6.7 Cummins Ticking 2010 Dodge - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By N of 60
post #1 of 5 (permalink) Old 04-12-2019, 06:06 PM Thread Starter
CumminsBoyTx89's Avatar
Hey guys, I need some insight of possible options to look at, it's an 2010 Dodge 6.7 Cummins with almost 127k on it, this morning I noticed a slightly loud tick coming from what seemed to be the driver side.
When I drove it to work at lights it had seemed like it was not there but then again wasn't paying too much attention to it. Going to see if it does it again this evening when I get off work.
Does anyone have any advice on what I could look at?
Sent from my QS5509A using Tapatalk
CumminsBoyTx89 is offline
post #2 of 5 (permalink) Old 04-12-2019, 10:37 PM
N of 60's Avatar
I have never owned a Cummins that didn’t have a tick.
Other than confirming your valve lash clearances that can cause a noisier motor.
gsbrockman likes this.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.80 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #3 of 5 (permalink) Old 04-13-2019, 10:10 AM
My 2016 had a tick so loud when cold i thought it had a knock, had valve adjustment done, now hardly ticks
marks cummins is offline
post #4 of 5 (permalink) Old 04-15-2019, 11:09 PM
El Pozzinator's Avatar
IIRC, first valve adjustment should be performed at ~100,000 miles, and checks should be done every 50,000ish thereafter.
Edit:
If your truck is emissions stock, Ive seen many recommendations to stick with factory spec 0.012 intake and 0.026 exhaust clearance. If youre deleted, Ive seen most recommendations saying go with 5.9 spec at 0.010 intake and 0.020 exhaust. Many of the stuff I recall about using 5.9 spec suggests it also quiets down valvetrain noise quite a bit.
Hope this helps.
08 Resistol. Emissions cleaning pending. Anarchy EFI, Sinister coolant filter, Carbonite DP sensor, CSS -2"/+400# springs, reverse level, Amsoil bypass filter, and a pile of boxes in the garage
El Pozzinator is online now
post #5 of 5 (permalink) Old 04-16-2019, 01:25 AM
My 2010 was doing the same thing! I heard the clicking noise coming from the drivers side front wheel. The center cap was kind of loose in the wheel so I thought maybe that was it. Jacked up the front axle and spun the wheel and you could see the u-joint had enough play in it and was sliding from end cap to end cap every 180 degrees of rotation. Ordered new u-joints for the front axles!
2010 2500HD Crewcab 4x4 68RFE 3.73s Longbed Laramie
dcs1968 is offline
Similar Threads
Ticking noise..PLEASE help, it's driving me crazy!!! TxHD01 3rd Gen. Powertrain 11 11-19-2013 11:34 PM
2010 Big Line Kits & 2 Micron Filter Kits Glacier Diesel Power Glacier Diesel Power 27 10-16-2013 09:08 PM
Swapping 2010 front seats. curuxa 4th Gen Non-Powertrain 12 07-22-2012 09:11 PM
2010 replacement fuel tank question truckin-on 4th Gen Powertrain 11 06-22-2012 04:06 PM
2010 engine ticking when cold mikeg091578 2010-2012 General Discussion 30 11-07-2011 09:04 PM
