked good as far as every place was concerned. Can't remember what caused to me to try it...but I took the shaft itself apart, i.e. separated the slip portion. From the factory it came with hardly any grease on the splines...I greased the hell out of it, put it back together and it completely fixed my problem.
Its a little surprising that there isn't some sort maintenance schedule for this...on every aftermarket drive shaft I've had with the slip built into it they come with grease fittings so you can keep the splines greased up.
13' With 6" Thuren lift, Stage 6 King 3.0's front and rear, alien arms, trussed front end, dynatrac ball joints, king steering stabalizer, thuren track and sway bar, boogie bumps, 17" Tail Ready Bead lock wheels w/40" toyos. 4.56's w/front ARB
gotsig21 is offline
post #15 of 17 (permalink) Old 04-17-2019, 09:42 AM
I haven't taken mine out yet, but a local mechanic who specializes in these trucks told me that the bolts are loctited and I may have to heat them to get them to release. I'm a bit nervous about trying because I don't like to use heat that close to a seal.
uglydukwling is offline
post #16 of 17 (permalink) Old 04-17-2019, 09:47 AM
gotsig21's Avatar
They're fine...dont need heat, just slow steady pressure
Sent from my SM-G950U using Tapatalk
gotsig21 is offline
post #17 of 17 (permalink) Old 04-17-2019, 06:16 PM
I’ve never had to heat them either. Just be sure your torx bit is fully seated and square.
Jhenderson is offline
Similar Threads
03 Cummins Front Drive Shaft Noise When Not Engaged? Callumpickles10 2003/2004 General Discussion 8 06-17-2017 05:37 PM
Front drive shaft removal 2012 Jimmy_1911 4th Gen Powertrain 2 11-19-2014 09:08 PM
Front drive shaft removal hillbilli 3rd Gen. Non-Powertrain 6 10-21-2013 10:33 PM
Front drive shaft upgrades? Geezir 3rd Gen. Powertrain 15 11-19-2011 09:04 PM
