68rfe up shifts HARD! - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 04-04-2019, 07:17 PM Thread Starter
jcfpd8012's Avatar
Driving unloaded trans shifts nice and firm. Loaded with the 15k 41ft 5er, the trans up shifts violently 1-3. So violent the whole truck will shake when accelerating. It did the same before deleting and adding the line pressure. Had the dealer look at it with the 5er hooked up and all they did was set it to re-learn. Which did nothing. Been dealing with it for a while but thought I would post to see if they are any solutions. Searched around and did not find a lot.
jcfpd8012 is offline
post #2 of 4 (permalink) Old 04-06-2019, 12:08 PM
91Dodgecummins350's Avatar
Well, since it did it before you deleted I'm going to say it isn't a tuning issue. And now that you've made your warranty go bye bye you're kind of screwed.
I would get a data log and send it to your tuner and see if they can do anything
'14 2500 Laramie 68rfe - Efi Live by Anarchy, BD 68Protect, 4" straight pipe
'91.5 W350 RegCab SRW 5 Speed, he351 over s472, 6x15s, 182/214 Cam, custom head work, #60 valve springs, HVLP Lift pump, 3800 gov spring, BHAF
91Dodgecummins350 is offline
post #3 of 4 (permalink) Old 04-06-2019, 12:17 PM
Billy V's Avatar
Did you ever have it checked out before deleting? That certainly would have been a good time to check it out.
What does the dealer say he can do now? Will they still fix it under warranty?
There is always the SunCoast or RevMax option at $8000, but it will be a much stronger transmission.
2017 Ram 2500 Laramie CTD 68rfe 4x4 CC SB
Billy V is offline
post #4 of 4 (permalink) Old 04-07-2019, 02:47 PM
nick00less's Avatar
Whose your tuner? Do you know what a data log is?
'14 6.7 S465 tuned by CTT
'17 6.7 tuned by CTT
'18 6.7 S467.7 tuned by CTT
nick00less is offline
Similar Threads
How hard does does your built 68rfe shift? sicumminsde 4th Gen Performance Parts Discussion 15 04-02-2019 09:26 PM
EGR Delete, Transmission shifts hard 762soldier 2013-2018 General Discussion 6 01-05-2019 05:26 PM
68RFE New Calibration now shifts funny..Why? cgc 4th Gen Powertrain 5 04-10-2018 09:02 PM
Shifts hard into 4 wheel drive DP's Cummins 07.5 - 09 3rd Gen 6.7L Powertrain 16 12-15-2012 12:06 PM
hard shifts badherb 911 Urgent Situations 3 10-03-2011 09:55 AM
