EGT Sensor with PPEI - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 04-11-2019, 05:19 PM Thread Starter
salisboz20's Avatar
I am inquiring if anyone has installed an egt sensor for a 2013. I am tuned with PPEI on the ez Lynk platform. PPEI says to use an egt sensor from the exhaust in the egt blockoff plate and use the factory egr harness to read it. I have an egt sensor but no where to plug in. I am lost
'13 Ram 2500 Tradesman Flame Red Stock For Now
salisboz20 is offline
post #2 of 5 (permalink) Old 04-13-2019, 10:39 PM
Iím tuned with EFI Live autocal and I ordered the edge CST2 and their egt probe, which connects directly to the CST2 monitor in the cab. Could that be what they are referring to? I didnít think the factory harness supported aftermarket egt probes.
andytall23 is offline
post #3 of 5 (permalink) Old 04-14-2019, 08:46 AM
jbell's Avatar
You need to use one of the factory sensors from around the DPF. Then find the sensor in your down pipe and unplug it. Use that harness with an extension harness (canít remember if itís PPEI or HPP) to run it up to the block off plate.
2016 2500 Megacab 4x4, EZ Lynk with Anarchy tunes
jbell is online now
post #4 of 5 (permalink) Old 04-16-2019, 09:28 AM Thread Starter
salisboz20's Avatar
I have an extension harness and plugged it into the only plug for the downpipe and it still does not read. The plug is almost down by where the dpf bolted onMine is tapped into the manifold not in the block off plate but still should not make a difference which would be EGT 1. Correct?
post #5 of 5 (permalink) Old 04-16-2019, 02:26 PM
jbell's Avatar
That depends on your tuner but with Anarchy mine reads on EGT 5.
jbell is online now
Similar Threads
EGT gauge electrical help needed MNfarmboy 3rd Gen. Non-Powertrain 3 04-17-2016 12:03 AM
EGT reduction on a budget. PWTurboProps 3rd Gen. Performance Parts Discussion 26 11-12-2015 08:57 AM
12v in a 07 ram 3500. My EGT is out of hand on a stock motor??? I don't get it street_legal? 94-98 Powertrain 24 07-26-2012 08:02 PM
EGT Sensor Fooler bondsman22601 07.5 - 09 3rd Gen 6.7L Performance Parts Discussion 12 04-22-2011 10:31 PM
EGT spikes to 1600 degrees DFLS 98.5-02 Performance Parts Discussion 20 12-31-2010 06:50 PM
