Troubles not retuning after swap? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 04-09-2019, 09:57 PM Thread Starter
Hey Y'all.
I am in the middle of swapping out my stock VGT Holset for a s300 turbo.
If I were to swap it out keeping the truck around the same power, would I have major troubles if I don't retune immediately? I do not know if the VGT settings were shut off by the previous owner.
The truck is a 2011 6.7 3500 automatic. It has a H&S mini maxx which obviously is no longer in business and the screen is black.
Before I go into buying a new tuner/tunes would I be alright to drive my truck for a while?
Thank you for any input.
Natebrody11 is offline
post #2 of 6 (permalink) Old 04-10-2019, 10:54 AM
08 Cummins
KhakiCummins's Avatar
The truck will probably be a slug at lower RPMs. The VGT tuning is designed to spool the turbo by closing the nozzle. This will make it hard to spool the new turbo down low. Once you get up to higher RPMs, it probably won't be as bad but I would not expect it to perform the same.
Duane
2008 Ram 3500 QuadCab
KhakiCummins is offline
post #3 of 6 (permalink) Old 04-10-2019, 12:52 PM
N of 60's Avatar
I would be more concerned with driving it around if the Mini Maxx is not communicating on start up with the ECM anymore and has reverted back to stock fueling and timing is at 2 or greater. Nothing with swapping turbos will hurt anything.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.80 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #4 of 6 (permalink) Old 04-11-2019, 01:14 PM Thread Starter
Thanks for the reply. I drove it home from a shop which is only about a mile and you're definitely right, Really sluggish down low. Never went fast enough to feel the top end. Would this be helped with the right tunes?
post #5 of 6 (permalink) Old 04-11-2019, 01:16 PM Thread Starter
That's a little terrifying, i drove the truck about a mile and it's sluggish. I'm not moving it again until I'm retuning it. Thanks.
post #6 of 6 (permalink) Old 04-11-2019, 01:17 PM Thread Starter
[QUOTE=Natebrody11;28953427]
You sound knowledgeable on tuning do you have any opinions of where to go with it? Do I need a screen or can I get something like a chip? Thank you for any help.
Similar Threads
Another successful 48RE to G56 6 speed swap MTMike 3rd Gen. Powertrain 72 05-08-2018 03:19 PM
68rfe to G56 swap. Everything you need to know and my swap. JGray.proaudio 07.5 - 09 3rd Gen 6.7 Liter General Discussion 13 10-06-2014 12:18 AM
NV4500 Swap Tutorial With Pictures Diesel_Addiction 94-98 Powertrain 24 12-01-2013 03:15 PM
Manual to Auto Swap questions luckyhat12 3rd Gen. Powertrain 12 09-11-2012 07:01 PM
d80 limited slip carrier swap possible? brianell 98.5-02 Powertrain 3 08-08-2012 02:16 PM
