bleed question,, longer front break lines - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 04-11-2019, 04:14 PM Thread Starter
I ordered some longer front break lines for my 2012 because of the 6 inch lift. When I put them on am I going to have to do a bleeding procedure or will break fluid siphon down through the new line so I can attach to the caliper? Or should I try this in the parking lot of the mechanic shop so if I f up at least I wont have to have it towed.
ar_mcadams is offline
post #2 of 10 (permalink) Old 04-11-2019, 05:18 PM
Definitely bleed, procedure is pretty simple, plenty of videos on YouTube. A friend is helpful.
Sent from my ONEPLUS A5000 using Tapatalk
trevgrove is offline
post #3 of 10 (permalink) Old 04-11-2019, 05:51 PM
If you replace your brake lines, yes, you will have to bleed the system.
2014 2500 4x4 6.7 reg cab.
Soon to be leveled on 35s
Ergovation is offline
post #4 of 10 (permalink) Old 04-11-2019, 06:02 PM
08 Cummins
KhakiCummins's Avatar
Any time to break open a brake line, you need to bleed the line.
Duane
2008 Ram 3500 QuadCab
KhakiCummins is offline
post #5 of 10 (permalink) Old 04-11-2019, 07:02 PM
Gator1's Avatar
yes, air compresses fluid doesn't so you need to get all air out. As soon as you crack the seal on a line it's gonna suck air.
03 Dodge SHO CCLB Dually Banks intercooler 4" side draft intake. Carli/Thuren Argon filled Shocks, radius arms, SRW 4 link Conversion, 17"methods, 42" Goodyear MTR Kevlar Tires / 6 in a row ready to tow! NO BUSTERS
Gator1 is online now
post #6 of 10 (permalink) Old 04-15-2019, 05:34 AM
A scan tool is needed to bleed the abs module
WhiskeyThrottle is offline
post #7 of 10 (permalink) Old 04-15-2019, 08:35 AM
The module wonít need bleeding. Gravity bleed the lines before attaching them to the calipers. Youíll still need to bleed the calipers but itíll be much easier.
Jhenderson is offline
post #8 of 10 (permalink) Old 04-17-2019, 12:17 PM Thread Starter
So as long as I dont let the system go dry the ABS module wont have to operated?
post #9 of 10 (permalink) Old 04-17-2019, 06:12 PM
That is correct. You can even gravity bleed the calipers once theyíre mounted. I always bleed the system with the pedal as a last check but there should be very little air at that point. No need to start the truck. I generally use 3 slow, very firm pumps of the pedal and hold while someone opens the bleeder. Donít let the pedal go to the floor and be sure to close the bleeder while the pedal is still being pressurized.
post #10 of 10 (permalink) Old 04-22-2019, 11:29 AM Thread Starter
Well I got my longer brake lines on and bled them, I had to tighten the banjo to caliper bolt more than the called for 20 ft lbs to get it to stop leaking. I had to tighten it to 35 to get it to seal to the new crush washers. Also had to tighten the bleed screws a little more than 14 lbs. Had to go 16 lbs and I hope that stops them from seeping.
Similar Threads
I learned a new dealer trick today, dont trust the window sticker #s!! kalantar 2013-2018 General Discussion 15 04-18-2017 03:22 PM
front end question? 2011laramie 2010-2012 General Discussion 5 10-18-2016 12:54 PM
General Maintenance cummins6707 07.5 - 09 3rd Gen 6.7L Powertrain 24 09-24-2012 12:32 AM
Front end part question... Please help!!! rex2725 94-98 Non-Powertrain 3 12-03-2011 10:14 PM
Oil/Filter change interval w/deletes Hounddog 07.5 - 09 3rd Gen 6.7L Performance Parts Discussion 38 10-15-2011 10:13 AM
